Rotten Egg-like smell coming from '96 Saab se turbo
                    Anybody...for the past couple of weeks I seem to notice a rotten-egg like smell coming from my car.  I notice it after I have been driving for about 15 minutes...especially when I park it in a garage (non open area).  The smell then goes away after about 2-3 minutes.  What gives?
Edwin
Othewise, almost certainly a catalytic issue of some kind....this is hydrogen sulfide I believe? Chemists on board?
The euro cats are designed for the lower sulphur gas. What happens it that the sulphur builds up on the cats, and it tends to dump off the sulphur en masse.
What happens chemically is that extra fuel in the exhaust gets seperated into its components by the catalytic converter, and some of the free hydrogens combine with the sulphurs to make the rotten egg molecule. This will obviously happen more than the engine is running rich. SAABs run rich when there's significant boost.
'course, it could be something else too, but it's not unusual on the euro cars, especially if you live in the southwest, because a lot of our gas comes from south america, where the sulphur content is very high.
BMW's had a few problems with the sulphur, too.
dave
If you've noticed this recently, you might want to switch brands of gas. I've noticed with BP the smell is lighter. It's stronger with Amoco, Chevron, Texaco and Quick Trip/Speedway.
Also the time of year and US region has something to do with this. The midwestern states use more gasohol than other states. Northern states get a reformulated gas as winter hits. Californis doesn't sell any gasoline. They use a "vehicular propellant" that is made of filtered spring water, sushi juice, and the liquid leftover from fresh salsa. Talk about a strange smell...........
I still think Dave is essentially correct. Saab has had issues with their ECU's. My 'sperience is that the smell is most noticeable after some spirited driving. When I drive it easy, not much stank.
I do think the smell is a combo of excess sulphur in some fuels, a cat that meets EPA regs but doesn't handle sulphur too well, an over-rich ECU programming, and some turbo-spinnin' fun on my part.
It's no big deal to me. It stinks but I can live with it.
The car runs rich under high boost because running rich is a way to stop preignition in the high pressure & heat environment of high boost. It's not an ECU problem per se.
dave
