1990 honda accord ex-r does not start after parking 1 hour on a hot day
                    after driving the car and parking it for more then
1 hour on a very hot sunny day, I cannot start
the car.
The starter is very good and my gas tank is half full.After 10 minutes of trying, I left the car
for half hour and tried again and then it started immediately.
I also checked if there was pressure in the gas
tank, but there was no pressure build up.
Has anyone had this problem and how was it solved?
the car.
On modern ignition systems, if the voltage is just a bit too low, the coil may not fire. And heat might affect the battery's output.
Anyway, it's a simple experiment and would prove something conclusively I think.
My Alfa did the exact same thing and that's what fixed it.
