Chevy 1500hd 4x4 leans to the left (does not sit level)
                    If you look at my truck from the back the whole truck leans to the left.  The right side of the truck is at least 1" higher than the left side.  Has anyone seen this before?
The gas tank is on the left (drivers) side. That will add quite a bit of weight
if thats not it it could be the torsion bars need adjusting.
Ryan
The difference side to side in my case is about 3/4 inch. The dealer says the factory spec. is < 1/2 inch with a full tank of gas.
I checked 3 other new trucks on the dealer's lot. 2 of 3 were perfect, the third was lower by 1/2 inch on the left side.
Please let me know if your dealer finds the cause.
Barry
Barry
-- Don
-Eric
Truck fix update:
Today, with the dealers approval, I had a local spring shop tweak the left rear spring, to add a little more lift.
The spring shop told me that this problem is fairly common, and not just with GM. Dodge, Ford, and GM all mount the gas tanks on one side, and the extra 2-300 lbs, (depending on tank capacity), causes some body lean.
When upgrading springs for customers, this shop normally puts a little more curve in the tank side spring to compensate for the difference in load.
In any event, after I got the truck back from the spring shop it is better; (now only 1/2 inch low on the left with full tank). I would estimate that it should be nearly level with the tank empty.
I'm going to talk to the spring shop again tomorrow, to see if they can get rid of the last 1/2 inch. If not, I guess it's back to the dealer.
I'll keep you posted.
-Eric
Ok, looks like we have determined that 2WDs have coils, and 4WDs have torsion bars. (Stobar's truck is also 2WD) With that behind us, my point was that:
Yes, I have seen new GM pickups that have a leaning problem, and since we're really not sure what's causing the problem, and it appears to be present on both 2WD and 4WD models, let's share info, and maybe we can find a solution that can help out all concerned.
I also don't feel that adjusting the torsion bars 1 to 2 inches is a solution, only a band-aid...
Let me know what you guys find out. Thanks.
-Eric
Sorry about the last post, I was kinda grumpy...
-- Don
-- Don
The left of the bed is now about 1/4 inch low, with a full tank, and about 1/4 inch high when the tank is empty.
I know this is not a perfect solution, but if you think about it, it only makes sense, that the left spring needs to be stiffer, to support the extra weight of the fuel tank.
The only other solution, would be to install fuel tanks on both sides of the truck, to balance the load.
Any other opinions on this solution?
Thanks for the input on your truck. I just received my call back from Chevrolet Customer Assistance Center. I am going to take the truck in one more time. Since they noticed the driveshaft was sitting "cockeyed" and the transmission was at a tilt, I am going to hold off on informing them of your fix. Who knows, I may have worse problems. I will let you all know what I find out. And as far as the comment about the 2001's not having torsion bars, I'm certain the mechanic was talking about 2WD not 4WD. Sorry for the confusion.
Barry
