Deciding on a new diesel 4 door 1 ton SRW LB pickup
bobsquatchbobsquatch Member Posts: 136
I am gearing up to buy a new truck. I need a 4X4 diesel 1 ton 4 door long bed with single rear wheels. I am most familliar with the Ford Powerstroke because I maintain them as part of my work. The problem is that everyone I talk to is so blind in their loyalty toward ford as the ultimate truck it is hard to separate fact from fiction. I am leaning toward Ford at this point with two exceptions. They seem smaller than just a few years ago. ( I could sit in the back seat with my hard hat on in 96-98) I also heard a rumor that every five years ford recommends replacing the entire fuel system at a cost of around $5000.00 to keep your truck running.(diesel only). The Duramax sounds impressive but I am leary of first year anything and I hear of a tick and a shudder that the dealers are unable to resolve. I have heard however of the 100,000 mile waranty of the Duramax truck... Is this true??? Lastly I hear the Dodge cummins is a great engine but the trucks it comes in do not hold up as well as they do. I also feel that they would be a bit underpowered for what I need even though I like the idea of a straight six in a diesel. Finally, why I need this truck. Primarily it will be a daily driver/family mover. Weekends and holidays it will pull a 10,400lb trailer RV. I get stuck enough 2WD to justify the 4X4 even though it's no trail rig I really do need it for Mexican boat launchig and getting away from all the motorhomes in the desert. Dual rear wheels just pick up rocks and cost more to replace and I can haul the load I need without them or the fat fenders that come with them. I am ready to buy once I decide which is truly best suited to my needs so all genuine unbiased advice will be greatly appreciated and heavilly considered. I have not decided between a six speed manual or an auto yet and will hear arguments for each. I am leaning for the longevety and power of the manual versus the convenience of an auto. Thank you my fellow truckers for your advice. I will let you know what I decide and who to praise or blame as time goes by.
  • richcolorichcolo Member Posts: 81
    There are no crew cab Dodges, so you'd have to settle for the smallest extended cab in the business. I don't know about you, but I expect my boys to grow, so I won't be getting a Dodge.
    I'm leaning toward a Duramax 6 spd., crew cab, short bed (fits in the garage, long bed won't), 2WD w/ posi rear. Before I take the plunge I will take a good hard look at the equivalent Ford.
    The uses will be similar to yours, although I like to be able to hook up to water and power, so I stay close to the RV's, and so far I've always managed to recover the boat with 2WD, so I can't justify the extra $3,000 for 4WD (in lieu of the posi).
    I'm not going to get the new truck before the 2002 model year, so the first year jitters are not an issue.
    If I worked on Fords for a living, I'd probably get on for myself, just so I'd have some idea what to expect. I have no experience with Fords, or with the Navistar T-444E (also known as PSD). I do have some experience with B series Cummins (12-valves) and with GM 6.2 and 6.5 diesels. By any measure I can think of the Cummins is far superior to the old GM. Although a few people have gotten high miles out of the GM's, I personally consider them to be hand-grenades waiting to explode. Duramax is the first serious diesel to be available in GM trucks, in my opinion. I have nothing bad to say about Cummins 5.9 engines, except the 24-valve sure is LOUD. If there were crew cab Dodges, I'd be seriously considering buying one.
    Personally I'll be getting a manual transmission, because I like them. Every Allison transmission in my experience has been extremely robust, and I wouldn't expect this new one to be any different. Once again, I have no experience with Ford automatics, so I won't offer any advice about them.
    I hope some others will post their thoughts, to help us out.
    Chevys 1 ton (new body style) only comes in DRW.
    Looks like ford is your only option
    Ryan
  • sebring95sebring95 Member Posts: 3,241
    I'm purty sure the Dodge is only available with dual rears in 1-ton also. Although the towing capacity is very similar, so a 3/4 ton should do the same for ya. The duals will haul the weight better. I believe the Ford is the only one available with a 1-ton and single rears.
