Oil Analyst Sites.
I was wondering if you people who use oil analysis could compile a list of sites to use on the intenet. I'm willing to take the leap into analysiszm. Tony
Is that sample correct or is more information provided then just acceptable. Love their warranty program, how can one go wrong with oil analysis and 4000 mile changes. They cannot lose!!!!
I see their point, but I won't be a regular user as it is far too expensive. Plus, I'll want more detailed results if/when I go this route again. Only with actual numbered data can you track the trends properly.
Seeing that I use Redline oil and will be draining it after only around 7,000 miles, the results should be just about perfect. I guess we'll see ...
--- Bror Jace
I usually sample the OEM oil at first change which is always high in silicon (gaskets etc) and some wear metals as engine is breaking in. Takes abouot 20,000 miles for particle counts to calm down
The reason I considered doing an analysis was because of some info I read on an Amsoil jobber's site. He portrays some serious problems with a couple Redline samples as determined by analysis. You can take a look at what I'm talking about here:
http://www.guarding-our-earth.com/amsoil/red_line.shtml
Now, I know it's just one site and anyone can say anything on the 'net and some of what's out there (maybe a lot) are outright lies. What I read also goes against all the anecdotal evidence I have ... the most powerful of which is that so many serious racers swear by Redline Oil. Given that Redline is this guy's competitor and given that I'm not sure why I should be concerned by the presence of molybdenum (an excellent high-pressure wear preventative) in my motor oil, I got kind of spooked when I saw his data. It shows Redline not only not being a super-premium oil, but seemingly 'defective'.
So, I'm going to see if Titan flags anything on their report and last night I sent away for a Blackstone Labs kit. Hopefully I'll get that one in time for an oil change planned for the 8th or 9th of December. Filling 2 - 4oz bottles shouldn't be too much of a challenge.
The results should be interesting in a number of ways. Will Redline show any obvious degradation? Will the two testing companies more or less agree with each other? When I get the results I'll post them here and ya'll can see and comment.
If the Redline motor oil shows any serious degradation (TBN number, etc ...), then the 5W30 I'll be putting in my car in another week or so will probably be the last I'll buy. I'll simply switch back to Valvoline Synpower or Mobil1 for this as well as all future motors and use Redline strictly as a gear oil. Of course, I'll be sharing this data with them if it looks really bad. >;^)
My car runs very well and I know I'm not losing coolant. The car went the first 90-100,000 without needing a drop of top-off oil after an oil change but in the last 10-15,000 miles, consumption has increased to about 1 quart every 7,000 miles. I'm currently at 111,000 miles.
armtdm, I hear what you're saying about a single test not meaning much but I'm not really willing to have every sample of my oil tested ... it's just too expensive and I really don't mind changing my oil & filter twice each year. I only have 1 car to worry about, for the most part. I'm really doing this to see if there are any obvious problems with Redline's street motor oils. It's useful for me to pay $20-40 for a couple tests to give me piece of mind ... or to tell me not to pay Redline's premium prices and stick with the mass-market brands I already know work well.
I hope I'm just jumping at shadows ... but we should see soon enough.
--- Bror Jace
Personally I think RedLine is a great oil, for me too expensive and hard to get but I do use their gear oil as it performs better then Amsoil.
a good example of why this is needed is that some oils actually use silcon as a anti foam additive. so higher levels of silicon isn't always a bad thing but to know for sure, u must do more than one tests as he pointed out.
as for redline, the mos2 used is a great barrier lubricant but because of the excessive amount they use, in long extended oil drain ranges you'll find it can cause higher levels of oxidation thus depleteing the tbn faster. which i suspect was the case here since i could not see the report u were reffering to i'm haveing to guess from your statements.(they apparently pulled that page) one reason it works well for racers is they never run thier oil 3-5-or 7500 miles. they change it long before the base oil has time to be attacked by the acids and blowby gases in race engines. this one reason why what works for racers isn't a good indication that it will work for normal duration oil changes in personal cars.
bob in jville.
another oil analysis company that provides personal information about your report as well as the report and not a vague computer print out is dyson analysis.
here is the site.
http://pub27.bravenet.com/classified/show.php?usernum=2240725418&cpv=1
I remember someone else posting oil sample results on this forum over a month ago and they had an American V-8 which showed some high levels of iron, etc ... (if memory serves). I think part of the 'problem' lies with the large, US auto manufacturers. They've known for quite a while that the older V-8 engine designs are quite robust and often outlast the rest of the car. So, some mechanics have told me that they've skimped on their blocks and machining since the 1980s. While the basic V-8 design remains quite reliable, less-precise machining/castings could easily account for higher counts of particulates in the oil.
