Suspension ALignment
I have a 2001 Passat GLS 5M with 6000 miles. It has been aligned twice by dealer. I just changed the tires from the OEM Continentals to Michelins Pilots.....much better but I still find it drifting to the right, favoring the right side and changing.
Has any one had similar exdperiences ? Otherwise I love the car
A real alignment places everything at the exact center of the range with devations of no more than 0.2 degrees side to side and a perfect 0.000 degree thrust angle.....this is extremely difficult to achieve and the time required [maybe parts replacement]. For warranty purposes they want wide tolerances so they don't have to pay!
A perfect alignment assumes a perfect road unfortunately roads have crowns and camber to drain water [drift from the high to low side--], heavy trucks make ruts in lanes [dartiness] many designs favor a drift to the right as a safety measure in left hand drive cars to avoid inattention and crossing the medium with a head on collision.
If you post all the numbers from the alignment we can better analyse!
Took it to a good independant. He said that alignment was in spec, but a big difference between front right and front left specs.
Note there is only toe in/out adjustment on many cars - when you pay for an alignment you get a toe adjust.
This indep tech cut a small slot in the left strut hanger and that cured it - $59 for align and $30 for the slot cutting. Car drive straight and actually ignores the crown (drive like a Honda).
Your dealer is jerking you around - go elsewhere.
One problem with all this is that one good smack on a pothole and an afternoon's good alignment work can go down the drain.
Alignment article
Tell them to try again.
Harry
Harry