    We do alot of pulling with horses and I know many people with heavy-dutys of different makes and models but mainly Fords & Dodges as the Chevy's weren't attractive until just recently. I've seen both makes go through trannies, rear-ends, and alot of small stuff. Personally don't see a big difference between them as far as reliability goes. The Ford has a much more attractive offering with the crew-cab which I'm sure is a big part of why you see alot more SD Fords than anything else. Dodge should have a crew-cab sometime next year, will be intersting to check out.
  • eric2001eric2001 Member Posts: 482
    The GM 2500HD is rated higher payload than the Ford 1 ton SRW, so in actuality you can choose either. Both 2500HD & 3500HD use the same frame, but the 3500 gets an additional leaf or two. The 2500HD is really a SRW 1 ton in all but the labeling.
    Richcolo & Sebring95: Dodge is releasing a real crew-cab for 2002. I don't know about the 1 ton SRW or not, though.
  • jwhaelen1jwhaelen1 Member Posts: 27
    Bob, Not enough power with a Cummins?!?!? They use the Cummins motors in 18 wheelers.The Cummins also has a 10 yr/100K warranty. If you are going to pull the trailer you are talking about,you will hardly know its back there with the Ram 2500HD(same as 3500 without the duallies out back IMHO)PLENTY rugged too!.That is what I own and its deffinately a powerhouse(see my profile). It will pull your trailer "like a joke"! I use my truck to haul construction equipment to and from our jobsites,you name it(backhoes,bobcats,ditch witches,etc.).Approx.12,000LB worth of equipment goes on the trailer(gooseneck).Dodge doesn't put heavy duty Dana axles on these trucks for nothing(LOL)!If you can wait, Dodge will have a new Ram-Cummins(4 full size doors!)setup with 300HP & 650LB of torque in the fall of '02(2500/3500) I am thinking about getting one of them,with the new Cummins(of course),in 2003 or so. You can get an idea of what they will look like at:www.car-truck.com or: www.turbodieselregister.com .Word of advice: get the 5 or 6 speed manual with the 4:10 limited slip(Dodge calls it"antispin") rear end for maximum pulling power(Auto tranny is a bit weaker).Good luck on whatever brand you decide on!
  • bobsquatchbobsquatch Member Posts: 136
    Come on jwhaelen1, it is not the same engine in the big rigs. I drive the big rigs and just because cummins makes engines for them it is not the same one that is in your pickup. That engine in my rig wouldn't get over 30 mph on flat ground. Plus I prefer cat engines in my big rigs. I am not discounting dodge yet but when comparing pickup engines lets stick to reality. P.S. Ford uses dana 60 axles too.
    Has anyone heard about ford sending a notice to new powerstroke owners telling them to replace the entire fuel system every five years at a cost of $5000? It could be a rumor but I doubt it
    I wouldn't mind having a Cat 3126B under my hood!(LOL) Lotsa power.860FT LB of torque- Yee-ha!(can we say overkill).Besides,I don't think my frame would like that too much.(LOL).I LOVE MY CUMMINS!People know your'e coming down the road & steer clear-they respect that diesel and DON'T DARE to cut you off-especially when hauling a big load down the big road(RT 95).Don't have to worry about the "chickencoops" either!.(LOL)Although a Bear did follow me once for about 35-40 miles(not sure why though)I don't think I was overweight & I wasn't speeding or anything.Well anyway,As far as fuel system replacement in the PSD SuperDuty trucks goes,can't help much there.That's a new one on me.Check out: http://www.dieselpage.com or http://www.ford-diesel.com ,there might be some helpful info there. If there is,a problem,it "should" be covered under the warranty if there is one,IMHO. I know mine is.My lift pump was going out on me(no top end power-mushy pedal),and that was replaced free of charge on the Cummins warranty(10yr/100K) Oh,Not trying to start any fires but,Dodge uses BIGGER axles than the SuperDutys do. Ram has Dana 70's front & Dana 80's out back(huge!).I'm Not trying to steer you towards Dodge,just trying to help ya out. Let me know if you have any more ???'s about the Ram HD's,capacities,experience w/ truck,engine,fuel MPG,etc.,and I'll be glad to answer them for ya. "Catch ya on the flip side driver".
