Honda Odysey - Service Light
ducphanducphan Member Posts: 8
edited March 2014 in Honda
If you know how to reset the service light for a 2000 Honday Odysey Van, please tell me.
  • Is it the oil change light (usually red) or service engine light (usually amber)?
    If it is the amber one, there is a problem and you will need to have the trouble codes pulled to retreive the information that will help guide you to the problem.
  • self_mechanicself_mechanic Member Posts: 95
    Page 64 in the owner's manual tell you how to reset the light. Basically,
    (1) turn off the engine.
    (2)Press and hold the select/reset button in the instrument panel, then turn the ignition switch ON (II).
    (3)Hold the button for about 10 second, until the indicator resets.
    That should take care of it.
  • ducphanducphan Member Posts: 8
    Thanks "self_mechanic." I will reset the service light not check engine light tonight.
    PS. These are the same instruction for resetting new 2001 Volvo S60 cars.
