Tacoma Supercharger, how much for dealer option?
shogun1313shogun1313 Member Posts: 17
edited April 2014 in Toyota
Ok, so who has it and how much was it?
  • briancorrbriancorr Member Posts: 67
    Go to www.tacomaterritory.com
    There are links on the home page to specials offered. You should be able to get it for around $2200.
  • 2k1trd2k1trd Member Posts: 301
    I have one on my 01 TRD and it's killer!...i was going to install it myself but later found out that you only get 1 year warranty verses 3/36 if the dealer does it so i dropped it of in the morning and picked it up at noon time and all for 2500.00 installed.My tacoma is a 5 speed also wich makes it even faster!
  • slamedtacomaslamedtacoma Member Posts: 18
    hey. has anyone seen anything for a 2.4l 4cyl. mine just aint fast enoph. thanks
  • smgillessmgilles Member Posts: 252
    I am going to get the supercharger put on this week. I also have a 2k1 trd. What did it do to your gas mileage? Also, have you put on the transmission cooler, or do you not pull anything? Also, is there anything else I should be aware of?
    Thx
    Make sure they hook the boost port to the fuel pressure regulator (you might want to mention this to the installer)also my truck is a manual trans so no cooler is needed.The gas mileage should stay about the same unless you drive it hard wich would lower the mileage anyway even without the charger.I run 92 octane and have zero detonation problems. ......have fun! :)
  • got1bgot1b Member Posts: 48
    How do you all like the supercharger? Is it worth the cost? I found the regular engine sluggish when I test drove the double cab. The hard part is you can't test drive the supercharger before deciding to buy the vehicle. Also, how is the stability? Does the vehicle feel like it could easily roll over? Thanks for your help.
  • ebbgreatdaneebbgreatdane Member Posts: 278
    Not sure if you're still checking but:
    1. Those that install the super charger have nothing but praise.
    2. Those that install the super charger have no bottoms to their wallets but if they did that would be the one complaint.
    3. Stability...With the TRD package I haven't been able to break the tires loose from the pavement (and I've tried).
    John
    Thanks for the information. I check occasionally (obviously). I must say I am surprised that I am not getting a lot of feedback. I guess this category is dead. Enjoy your truck!!!
    It's just that most people can't afford the option.
    Yours Truly included...
    John
