When I test drove the car I didn't notice these annoyances which are of great concern. I called the Toyota Service Dept. on Friday (yesterday) and they indicated there have been problems with the Toyota Highlander not shifting intelligently . Apparently Toyota replaced the manual throttle to a sensing throttle on 06 and 07 models and they are aware of complaints. The service manager basically indicate my problems were just normal and they would check the vehicle to determine if my car received the software upgrade. But other than that there was nothing they could do. (sounds like I am screwed). The head of the service Dept indicated that it was up to Totota to supply another software upgrade not the dealership and until Toyota acknowledges they have a problem nothing will be done.
I am thinking if Toyota knows there is a problem why don't they just upgrade the problem with the correct software package. I am greatly concerned that if I am experiencing some problems this early it will only get worse.
Dave.
Yet I have my new Highlander coming in next week.
Is there anyone out there with an 06 or 07 Highlander that shifts just fine?
Out of curiosity do Dealers want you to sign the papers before you take the test drive normally? Or can you wait to sign until after the test drive?
"Thank you for contacting Toyota Motor Sales, U.S.A., Inc.
,we appreciate the opportunity to respond to your concerns."
"We do not show any Special Service Campaigns or recalls on the transmission of the Highlander, and thus would not have any formal indication of this being a commonly reported concern."
"It is through communications such as yours that we become aware of the reactions and expectations of our customers, and we are able to review and improve upon the quality of products."
"Thank you for choosing Toyota and we hope you enjoy your new Toyota for many years and miles to come!"
I can understand your concern, because of some of what is posted here. As I mentioned before our 2005 has run flawlessly for over two years and 30K miles now. Our newest addition of the 2007 has also been perfect so far. And, I know and have talked to a lot of owners who have told me theirs have run the same as mine. This issue has interested me and I have made a point of chatting with any owner I can. So far, I have not met a single person in real life who has reported any problems like this at all. So, while there are some people here reporting the issue, it would indeed seem that Toyota's statement of "would not have any formal indication of this being a commonly reported concern" very true.
I am a very happy customer who would proudly recommend the Highlander to anyone I know.
Talk to as many real people as you can and I expect you will hear that most everyone who owns one feels the same as me.
Good Luck
covered for the first 8 years or 80,000 miles of vehicle use on 1995
and newer vehicles:
* Catalytic converters.
* The electronic emissions control unit or computer (ECU).
* The onboard emissions diagnostic device or computer (OBD)."
EPA Environmental Fact Sheet
This link dates back to 1996 so if someone has more current info, please speak up.
And some dealers may try to avoid the warranty by claiming abuse, like driving around with the check engine light on for weeks or failure to follow the required maintenance schedule.
The service writer has an HL and is not happy with it. He said they are waiting for an SB concerning the accelerator pedal,hesitation etc.,something about flashing it.
Glad to hear you are happy with your Highlander and good luck with them.
That attitude won't help you much at the service desk either when you have a problem. That's a fact.
I think you missed the
SUVs and Smart Shopper
I am considering a 2005 Highlander with 13K on it. I am sure the car still under the original warranty. Will I be able to purchase toyota extended warranty or does that need to bought by the original owner?
Chris
If not.....a Toyota dealer would have the ability to look up your VIN number, and definitely tell you whether your vehicle has those features installed.
P0440 EVAP Emisison Control Malfunction
P0441 EVAP Emission Control System Purge flow fault
P0446 EVAP Emission Control Vent Circuit Malfunction
ANyone have an idea what this ,means?
Dan
I'd do a look at all of the small vacuum hoses looking for a hose off, hose split, plastic fitting broke, gas cap off, etc. Your charcoal canister might be underneath the vehicle.
Got the Camry 07 service manual out, and for a P0441 (Evaporateive Emissions Control System Incorrect Purge Flow) it says the trouble areas are:
- Purge VSV
- Connection/wire harness (Purge VSV ECM)
- Canister pump module
- Leakage from EVAP system
- Leakage from EVAP line (Purge VSV Intake Manifold)
- ECM
Good Luck
Edit....sorry, I just realized the 2nd post is from you as well, where you identify the vehicle as 2002. With a quick review of 2002 manual, I don't see any breakout of error codes to trouble codes. Regarding waterpump...yes. For a 6 cylinder fiber belt replacement, it is normal to replace the water pump while they have the front of the engine open. The fiber belt drives the pump, so they are right there and it is easy to replace. You don't want to have to pay a 2nd time to go in and replace the waterpump.
I purchased a highlander 2007 4X4 6 cyl this month. One thing I have noticed is that when I release the brake there is a lot of noise. is this something which will go away with tim, or should I show it at a dealers ? I have driven some 250 miles.
One other thing you can test to help in diagnosing......Go out into an empty parking lot and jam on the brakes hard to see if you can get it to skid....see if the ABS is working.
Anyone else have this problem? :confuse: My Highlander has over 108,000.
I purchased a highlander 2007 4X4 6 cyl this month. One thing I have noticed is that when I release the brake and turn the steering there is a lot of noise, which seems to be coming from the back of the vehicle . Is this something which will go away with time, or should I show it at the dealer's ? I have driven some 250 miles.
Any guidance will be deeply appreciated
Otherwise you have a VSC sensor failing.
Should I take the car to the dealer ?
Have you visited your dealer? How's the result? I think I have exactly the same problem as yours. Mine is also a 2007 4X4 6 highlander with just 1000 miles. I have the same kind of noise coming from back of the car while turning the steering when the car is still, of course with brake pedal off. It seems it's kinda common problem not just your car. Thanks for sharing your experience.
On all the other vehicles that I have owned for the last 20 years including Fords, Toyotas and Hondas the temperature guage usually runs at about the one-quarter point vs. the half way point my new Highlander does.
It does sound like no biggie running at the halfway point though since your wheels run at the halfway point on the temperature guage.
