Q45 will turn over but won't start
Hi all -- My car has new fuel pump, air filter, 2 new ignition modules. I really think it is some type of an electrical problem.
Car was running great. One day, I parked it for about 45 min and when I returned, it wouldn't start I had to get it towed home. I'm clueless
PLEASE HELP!?!
Thanks in advance for any help -- I really appreciate it.
PLEASE HELP!?!
Or, even better, go to Yahoo Clubs and find the Infiniti Owners Club. It's pretty much dedicated to the 1st generation Q45.
When was your last tune up, I don't know if your car has one but check the cap rotor and ignition coil, if you are not getting spark to the plug it won't start. Be careful when testing for spark 45,000 volt ain't fun!
Measure the fuel pressure after filter [34-44 psi].
When the pump was changed was the electronic pump control module checked [common failure is burned ground contact from leaving the loud worn pump in too long...eventual open circuit in module......take wire with 2 alligator clips jump pump ground to ground temporarily bypassing module. Can't leave it this way for more than 10 minutes new pump will over heat and fail.
Other things like hydrolocked from bad injectors start with pump circuit. Measure current at pump fuse [inside fuse panel] 3-6 amps depending.
The pump shuts off 10-15 seconds after key is turned on ----if no start! or engine dies.
http://clubs.yahoo.com/clubs/infinitiownersclub
All owners should have the 1000 page shop manual as the systems are very different and complex compared to run of the mill old style designs.
The 32 valve 4 cam engine is built to racing standards [interfearence valves, 6 bolt mains and bearing girdle, stainless steel exhaust headers, sodium cooled exhaust valves, etc.] and as such you have to be patience and very careful dealing with it. Most tolerances are 10 times more severe [0.0001"] beyond most shops ability to work on correctly.
After 12 years of refinement the 2002 engine barely produces 10% more torque than the orginal design with much more complexity! The 96-2001 engines were real dogs [low power].
We have over 400 old Q customers [400x 8 coils] only 1 out of 3,200 has failed in 6 years [on up to 11 year old cars] and that was caused by an oil filled spark plug well.
90-93 0wners must change chain drive tensioners and chain guides at +100k [depending on luck] or engine destruction as guides break, chain jumps time allowing valves to hit. pistons!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Knock sensors harness and sensor failure [due to overheats] are common due to sloppy maintenance...$450 worth of parts takes 6 hours to get to and change.
A 1990 design with 278 HP and 300 lb/ft from 274 cubic inches requires a little special care.
The pump has a max capacity of 33 gallons per hour while maintaining a 44 psi pressure.
The trispeed is necessary to minimize pump noise [lux car] at low speeds and extend pump life while still being able to deliver 320 HP on demand....the injector duty cycle never exceeds 60%.
Just one of the things necessary to get 100-150k out of a pump.
The system never fails unless you fail to change fuel filter every 30k and ignore the sound when the pump gets noisey from dirty gasoline!
Many expensive High Power cars used an extra cold crank injector to start the engine; Q just supplies WOT pressure and volume, much simplier and less injectors to break.
