6.5 injector pumps
we have now replaced our second injector pump on our ambulance, this time it failed while we were doing cpr on a patient. any body have any simular experiences. Also have a ford 7.2 liter
on a ambulance chassie that throws v-belts at any given time for says don't worry they were designed to have one v-belt run 165 amp alternatorand anda vacum pump!? go figure that one out.
You should get about 100-120k on an injector pump, since it is an ambulance I figure you get lots of miles on it? If you didn't get that much then the rebuilt pump had some sort of problem.
www.thedieselpage.com has suppliers listed that lots of members have dealt with, you should be able to get a good one.
I've never had a "belt thrower" but that would seem to be a simple problem to isolate and solve, especially if it is only one belt that does it. There can only be a few reasons I see to cause that. Misalignment of one of the things it is turning, wrong pully on a device it is turning, wrong belt, wrong tension on the belt, or something in one of the devices being turned beginning to fail, perhaps causing intermittent "freezing".
