TOWING PROBLEM
                    Hi all,
I have a 97 Dodge 3500 diesel with a 5sp trans. when I hook up my car transport the truck sometimes starts to bounce, it feels like if you step on and take your foot off the gas real quick and keep doing it over and over while driving down the road. I have noticed that a small bump in the road will set it off. The trailer is a 5th wheel/goose neck, it weighs 7000ibs but it doesn't matter if it is loaded with 16,000ibs or empty. I have added 2 springs and a new set of shocks and checked every nut and bolt while it was on the lift. I also hooked up another trailer and it still does the same thing. It won't do it empty though. I have been using this truck for about 2 years and the problem just started and seems to be getting worse.
thanks for your input.
R......
R......
Thanks for your input though
R.....
Just another thought anyway.
R.......
It sounds like the one you drove had the same problem, but mine will not act up running empty.?
Robert
Good Luck
