Head Gasket Replacement
I suspect that engine coolant may be in my oil. I have been pointed to the head gasket as being the problem. How quickly does this need to be taken care of?
If there really is coolant in your oil, yesterday wouldn't be fast enough.
I wouild check service bulletins for you car at
http://www.nhtsa.dot.gov/cars/problems/tsb/servicemmy1.cfm
They may have some information on this. I had a Dodge with head gasket issues, and 5 years later they came out with a TSB that recommended placing on a different valve cover. Problem fixed. It used to have to be replaced every year, now it has been 3 without a drop of oil leaking.
Cost of valve gasket replacement between $65 and $100 for me. I have heard it as high as $225 for others.
Personally, even if it's just oil I think it should be fixed, quickly since the cost is low compared to having a new engine. I had a friend who didn't repair it and a piston cracked. Afterwards, have the engine steam cleaned. It disappates heat better when cleaned, and helps minimize the chance for electrical fires.