  • modvptnlmodvptnl Member Posts: 1,352
    http://dodgeram.org/tech/specs/Ramspecs.htm
    If you have an auto trans you get a Dana 70 rear and ALL of 'em get a 60 on the front.
    Ford puts the 60 fronts on the 450/550 and disc brakes on ALL the rears.
    Hopefully Dodge will get modern with their brakes to handle all that massive power.
    Mod, what does this have to do with your V-10????Anyway,my 5-speed version has a Dana 80 for the rear and Dana 60 up front not 70 as I accidently typed(due to burnt out desk light-LOL)Sorry about that Bob. As for you Mod, I believe the subject is also "unbiased"(AKA non-bashing) about DIESEL powered trucks, and NOT about your V-10 gas burner.And,yes Mod,My truck halts just fine. So,in short,quit trying to "stir the pot" over here also!!! It's just not gonna happen.
    A little touchy there hey, whalen??? Just figured I'd correct the "mistake" on the axles. Don't want any incorrect info to potential dodge owners now, do we?? Sort of like when you said they use the same Cummins from the dodge truck in the 18 wheelers!!!THAT WAS A GOOD ONE!!! Two quick question, J. why did you delete all your posts in the "pros and cons in a diesel pick up forum" where you said the powerstroke needed the entire fuel system replaced???
    Where did I mention my truck???
    Red...er..lake....er dan hull, quit trying so hard. It really is quite obvious you're touched in the head!!! ROTFLMFAO!!!
    I drove a 2500 extracab duramax 4X4 with the allison trans yesterday. It was the closest thing they had to what I wanted on the lot. The thing is a monster out of the hole but is very flat on top. I didn't have a chance to pull any weight so I cant say if I like the power or not but unloaded it sure tapers off at higher speeds. What I liked about it is great bottom end power, a super soft but firm ride, they offer a true locker, I saw an external spin on trans filter, and a comfy cab. What I didnt like was the ifs center disconnect front axel (I know that is where the soft ride comes from) because they are expensive to lift and repair plus you cant get manual hubs which leaves you at the mercy of the actuator that will fail. Also the power brakes are plumbed to the power steering pump. Ford did this for a while and it failed so I am leary of it. Lastly some of the welds and other connections under the looked cheap and weak. Lastly, the 100k mile warranty is only good for 5 years.
    I also test drove a ford psd that had almost everything I wanted. As the sales rep pulled up he said something isnt right so I gave it a once over and found somone had locked a single hub. As we left the lot the service engine light came on so we went around the block and came back. Probably just a minor thing but a terrible first impression. I may go test drive a dodge today but they are pretty much out as they do not offer a true 4 door yet. By the way whalen, I have had a dana 60 rear in my van that has been abused to extremes and have had zero problems so I am comfortable with that size and up. The stronger the better but I can live with 60's happily. Question, the big problems I hear about the dodge is the steering on the 4X4 3/4ton+ models and that the little things like fit and finish deteriorate quickly. Have you experienced this?
    OK!, That's the best thing you can do is test drive each brand "like you stole it"(LOL)! Even better if the salesman let's you borrow it over the wknd,but that probably wouldn't happen, who knows though... That's what I did before choosing the Ram. The main reason I went with the Ram is due to the fact it has a Cummins for an opt,not because of vehicle brand.I'm not loyal to any one brand.(I own a '79 C-30 & 2000 Tundra also). The only thing that I didn't like about my interior on the Ram,is that the rear slider had a leaking gasket and soaked the carpet(fixed next day under warranty) Another minor thing is I wish I had a 6 speed(NV5600) in it. I drove a 3500 w/ Cummins H.O. 2wd with the 6 in it not too long ago and it was a blast!. It had ALL KINDS of power-Unreal! I was jealous!(LOL) If you get a chance to drive one you might get hooked.....I almost did! No 4wd on it though. As far as the steering goes, I've only seen one truck that had a steering related problem.A steering pump went "out to lunch" on them after a long trip back from NC. Dealer said a bad bearing was the culprit. I don't know the exact details,but they(owners) discovered it the next morning before leaving for work. Dealer gave them a loaner for the day,and the truck was up and running that afternoon. Bob, have you seen the new Ram crew cabs yet? I'm still deciding if I want one,later down the road when/if I ever get tired of this one. I probably won't get tired of mine anytime soon though. It's still really fun to drive. See if you can test drive a 6 speed HO Cummins/Ram. They're Great! It could probably pull,or haul just about anything your'e crazy enough to hook up to it! (No B.S.) Have Fun Bob.
