HELP!! Need to know how to replace Belt on Cavalier 98 2.2 Engine.
I used a breaker bar with an eighteen millimeter socket on it. Don't grabe it with the bar too far down, because after you take the belt back, you won't be able to get the bar and you may not want that bar to return too far back.
I am assuming that it is the tensioneer pulley you are talking about.
"On the 2.2 engine, use a 15mm drive tool or a special belt removal tool to rotate the tensioner pulley bolt CLOCKWISE".
I don't know how difficult it is to get a tool down there though.
- a complete transmission fluid flush of the system
- fuel injection service
- replace fuel filter any suggestions if there is a good time versus a general advice that around 45-50k miles these services should be completed?
Even with a simple transmission fluid change, it should be done every 100K-150K miles. A flush is a lot better than just a regular change. Unless you have done a lot of towing with your vehicle or are experiencing problems with the tranny, I see no need for it. In my opinion, a tranny flush is a new toy on the market that service shops are trying to promote to their customers.
Maybe replace the fuel filter but injectors should be good for 44K.
