interior repair - ceiling falling down
my 89 cavalier,like many late models has a problem with the ceiling fabric coming down and being annoying. I have tried staples because there is a hard cardboard type material above the fabric but the staples just fell out over time. I am worried about using longer more powerful staples because I do not want to puncture the roof metal(if this is possible).
Does anyone have a suggestion for fastening the interior ceiling fabric?
She was quoted at one place like $150 to fix it.
It's been my experience that those 1-piece foam headliners can be pretty unpredictable after about 7 years. That's when the one on my '80 Malibu started falling down. But then the headliner in my grandmother's '85 LeSabre, though, is just starting to let loose in a few places. Come to think of it, the '79 Newport I used to own which was 18 years old when I bought it, started to let go about 3 weeks after I bought it.
Ryan, for $150.00, I'd probably get it done, but a lot of places around here want more like $300-400! I don't know how much the junkyard would charge for something like that, but chances are a used headliner might start having the same problem. Plus, you have to bend them to get them out, which may damage an otherwise good headliner.
3M 90 is available at most hardware stores.
if you don't want to pull the headliner out, you might be able to do like some, and pull the trim off above the door and shoot some in from the side. let set up for a bit and then stick. it'd be wise to cover things up below though just in case.
Either way, there is a fair amount of work removing it, and if you have gone that far I suggest you put new cloth on.
To reupholster, buy contact cement, and foam backed cloth for the ceiling (or vinyl). Pull off the old material from the headliner while it rests on a table. Next clean the headliner with varsol ro remove as much old glue as possible. Next lay the cloth over the top of the headliner and cut the material with a few inches hanging over the edges all the way around. After cutting the cloth, roll back one side, and lightly spray the cloth (so as to not to soak through) and the foam headliner board and after it is tack dry lay the cloth down and with your hands spread it evenly. Then roll back the other side and do it the same way. The exess material around the edges you now cut so as to leave about 2 inches for bending around the edges and to be glued to the backside. To wrap the cloth around sharp corners and avoid ripples in the cloth, make a few v-cuts into the cloth on the excess portion hanging over the edges. This releases the tension in corners.
The other option is see an auto unpholsterer. They would likely recover the headliner for about $50-75, and either you remove/install or they can do this also for an extra charge.
If this sounds like too much work/cost, then remove the plastic trim along the side of the roof, clean the ceiling and spray contact cement on both surfaces "lightly", then join and put the plastic trim back in place. Working upside down will not be easy, unless its only a small area. Any overspray is easily removed with varsol.Odourless varsol works best and will not affect seat cloth, carpets, or plastics...but testing is always the best choice. I've removed gum, etc on limousine seats using varsol....works great!
Read about this in "The Tightwad Gazette" so I can't take credit, but I do know they work better than glue staples etc.