    Which one fit you better? We talked about your height, and I was wondering how you made out.
    Does anyone know the release dates for the new Dodge crew-cabs? When will they be on the lot? Will the updated Cummins be 2002 or 2003?
    -Eric
    My neighbor is ordering one, and according to him(Mopar nut),they'll arrive late this summer(Aug 15th-Sept 30th).That seems about right I suppose. Check out this site for the new Cummins/Ram setup: http://www.car-truck.com Enter "Cummins" in the search block. They even test drove a new 1500 and posted the review on it.The new front ends look like a "guppy" to me, IMHO. I'm still undecided untill I see the new HD's up close and in person. Maybe(I hope) they'll look "meaner" than the new 1500's. We'll see.
    Hi Eric, I have sat in all three and I have to recline somewhat in all of them. I hate the leather in all of them but the high end cloth seats are comfy, particularly the dodge. I think the ford is biggest but none are big enough.
    John, do they make a high output version of the cummins? How much difference? I can't find a 6 speed on the lot for any of the big 3. I guess when people buy a high end truck they all want the luxury of an auto vs the durability/power of a H.D. manual. This is a problem as I want to drive them before I order one and it is seemingly impossible. I am still undecided about the trans I want. How many miles on your ram? any squeaks or rattles?
  • lariat1lariat1 Member Posts: 461
    The HO cummins I believe is 505 lb-ft of torque and 245 hp it is a beast of an engine full torque is available at 1500 rpm and is level all the way up to 3000 rpm. The "normal" 24v cummins has 460 lb-ft of torque and 215 hp. Also if you are going to really work the truck (towing over 6000# all the time) get the manual the 6 speed is better but either are more reliable than the auto,the problem withthe auto is that there is not sufficient transmission fluid flow at low RPMs to prevent damage.
    Yessirreee,They most certainly do make a HO Cummins! It's deffinately a "powerhouse".505FT LBS @ 1400 rpm & 245 HP @ approx 2600 rpm's! IT FEELS LIKE MORE THOUGH.....They're deffinately worth checking out.(see my post:#14) for all the details. Yes, those Dodge boys did a fine job on the seats, I've driven approx. 5-6 hours+ before needing fuel at times and don't get tired/cramped up like I normally get when driving my Chev or Yota after shorter road trips. The only "rattle"(minor) I've experienced on my Ram so far,was a loose passenger side mirror @ 18K,Fixed under warranty.Typical minor stuff,which happens to all brands nowadays.Other than that,I really can't complain(39.5K and not even broken in yet),especially when I can squeeze approx.640+ hwy miles(65-70mph) out of a 35 gallon tank of fuel with such a heavy truck! I love the mileage I get on this thing. It's truly amazing.It does good towing also, I average between 10-14 mpg(65mph) with the trailer,depending on weight, and how much the turbo kicks in of course.Still,almost double the mileage of my '79 Chevy dually. Bob,Deffinately try to find a dealer,or someone who owns one of the 6 speed/H.O.'s.Word of advice: If you do decide to get the Ram, DON'T ORDER THE AUTO TRANNY(47RE)!!!(they suck [non-permissible content removed]!) Here's a link to help you find every Dodge dealer in your area: http://www.4adodge.com Hopefully,someone will have one for you to "experience"(LOL). Current design HD's should be around till Jan '03 at the latest.After that, Gone for good(or at least till the new HD design takes over)! Let me know how you make out,as I am the curious type. Good Luck!
