Oldsmobile Aurora Owners: Meet the Members
124»
  • 99aurora99aurora Member Posts: 1
    Hi all.....
    On my 3rd Aurora ...the present one is a 99 all option version in the lumenicent white or pearl white ...honestly I dont know what they officially call it...but Its the color ive always wanted although Im not sure Ive ever seen a detailed one in any color that I didnt like...
    99Aurora
  • javidoggjavidogg Member Posts: 366
    Yup it's called Pearl White, on your 3rd one, not bad.
    Good luck with your Aurora
    Javi
  • phil95phil95 Member Posts: 30
    Hi
    I'm phil95 I have the same car and live in the same city. I too scour these messages.
    I have a good car some little issues so far. like the temp control on the passenger side otherwise the car is like new. loaded every option but the winter warmer. I'm alway in need of advice currently I'm looking to change ant- freeze not power flush. just drain the zerex and add the dex-cool. Still looking for the radiator petcock. which I assume is uner that plastic cover. and put in a new battery if I can firgure out the right one.
    Phil
    Hi Henri,
    we have the exact same car. see mine at http://www.carspace.com/phil95/?50@@.59a82af4
    Phil
  • blp63blp63 Member Posts: 1
    I have a 2002 Aurora and have a whine coming through the speakers even when radio off. We have checked several grounds and the amp. When amp unplugged sound goes away but that also kills the speakers. I read some comments that it maybe caused by bad plug wires. These aurora's (2001-2003) do not have wires only the coils. Could this be the problem and has anyone else found a solution ?? Also some of the small light bulbs have burnt out in heated seat switch, steering wheel volume switch. Can the bulbs be replaced or does the whole switch need to be changed??
  • mstonimstoni Member Posts: 1
    Hello everyone hows it going. Well I just bought my first car about 3 months ago and it was a 95 olds aurora v8. Yes my car is kind of old but it has the look, feel , and technology of a brand new car. When I first saw my baby I fell in love with her. Right now I am in the possess of giving her a little face lift and I am open to suggestions. Yes I have had a couple of issues with her but she is an older car and she has a few little tweaks but shes still my baby. I was excited to find that so many ppl love there auroras and being a new owner i consider myself lucky to have found a group that knows so much about my newborn.
    Well I do look forward to receiving different idea for her face lift and other repair responses from any and all.
  • pegasusthunderpegasusthunder Member Posts: 13
    Hey there!!
    Glad you love your Aurora. Mine is also a 95. I have had some problems with it, but I still love it. She runs great now.
    What I did to mine that I have not seen on any Aurora's is put a spoiler on her. That made her look so sporty and cool. I also put some decals on the hood. Some cool skulls. That made her look "bad!!!". I hope that is some ideas for ya. But the spoiler really does something. Good luck fellow Aurorian!!
  • qsmithpqsmithp Member Posts: 2
    hello,everyone i have a 2001 4.0 and the oil pressure comes on when its 55degrees or warmer outside and only after the car has been driven for 30-40 minutes. the oil level is correct and the engine does not knock or tap, and the funny thing is that this never happens when its 55degress and colder,could someone please direct me in the right direction ,very confused
  • tennbobtennbob Member Posts: 2
    I have a 2001 Aurora. I have been having a problem with the interior lights circuit blowing the 10 amp fuss under the back seat. Finally have gotten some relief by putting a ciruit breaker in place of the fuss. The light have not gone out since. The fuss used to blow every once in a while. Dealer and mechanic tried looking for a shorted wire but never have found anything. Any suggestions?
    TennBob
  • antiquediyerantiquediyer Member Posts: 2
    Thanks to all of you for the great advice and tips on the repairs for the Auroras. My '98 Aurora is starting to be very expensive to own without a repair warranty (8 new injectors, Disk brake rotor problems, new radiator and now A/C problems).
    My mechanic said that I have a minute leak in the A/C evaporator on my '98 Olds Aurora. Replacement of the evaporator and dryer will cost $700 with 8 hours labor for removal and replacement of the dash.
    The interior of the car and the dash are in mint condition and I am concerned that the mechanic (non-GM) will break or damage the dash and or parts inside of the dash. How do I remove/replace the dash to save time on the labor costs for this repair?
  • chackneychackney Member Posts: 5
    Did you ever figure out what was going on with your oil pressure message? I have a 2001 3.5 and am having a problem with this "Oil Pressure Low" message coming on. The oil is clean, just had it changed. The oil level is correct and there is no knock or tapping noise. It appears to be running great. But, I keep geting that annoying message. Any thoughts?
    I have a 2001 Aurora with the 3.5 engine and am having a problem with the "Oil Pressure Low" message coming on. The oil is clean, just had it changed. The oil level is correct and there is no knock or tapping noise. The engine appears to be running great. But, I keep geting that annoying message. Any thoughts?
  • dawnt1dawnt1 Member Posts: 2
    I GUESS I AM A GOOF BALL . ALL I WANNA DO IS PUT UP A QUESTION ABOUT A MAJOR PROBLEM I HAVE W/ MY 01 AURORA AND I CANT FIGURE IT OUT LOL. CAN YOU PLEASE HELP ME
    I'll help if I can. What kind of a problem are you having?
  • dano853dano853 Member Posts: 17
    I'm Dano. I have a dark green 95 with the sunroof and I LOVE to drive. I've always been an OLDS guy and my favorite was the '67 toronado (I've had 2).
    It must have been late 1994 and I lived in Largo FL. I had recently finished restoring my driver, a 2 tone 79 Grand Prix with T tops, and was heading back to the shop from lunch one afternoon, when I pulled up next to this White, almost Pearl colored car at a stop light. I had never seen anything like it... because there WAS nothing like it. This was a sedan? I HATED sedans. How could this sporty, beautiful thing have foor doors? The curves, The wide stance, The wheels. And something about the tail lights reminded me of ... what was it? I searched for a Logo as I inched towards the intersection until I saw just this silver scribble on the front of this fluid sensuous hood. What IS that? This was about the most striking car I had ever seen. I loved the '66 Vette and '72 Citroen SM and my old Toronado from years past, but this car was NEW. Like Ice cream just starting to melt. I talked about it the rest of the day.
    I don't remember when I found out that it was an Olds, but I remember thinking "I should have known". I think thats when I made the connection between the tail lights of the Aurora and my old 67 Toronado. The back ends were definately related. I laugh now thinking there was no way for me to know, poor as i was, that in 5 years I would own one..... 2 B continued.
  • auroraexpert12auroraexpert12 Member Posts: 2
    hey i know that im replying to your post a few years to late since you have probably bought a new car or figured out the problem, but when it comes to auroras i know just about everything. now ive had multiple problem with the computer notifying me about certain things that have been puzzling. and well the computer sensors can be very faulty sometimes. so a new sensor for your oilpressure gauge may do the trick and fix your problem, thats usually what it ends up being.
