98 ford ranger electical problem
battery drains when headlights on in about 15 minutes while engine is running. The problem has been traced this far after a new alternatior and battery have been added/replaced. the wiring from the alternator and battery have been checked and nothing else is running except the clock on the radio. aside from the required things like the fuel pump etc. the battery doesnt drain while off, or while on without headlights. This has led me to think the problem is in either the computer for the vechile or a wiring defect some place any suggestions before my scheduled trip on the 30th at the garage???
reply to either list or johnnyxxl@yahoo.com
I'd have to check, but I think you have an external regulator on your vehicle, if so, the regulator may not be working properly.
Did they check to see that the alternaotr or charging system is working properly with a load?
Sounds to me that whoever is working on it is lost. May want to find a qualified person to work on it.
johnnyxxl,
shadetree mechanic
Meaning, with the headlights on, what is the alternator putting out?
Did you replace the alternator yourself?
If you did, was the battery disconnected before you installed the alternator. Some may think this is a dumb question, but I've seen many people try and replace an alternator without disconnecting the battery, only to fry the diodes in the new alternator.
How is the alternator being tested? Is there voltage to the signal wire on the alternator?
If the alternator doesn't sense voltage to the signal wire, it won't charge.
johnnyxxl
shadetree mechanic.
In orcer to find out, you will need to find out how much the lights are pulling from the battery.Try disconnecting the headlights bulbs, then start the vehicle and turn on the headlight switch, does it still drain the battery?
If it does, you eliminated the headlights bulbs as the problem. Then remove the tailight bulbs and reconnect the headlight bulbs and retest.
hopefully you can see the direction of this and test until you locate the problem component.
Godd luck.
now I feel stupid.
he found the problem with a circut tester with like 12 feet of wire on it. if I could have tested that long a circut maybe I would have found the circut with the problem.lol
well the guy was nice bout it 2 hours and a simple problem 20 not bad
I have a 1988 Cadillac Brougham that only has 74,000 miles on it. It drives like a dream, but the alternator light glows faintly when I'm driving it, and the battery leaks down if it is parked very long. The alternator and voltage regulator have been checked and found to be all right, but I notice when I pull the headlights on the digital clock on the radio dims, so I suspect it is in that circuit. When the weather gets cooler I'm going to see if I can find it and fix it. If not I'll resort to my favorite independent mechanic.
Don't know who/how checked it, but I bet you have a bad alternator.
Why mess around with it when you could have a dead battery at any time because of this?
