Silverado HD SB -- 38 gal. Aux. Fuel Tank -
Tank - Mounted in place of spare tire.
Fab. drawing available for the asking-
Fabricated Steel (12 gage/.112" thk- about 75 lbs.
31" wide at rear w/sides tapered in to 24" at front to clear exhaust pipe outlet and shock. 31" front to rear. Front 12" deep behind axel. & Rear 9" deep at bumper/hitch.
Bolted to upper spare tire frame w/ four Reese 1/2 self locking bolts. Filler neck at rect. hole behind license plate.
Cost $250 to have made locally-
Purolator PRO#12S 35gph electric transfer pump-
Operated by Aux. Switch that comes w/with Snow Plow Option. Cost $33.00
Fuel is transfered to main tank by adding 3/8 hole in upper metal filler neck and installing a modified 1/8 NPT brass tube fitting connected to 90 degree 1/8 NPT brass elbow connected to 5/16 brass barb connected to rubber fuel line tubing.
This has been somewhat of a do it your self research and design project to find all the wireing for the Aux Switch and figuring out the double wall filler neck system.
75v
75v
And, where did your spare?
Mike L
(have never needed a spare when tires are new)
Gas Milage??
Have not had unit on long hiway trip.
Best I get 10.0 mpg B&F to work.
64 x 10.0 = 1000m -- I wish--but i got it for the power so not complaining.
Love this truck -- Just wish GM had more brains on proper fuel tank requirements.
Gas weighs 6 lbs/Gal last time i figured W&B on the airplane -- What's your point??
75v
Sure beats looking for gas stations when your down to that half tank level with the 26gal tank on the SB's every 100 miles or so. (:-)
75v
SledZep
Jim
GM Warranty -- This arrangement simply transferrs the fuel to the main tank and does not alter the main fuel system. However warranty issues kinda depend on the situation. I have had two gm dealers send people to see this installation and copy it for what that's worth!!
If your worried about SAFTY and WARRANTY issues it would be best not to do anything I guess, but I don't like looking for gas stations that i can get into with long 5th wheel every 100 miles.
As for the GM made aux tank for chassis cab they still used the old frames - NOT the HD frame - and thus would not fit. Course this is mounted exactly in the same place as GM mounts it you might note.
75v
