C.V. Joint replacement or Entire Axle
                    Curious if a faulty right front CV joint on a 94 Mazda Protege is grounds for replacing the entire front axle?  One mechanic is trying to convince me on this...  Am I being scamed?
In all cases they said I didn't need to replace the Axle. It has to be more to replace the Axel because the boots then need to be replaced and repacked as part of the repair.
If your boot has been cracked for a while, and dirt has gotten into it, then it probably should be replaced.
Problem with rebuilders is that they often rebuild similar parts from piles of separated parts...in other words, you don't necessarily get your original parts rebuilt. So a piece from one car goes to a piece from another, and that can lead to problems sometimes. And then of course there is the firm's quality control standards, and workers' skill level and training.
I feel sure you did the right thing, csandste, but I also would like to hear details of some actual experience with the split boots.