    I have been stuck doing domestics and haven't had a chance to do any more test driving to date. I just ratified my union contract so I am financially set for the next 3 years so I am about to get serious about buying my new truck. All input is welcome and appreciated
  • joestapletonjoestapleton Member Posts: 15
    Yes, I too am having difficulty deciding on a crew cab/x cab diesel truck. From the experience of friends who own these trucks I've found out that the '99 Ford Crew Cab 1 ton long box has had multiple braking problems with pulling to the side and repairs not always satisfactory. Also torque converter problems and this is odd because this vehicle rarely pulls any loads. The '99 Dodge 3/4 ton Quad Cab has had constant braking problems and has also had all brakes and wheel cylinders etc. replaced several times. This truck has always run empty as far as load is concerned and has only 40K on it. I have test driven the GM Duramax X Cab and Crew cab long and short box HD pickups and have found that the short box crew cab rides choppy compared to the others but really is smaller than the other trucks which is nice for the garage. I want to pull a 5th wheel trailer so the short box is out for me. I love the Duramax and the only problems I have researched is loose torque converter bolts on several trucks (I want an automatic) and the Allison transmission getting stuck in low gear. This happened to a friend and I haven't heard the results of that repair yet. I am concerned with GM's build quality especially after reading Edmund's long term test on a '99 GM truck as I have driven Toyota's for years (currently a T-100 X-cab) with almost non- existent problems and am not enthused with the idea of visiting a dealer often to repair a "NEW EXPENSIVE TRUCK". With all this I am leaning toward the new Duramax Crew Cab long box because of the transmission which Ford and Dodge are still working on and I need to haul a 14,000 LB 5th wheel trailer in the future. Also Dodge has had about as many problems with their manual transmissions as the automatic's including the 6 speed. Good Luck, Joe.
  • chevytruck_fanchevytruck_fan Member Posts: 432
    as much as it hurts to say this go with the powerstroke diesel, boycott GM and their dumb izusu diesel. If I was to buy a diesel truck I would get a powerstroke, which really hurts.
    If you are going gas their is no comparison to GM's gas lineup. The 8.1L V8 is just the ultimate power house, and the 6.0 does a great job too.
    joestapelton, if you read that article they complain about a lot of crap like rough ride (what a pickup is suppose to have), trim pieces falling off because some stupid person is putting their weight on a b pillar, no car is meant to have a b pillar as a pull up bar, while there was some problems, most of them were stupid crap edmunds wanted to complain about. I would give them a chance, most of the people with car problems are the ones that have what I call bad car carma, if you think the truck will give you years of problem free service that is what you will get. and since you have had years of trouble free service you probably have good luck with cars. weird I know but it is the truth.
  • quadrunner500quadrunner500 Member Posts: 2,721
    I don't know Joe. I haven't had any problems with my Duramax, or 2500HD in more than 8000 miles. It's been pure joy. Only visits to dealer have been for oil changes. No warranty issues. The problems you mention with torque converter bolts and stuck in low gear etc., are news to me.
    It's ironic. I have (3) pals with Powerstroke Diesels, and (3) with Ram Cummins. They are always advising me of some new Duramax/Allison problem they've heard about from the Ford/Dodge camp, that us poor chevy owners must have been kept in the dark about. As owners, we are out of the loop, can't get reliable information of course! I only know one other owner of Duramax. He's not had a hint of any problem also. At http://www.thedieselpage.com , you can probably surmise that most Duramax owners are ecstatic to have one.
    There's really no question, the Allison is the cat's meow of HD automatics. As for Duramax, it's under a lot of scrutiny and envy, natural for anything so new, with so much horsepower (300), and torque (520 ft/lbs).
    Having driven the PSD, it has more torque off the bottom from 500-1200 rpm. The Duramax makes more power starting about 1600-1700 rpm on up. Duramax seems to get better fuel economy unloaded than PSD, not quite as good as Cummins, about the same as PSD loaded, not quite as good loaded as Cummins.
    The aluminum heads have been criticized, but there are no documented problems, just rumor and innuendo. The diesel page has a poster who works for Isuzu. He states he inspects every engine sent
    back under the warranty exchange. While there have been a few isolated instances, he said some are sent back mis-diagnosed. There have been posters stating problems with the heads, usually reads like "MY HEADS MELTED!!!" He asks for a VIN, the dealer name, supporting documentation, poster vanishes. No head problems have been proved. And so goes much of the innuendo.
