Removing Wax from windows
My brother in law washed my car the other day and he used a towel that was used to wax the car (carnauba wax) to wipe the windows and I have a yellowish haze in my windows. I tried alcohol and windex but the haze is still there and is really annoying. How do you remove this? Please help!
TRON
I have heard that if you have a "steamer" such as people use for steaming their curtains to take out the wrinkles...that the steamer will work...I have not tried it and do not what the results would be. I am sure someone reading theses posts can help us.
I hope someone reading these posts has a solution rather than the car wash.
TRON
I went to one of those brushless {shammy type strips flopping back and forth}car washes, however; I believe any good carwash will suffice.
I have also been getting a slight wax residue on the windows from my California Duster { I have to be a litle more careful and stay away from the glass area ]} as I believe the duster is wax impregnated to help lift the dust off the paint.
UNWAX-IT TRON
I'm not about to go the Zaino v Zymol conversation, but I've always used The Wax Shop's "Super Glaze". Awesome, stuff, comes off with NO effort (comparatively) and you can be sloppy around weatherstripping and it comes right off. I use it on my side and rear glass and it adds a nice shine to my older truck's glass.
i find that it works excellent for me.
If the wax still won't come off, use SOS pads.
Be careful with the windshield as some are coated with a UV protector and can easily scratch. To test, use the steel wool in an inconspicuous spot and look at the area from various angles to determine scratching.
FWIW, I've used the steel wool trick on all kinds windows and mirrors both on the car and at home. I've also used polishing compound watered down with either a rag or steel wool to remove crusted-on dirt residue from house windows. It worked great. Don't be afraid to experiment a little.
Removing wax from windows or your car's painted surfaces -
Tip number one:
Go to an automotive paint store, PPG makes Ditzler wax and grease remover. This is what a paint and body shop use to wipe down the car just before they are going to paint the surface. It removes all traces of wax and grease and fingerprints ect. If they don't have this exact brand, any wax and grease remover they sell for auto painting will do. I've used this before I wax a car. Wipe it on the car with a clean rag or paper towl soaked with the stuff. It evaporates and does not leave a residue. (I painted a couple of cars and used this and I know this stuff works)
This stuff is great for removing grease from clothes and I've even used it to remove gum from clothes. It is a clear liquid and has some odor. I've had a gallon of this stuff for years and it comes in handy for all kinds of uses. Today I used it to wipe down the area of my son's race bike to put the numbers on and it makes the numbers stick really well and is good to remove it too.
The second tip: To clean water spots off ANY color car or truck and to get the windows absolutely spotless inside and out. Buy a gallon of vinegar. Soak a paper towl with the vinegar and wipe over the window and then take another paper towl and wipe till it's gone. Don't do this with the windows hot in the sun, it evaporates and its too hot.
Follow these two steps and your baby will look better than new. Bade..Bade..Bade that's all folks!!
Naptha should do it if you don't have a safety solvent handy.
You could get a Prep-Sol solvent at a paint/body supply store, but if not, just use lighter fluid, then wash with a strong soapy solution, followed by glass cleaner.
Other than that, buff it off with a very mild compound, followed by glass cleaner or rubbing alcohol.
Rubbing alcohol (IPA) will not do a good job of breaking it off as the resin system of the product is made to withstand washer fluid which has a high concentration of IPA."
(The above quote was by Ron Ketcham, Director of Sales & Technical Services of Valugard)
"I would definitely recommend you remove the wax buildup on your paint. Just use Liquid Dawn (hand dishwashing liquid) as a car wash. It has a high alkaline content which cuts right thru carnauba wax, paraffin, silicone oils, etc. This will get your paint finish squeeky clean and wax free.
I don't advise making a habit of washing your car with Dawn. But for this scenario it's fine. High alkaline products like Dawn are tough on polishes. It will never harm the paint finish though. A car wash is made specifically to clean without removing durable polishes"
I tried everything and finally found "No Touch Auto Glass Stripper".
My car I used it on is a 92 and the windshield was "baked"in car wash wax when I bought it. Most is gone by now.
