Infiniti G35 Sedan 2006 and earlier
In my opinion the interior is above average, but below the average for luxury cars. Actually I rank the G's interior about the same as the 2002 TL I traded.
For me, it's all about tolerance... and acceptance.
Unca D, if you can adjust to the G's interior, you WILL NOT be disappointed with your purchase. The only car I would have purchased before the G was the IS Sportcross, even though it's aging, I've always loved the shape and rarity of this model. But for some reason or the other Lexus has been holding these back and not offered them for sale over the last few months (I suspect for an HP upgrade).
Good luck with your decision, and be sure to let us know which car you chose. (I have a feeling you'll soon be a G-driver.
I have seen as high as 6.9 secs to a low 6.1 secs. what is the deal???
In general, early tests of a car are usually the quickest. The mfg knows how important early reviews are so they test several examples and supply the best one. And the magazines push the cars as hard as possible to get the best times. Later, everyone is more non-chalant about it and the times reflect more of an average car.
- Mark
In my opinion, the G35's controls aren't as poorly designed as some have made them out to be. To me, the key point is that the controls that I often use while driving must be accessible without being overly distracting. For example, I can use the steering wheel controls to turn the audio system on and off, change modes, or go to the next station or track without looking down, so the placement of the main audio controls isn't as important.
Other switches, such as the seat and mirror controls, may be more difficult to use than some, but once they're set I don't use them very often.
As for interior quality, I do agree that Infiniti could have done better. Overall, however, I think that the positives far outweigh the negatives. Since buying my G last summer, there hasn't been one instance where I've wished that I'd bought something else instead.
I also hope that Infiniti takes constructive criticism to heart and makes changes, but I don't have any inside information regarding their plans.
The coupe will have to compete with S2000 and M3s, and sedans with WRXs.
Should be interesting!
Should be interesting!"
Especially since the traction control can't be disabled!
Infiniti actually has the lowest rate of problems per car, according to multiple sources (like Consumer's Reports). It is probably the best sports sedan out there - that will also be reliable. BMW and AUDI offer some aspects that the Infiniti doesn't, but I would feel sooooo much more confident about the G35's longterm durability.
So, right now, I am leaning in that direction.
Thanks for the input guys! I appreciate the information.
JW
Just curious. Thanks in advance.
JW
Please keep us posted.
This seems trivial, but i'm about to buy the G35 premium with aero sports package. It comes with the five spoke rims, but the dealer said he'd change them for the six spoke if I want. I can't decide. Anyone have any preferences. Believe me I've been banging my head over this. If i get the five, then i'll probably want the six and if i get the six, i'll probably want the five
i guess i'm privellaged to have the option. if it would have cost me money then i wouldn't consider switching the wheels, but i think the fact that its free has put me in a dilemma. i guess in the end i'll get the five spoke, but i had figured that a aero sports package with 6 spoke would be different. i pick up my car next week and i can't wait.
As for a previous mention of "disabling LSD" -- the VDC system has what they call a "Brake LSD" where the traction system brakes the wheel that's spinning, forcing power to the other wheel. This is what cannot be disabled when you shut off VDC (according to the owner's manual). Of course, it's not nearly as effective as a real LSD.
Dropping to 12 cu ft with the full-size spare sounds about right. The way Infiniti does it is by raising the entire floor of the trunk a little to accommodate the fatter tire. That 1/2 inch or so (I'm guessing) spread across the whole floor can easily eat up 2 cu ft.
sorry, I didn't mean to jump on anybody.
The G35's TC system cannot be turned off totally. It has a "fail safe" function that cuts power and locks into 4th gear when the car decides you are having too much fun.
None of the press cars that were slolomed by the magazines displayed this behavior, which makes one wonder if these press cars had a "patch" in the software so these cars could be run to their full potential.
Gary Merideth, who owns the G35 that was the subject of the article, could get no help from Nissan/Infiniti.
We need to get together on this, folks!
If anyone knows some suit in the top corporate structure, please let us know their E-mail so we can lobby for the solution.
The G35 got real close to the real deal. The TC problem is the hardest challenge.
It's easy to solve the lack of LSD by installing the LSD pumpkin from the Coupe or Z. LSD would probably help prevent the TC from being activated.
But the real solution is a real "off" switch.
From the manual:
"If the vehicle is operated with the vehicle dynamics control system turned off, all VDC and TCS functions will be turned off. The brake LSD system and ABS will still operate with the VDC system off."
So they clearly seem to thing that TCS and Brake LSD are two different things. Here's what they say about Brake LSD:
"The VDC system uses a Brake Limited Slip
Differential (LSD) system to improve vehicle
traction. The brake LSD system works when
one of the driving wheels is spinning on a slippery surface. The brake LSD system
brakes the spinning wheel which distributes
the driving power to the other drive wheel."
They don't give any indication of what TCS does. Maybe it uses the yaw sensors, and TCS is for straight lines, while Brake LSD only actives when going around corners (and not in a skid). I'm speculating here.
My opinion on the matter is that the way they have it is fine for the average consumer, and I'd be happy if they offered a Nismo upgrade to turn the thing off completely.
This is similar to the traction distribution system that mercedes uses on it's suv. I think it's good for low traction events and getting moving on slippery surfaces, but probably not the best system for autocross or performance driving.
But...what do I know...my car has no ABS, TCS, and rear drums
(No, I haven't checked about what else is on the same fuse, just being theoretical for the moment until Infiniti steps in with a real solution for the sedan.)
JW
From comment 7201
Have seen several comments about a possible AWD G35 sedan.
What are the advantages and disadvantages of AWD compared to only rear drive?
Additional Sticker Cost ???
Any additional cost for maintenance???
Does it require more maintenance?
Answer:
From comment 7203 by jwilson1
Advantages:
traction at 4 corners, double the contact patch.
Disadvantages:
more expensive (usually about $1500-$2000)
heavier (uses power)
No extra cost for maintenance or repair. Most systems on the road are very reliable. Of course there are lemons with everything.
For more detail, you might want to check out some of the Subaru or Audi boards here, though you'll mostly hear about the advantages.
JW
you should get a survey from Infiniti in the mail, I would think.
Good Luck.
I only saw one other post re: price, so here's the deal that I got:
6MT (includes Sport)
Premium
Winter-Sport
Aero
Mats
Splash guards
$32,550 (inc. $545 destination and $320 Ad fee).
Only a few more weeks. . . .
I've been told that there are either incentives withheld from the dealer, or penalties assessed against them if their survey ratings aren't consistently high, or dip below Infiniti's standard.
I am almost 100% certain that this will spur action to address your issues. Then again, I don't work for Infiniti, so I could be wrong.
Nothing to lose by calling your salesman.
The AWD G35 will be released in April according to him. More expensive but, great news for us in the Northeast.
He had an FX35 there. Priced at $39,125. Awesome look and really nice job on interior.
Very interesting release by Infiniti
