emission failure 1991 Mazda PU
Iv just received my NJ "ASM 5015" enhanced emissions test and safety, and failed.
The following results were given.
Gas Standard Reading Result
NOx 1146 2051 Fail
HC 168 60 Pass
CO% 1.42 .56 Pass
CO2% 14.3
O2 0.6
RPM 0
The truck has a fairly recent (less than 15000 miles) "tune up" and a brand new exhust.
I would like to do this work my self as I figure it to be fairly straight forward. What I'm unsure of is what to replace. I know I could do an ERG valve, PVC valve and plugs. But what realy needs replacing? I'v also seen and noted the location of the O2 sensor on the exhast mailfold and would be willing to take a shot and it, if its required. Any suggestions??
Don
NOx 1146 2051 Fail
HC 168 60 Pass
CO% 1.42 .56 Pass
CO2% 14.3
O2 0.6
RPM 0
Don
These two items are not too expensive or troublesome, and are a good start and a good guess. It could be other things, but you can start here. Also check your spark plugs. That's another easy thing to do.
