ES300 97 Lexus Tires
First set of tires were Goodyear and I got 18K miles on them. I just figured they were cheaper tires so I bought Michelins. After 16K miles these tires are within 4K of needing to be replaced. I have rotated every 5K, so that's not the problem. Is anyone else experiencing this problem with the tires that are recommended for Lexus ES300s?
Many aftermarket designs have harder rubber to increase tire life at the expense of not meeting as designed specs......owners are legally responsible when the choose a harder tire.
In Europe and Japan you cannot run a tire with diminished specifications due to annual vehicle inspections.
Having said that, I think the Michelin Energy MXV4 Plus is a great all- around tire for that car. It does most everything well. A true no-brainer choice.
Others to consider are the Michelin Pilot XGTV4 for the more aggressive driver; the Pirelli P6000 Sport Veloce; Tthe Yokohama Avid V4 or the new Dunlop SP Sport A2 for good value.
Whatever you do, do not buy some El Cheapo no-name tire. Those are OK for older, inexpensive cars but a Lexus has a very sophisticated suspension that needs a top quality tire to maximize it's performance. A cheap tire negates all the engineering and development that makes your car what it is.
Hope this helps.
