flushing, engine oil
Should I do it next time?
On other boards, I have heard numerous accounts of engine flushes making old engines worse or killing/seizing them completely. People take an older engine that has a slight leak or oil consumption problem and ruin it with these damaging solvents.
Mostly, I'm talking of the kerosene-type engine flushes. This stuff ruins an oil's ability to lubricate and the engine damages itself when you are running it, distributing it throughout the motor.
Basically, on old, tired motors, leave sleeping sludge lie. If you feel like you MUST remove it, try frequent oil & filter changes using a motor oil that has a reputation for high detergency or possibly a mild detergent additive like CD-2.
--- Bror Jace
I suppose that oil has even more detergents, etc.
Dunno the details about those oils, but if it meets the performance specs...
Any danger in such a technique?
TB
If an oil meets the API spec, does you advice still apply.
Somehow this link came to me, and it is an oil marketed towards the trucking industry, but meets standards for both gasoline and diesel engines.
http://www.chevron.com/prodserv/nafl/L1_J.htm#3
Meets SH API spec, amongst others.
Wouldn't you be ok if the oil you chose meets the API spec your owners manual specifies?
Cheers,
TB
The junk in your engine maybe doing you more good than you think.
The polyol ester-based synths in this test left virtually no deposits.
But sure, you can make your own blend.
See Engine Oil, a slipery subject earlier entries, and also synthetic oil.
The 4X4 blend has worked well for a number of years in this car, so I'll stick with that.
Yes T-[non-permissible content removed], the 'heavy duty' truck oils DO have more detergents in them than most ... according to an article by Patrick Bedard in Car & Driver over a year ago.
So, you might want to go down to Walmart and get some Shell Rotella or Chevron Delo400 15W40 and use THAT to clean the inside of your engine. Leave it in for 2-3,000 miles and then switch back to something lighter/thinner for regular use.
--- Bror Jace