    In the end, you buy what you like, and are most comfortable with. In case of Duramax/Allison, I think most problems are exaggerated, if not fabrications altogether.
  • jcave1jcave1 Member Posts: 137
    Exaggerate? That would never happen. Seems like many of us, all too many, tend to lambaste rigs which we have little if any first hand experience with.
    My choice was PSD which my buddies bad mouth at every opportunity, they choose Dodge. I am pleased to know your choice was GM. Being the new comer, we're all anxious to know how it works out long term. Fact is, GM had to do it right considering the stiff competition they have.
    As for the PSD, it beats the F-150 I had hands down, sorry 150 owners. Lets not forget however that the PSD is a different class of rig. The comparison is a commercial duty rig vs regular half ton. Noticed your comment concerning mileage, yep the Dodge is better than PSD. Sounds like yours is also better than PSD. Considering all these rigs weigh four tons or more, 17 mpg and up is amazing. They acheive this loaded or unloaded, traffic or no. Gasers should be so lucky.
    With GM joining the bandwagon, the choices just became a lot tougher.
    Before I forget, first recall just arrived. Beleive it's wiper motor related.
    Keep on truckin.
    Jerry
    Goes without saying, all of us who own Duramax would be remiss if we didn't express our hope that the Duramax design will endure, and be as successful as the PSD and Cummins, both of which, while not still the new kids on the block, have nothing left to prove either.
    I am getting the 2002 Ford PSD CC 4X4 LB SRW. I have been agonizing over this decision for months and I have given up. They all have their strenghts and shortcommings that could be considered for an eternity. Dodge is out because they have to small of a cab, although I think the front seat was the most comfy of the three. I decided against the chevy because I work with a welder who has one ( a gasser ) and while working on his welder he stepped on the bedrail and it bent! I saw it! I heard (not witnessed by me) of a fifthwheel kingpin breaking and the trailer landed square on the bedrails of a Ford dually and nothing happened to the truck or trailer. Could be just another rumor. I choose the Ford because they are the most familliar to me and also most of the people I hang with ar Ford Fans. Not that I care about any potential ribbings if I bought something else but they are very knowledgable and will be handy to have around after the warranty expires. Remeber I am planning on having this truck for 30 years or more. Chevytruckfan, I hope you are right about car karma. I have always had good luck with cars but have never owned a new vehicle in my life. Anyway, I am having my work check with their fleet dealer for a price and I have put out a request for a quote from Fordfleet.com. I live in San Diego, CA and the truck I want invoices for $35,833. Does anyone have information on how to get this Truck at or near invoice? <$500 over would be nice. I am ready to do this so any helpful hints or techniques would be appreciated.
  • jaijayjaijay Member Posts: 162
    A year ago my wife and I decided to ditch the popup trailer and purchase a 5th wheel. This would be our first "real" trailer. However instead of purchasing something on the small side, we shot the wad and went with a 36 foot Montana. For something this large it was obvious our 1999 1500 Silverado was way out of the towing class. After pondering different vehicles we decided the 2500HD with the Duramax/Allison made the most sense. We ordered it in August of last year as soon as GM was accepting orders.
    I went with along bed extended cab, towing package and everything else that would make the truck much more enjoyable on a long haul.
    The truck arrived in January of 2001. This was our first diesel. Some friends of ours decided to do the same thing but instead of purchasing the Chevy/GMC they went with the Ford F350 SD/Powerstroke.
    When my truck arrived, my friend was anxious to see what the new Duramax was all about and to see if it lived up to its reputation. After many test drives with both trucks, the Duramax/Allison was clearly the favorite for both of us in power, ride and noise. The Ford was very loud and seemed to make more noise than get up and go. It also seemed like ordering a radio with the truck was a waste of money due to the sound out of the engine bay. Apparently he said he was getting used to it.
    Both trailers are pretty much the same weight wise. The specifics on the Montana are 2100 pin weight, 10k Vehicle Weight with a max of 14k full of supplies.
    In May we towed with the Duramax/Allison through a very hilly section of New Hampshire were the 7% and higher grades are not uncommon. The truck pulled excellent. I could not give you the exact weight of the trailer at the time but it certainly was not empty. My wife packed it as if were were going for a six month adventure so I estimate it to be well over the base weight of 10k.
    The truck tackled the hills with eagerness and certainly at 65 mph, the truck still wanted to go. Obviously, being the first big rig I have ever towed, I was not going to become the hero and do 80 mph.
    As far as stopping, the brakes on the truck work excellent and is another reason we love the HD. Obviously the trailer has its own set of brakes but when you have a load such as 10-14k, good brakes mean a lot.
    I cannot see were someone said that they dropped their 5th wheel on onto their truck bed without any damage. I know that if 2100 pounds fell onto my truck bed I certainly would expect damage to the truck and the trailer. Mind you that the closest part of the trailer rides 3 inches above the truck bed and is enough distance with that much weight to cause sever damage. This is one reason I lock the 5th wheel hitch whenever the trailer is mounted otherwise someone can easily pull the release lever when you are parked and as soon as you drive away, kaboom.
    My experience with my new HD has been a very positive one and have not experience any problems. Like Quad said, there are many rumors floating around about this and that happening to the Duramax/Allison and seem to always be generated by those that know nothing about the truck itself. I have heard it refered to as Duramax Envy. You will also hear the same folks stating that they raced a Duramax and won only to find out that their truck is modified to the gills with perfomance options or that the driver of the Durmax had no idea that there was a race going on. In other words they passed him on the hiway.
    I hope whatever truck you decide to purchase suits the job you intend it for. As for me, the D/A combination was well worth it and by far the best truck I have owned.
    I wish I could put a Duramax Allison combo in an F350
    There are a few Durmax rigs running around these parts. Unfortuneatly some of the guys I know are "talking" about maybe buying one. I'll beleive when they show it off and really beleive when they hand me the keys. Yep, lots of talk.
    Am very interested knowing how yours works out. Hopefully you'll let us know. Those that have taken test drives just rave.
    While my decision was PSD, I think any of these rigs beit Duramax, PSD, or Cummins are probably the best value for the money. Hopefully they all last us along long time without too many headaches.
    I don't know what I did with it, but somewhere in Sept issue of Motor Trend, they report there will be an all new Powerstroke Diesel, seems like it said 305-320 hp, 540 ft/lbs. Someone can correct me on this.
    Looks to me, from reading posts at http://www.thedieselpage.com , that most Dmax owners are happy, and it seems generally problem free. A few complaints here and there, but nothing you could call pervasive.
    I don't work mine that hard. So it may not be the first to show problems. Mine also is only a regular cab, with the much less popular ZF 6-spd manual. If I can keep my foot out of it, it returns 23 mpg. Worst tank came during fast highway running, 75-80 where it returned 18.5 mpg. Some guys report only 10 or 11 when towing big trailers. My friend has a LT 2500HD Dmax/Allison CC, and tows a big trailer. He's only getting about 10.5, but he drives 85 with it.
    http://home.mho.net/motronix/graphics/toybig.jpg
    I have driven the PSD and Super Duty. I could be happy with any of them. I like the visibility in the SD. Of course...I love the Chevy the best!
    Thanks for the pic. Looks like some mighty nice country. Obviously you know how to enjoy it too.
    Where abouts is that?
    That is the Texas Creek campground on the Arkansas River between Cotapaxi and Parkdale, in Colorado.
    I just wanted to re-affirm where I got my information on the Duramax Diesel and the loose torque converter bolts as they were found on several trucks. That was in the member area of the dieselpage.com and a Canadian Dealer gives his updates of any related problems. This is his repair facility talking and it is very informative.
    As far as the electronic's of the Allison transmission are concerned, one did get stuck in low gear and had to be towed to the dealer right here in Spokane. This may have been an isolated situation as I have not heard of this again.
    I just talked to a couple who returned from a 7500 mile trip through Alaska pulling a 10,000 Travel trailer with no problems. They had a total of 15 k on their truck with the Duramax and Allison transmission.
    I hope this package holds up as I have stated previously because I am contemplating a purchase within this next year and the Chevy/GMC with the Duramax is my leading choice at this time.
    Thanks, Joe
    Well I just ordered a 2002 F350 4X4 CC LB Diesel. Ford is say 8-10 weeks for delivery. I sure hope it doesn't take that long. I got it for $500 over invoice. I think that is pretty good for here in San Diego, CA. Anybody with info on what I can expect let me know. Also, what info can I get when they give me a vin number. I would like to take this opportunity to thank all of you for your advice and insight. It has been very helpful and entertaining. I look forward to sharing my experinces with you in the future.
  • pipesmokerpipesmoker Member Posts: 23
    Hey, Bobsquatch: Go to the Townhall section titled: "Ford 2001 Heavy Duty F-250". I had some of your questions. A reader provided excellent response to the VIN question.
    You'll find where I ordered a F-250 V-10 4x4 Super Duty on 8-02-01 and I picked up the truck on Friday, 9-14-01. The truck was actually delivered to the dealer on Monday, 9-10-01.
    Good look with your F-350 truck.
    pipesmoker - Dothan, Alabama
    Glad to hear you ordered your new truck. Best of luck, and I hope it works out well for you.
    -Eric
    I found the information you mentioned on the VIN and found out something that bothers me. Ford has 2 plants that make my truck. One is in Kentucky and the other is in Mexico. What is with that? Does anyone know if I can specify to have my truck built in the states? I love Mexico(great fishing) but I pay taxes here and want to support union jobs plus I have much more confidence in U.S. build quality. Any info would be appreciated.
  • jcmdiejcmdie Member Posts: 594
    I've heard the same complaint many times and the manufacturer reserves the right to pick where its manufactured, usually based on workload and available components. The only thing that you can do is refuse the truck when it comes in if "not to your liking".
    Hey Bobsquatch, I guess I got lucky, thank God my truck was built in the Kentucky plant!!!
    Loving my 2002 F-250. I'm already adding options.
  • badrammanbadramman Member Posts: 61
    I hate to be the one to burst the bubble. But all 3 companies put out excellent diesels. The market is so hot right now that if they were as different as y'all are sayin' they are, a manufacture would be out of business!
    So close your eyes and point your finger. Which one you're pointing at, buy it!
    I think you are misunderstanding the point. We just happened to buy Fords and the only two places Ford diesels are made is Kentucky and Mexico. I want mine built here in the good ole USA particularly in light of september 11th I want every dime I spend staying in the US helping US families and paying US taxes. I just read somwhere that the Mexico plant only made six hundred and something trucks this year and Kentucky made the rest. Theres not much you can do about where your truck comes from and aside from the reasons I listed the trucks from mexico are the same. So if yours happens to be one of the 600+ from there dont worry about it. I agree with you though Badramman, I do not think you can go wrong with any of the diesels out there. If you have a need all three make a heck of an oil burner to fill it.
    Any word on the new truck? Started to order your accessories yet? Keep us up to date.
    -Eric
    My dealer emailed me today and I will pick it up in the morning. So far I am thinking a spray in bedliner, mild lift and tires and a bed cap
  • wpalkowskiwpalkowski Member Posts: 493
    Enjoy! Just be sure to check it over real good before you drive it home. Dealer's are real attentive to your requests when you've still got the money in your pocket. Afterwards they're just not quite as motivated.
    Here's a link to a checklist of things to examine before you accept your vehicle.
    http://www.ford-diesel.com/faq/1999faq/General-NVC.htm
    My dealer's jaw dropped when I showed up with an page checklist.
    Good luck with your new rig. Your face is gonna be sore tonight from smiling too much.
    Thanks for all the info. Every one has been great but you particularly. Thanks again.
    Glad to help!! I've got the same truck except as a V10. Had it for almost 8 months and still smile every time I see it in the driveway!