The only oil analysis my Honda Civic's gotten so far is me looking into the container I just drained the oil into and swishing it around as if I were panning for gold in the middle of some stream. I'm looking for tiny metallic flecks like I've seen in other's used oil before (sometimes heavy concentrations!) but so far, I've never seen the same in my own. >;^)
Thanks Bob, for your input. Redline goes on and on about tailoring their street and race oils differently so I'd assume they'd take moly's side effects into account when they came up with their street formulas. I guess we'll see ...
Also, it's possible someone dumped their racing oil in a street-driven car.
--- Bror Jace
You said that the vehicle had previously not used much if any oil but recently had started using some, You may want to check the plugs just to compare them to see if all look the same or if there is just one that is carbon'ed up more than the others...would let you know if you have a single issue or just normal wear. I've always figured that Bessie needed a stiffer (thicker) drink after the hurdle anyway....
I'd also agree that for the oil analysis to do ANY good it would have to get a baseline and be done routinely so one could track the performance of the oil control that is being watched....and if any warranty questions (or soon after warranty questions) came up the history of the tests would be some good (probably required) evidence if any oil questions came up, mfg'rs may say you "spiked the oil and caused some kind of damage ...)
see y'all
I thought I started to notice some consumption last winter with Valvoline Synpower 5W30 ... but it was so slight that it might have been the inaccuracy of reading the dipstick. I switched to Pennzoil dino 10W30 for 20 days (to clean it out) and then dumped that stuff. Went back to Valvoline Synpower 5W30 for a few months (4,500 miles) and the slight oil consumption was no longer in doubt ... but the car was leaving a fine oil slick on the bottom of the pan now so I couldn't tell if it was burning or leaking. I switched to Redline 10W30 in July and I have added a quart of Redline since then. The evidence of slight 'leak' dried up completely but consumption remained about the same. The oil level is currently in the middle of the two marks and if I wasn't about to change my oil in another week, I'd probably add another several ounces to bring it up to max. Just so you know, my Civic's capacity is only 4.0 quarts, 3.5 quarts for a change including the filter.
I'm really just trying to make sure that Redline is actually worth the extra money I'm spending on it. If I get some warning signs that show the oil is overdue for a change after 'only' 5 months and 7,000 miles in my motor, I'll simply switch back to something else this spring like Mobil 1 or Valvoline Synpower ... whichever I can find on sale. If consumption increases, I might abandon synthetic altogether in favor of Valvoline Max-Life for the remainder of the vehicle's life.
I'll probably only keep it another year or two max anyway. Despite the fact that the car runs flawlessly, I've had the itch for something faster for years ... >;^)
--- Bror Jace
You're right about the consumption not being bad, not bad at all really for using 5w/10w-30 especially..I was saying at that age a little thicker oil may be about due anyway, but it doesn't seem like it's a problem anyhow, just a point to ponder,,,,
You want to go faster? hey my truck goes all the way up to 60, even better downhilllllll
see y'all
Rando
Well, I changed my oil (at 5 months and 7,200 miles) and got a sample for Titan. It'll be on its way Monday. Let's see how quickly they get back to me. Not only will they send you your results in the mail, but they'll also fax them to you as well. They stipulated that I needed a sample fresh out of the pan. Since I already had their kit, this was easy to accomplish.
I wrote to Blackstone Labs 10 days ago and they are back-logged with sample test kit requests. They said I could take a sample ahead of time ... and send it to them when I received their kit, presumably some time in the near future. I was careful to use a clean container (a clean and dry vitamin bottle - no residue) and I'll be sure to shake it up well when I transfer it to Blackstone's sample bottle.
The difference between the two procedures was interesting ... and a little odd.
--- Bror Jace
Couple weeks back I forgot and put full 5 qts in and ran it to check for leaks, and realized I was slightly over full...
Looked clear on the dipstick when I checked it, but I thought I'd drain a little just to see how much overfill there really was (how much was staying in the motor even though I really let it drain until it drips no more. It holds about 1/3 of a qt in the motor it seems, and the stuff I drained into a mayo jar actually had some relatively dark amber color to it just from that 2-3 minutes of running...
You probably did a real good thing letting the oil clean up for the 20 days.
I think I'm gonna add some CD-2 detergent for the last 1000 miles of this change ...the truck has 45000 miles on it now, was using CastrolGTX before and Havoline from now on
see ya
Rando
I know these results are fairly vague and could even be described as 'dumbed-down' but they look promising nonetheless:
Car: 1995 Honda Civic DX Coupe
Engine 1.5L SOHC, 16V
Mileage: 111,204
Oil: Redline 10W30
Miles on sample: 7,230
Days on sample: July 10 - December 9
Oil weight within limits? = Yes
Water in oil? = No
Fuel in oil? = No
Anti-freeze in oil? = No
All the metals tested for were within the "Acceptable" rating: chromium, copper, iron, lead, tin, aluminum, silicon (dirt).
The other possible ratings for metals were "Borderline" and "Critical" but they didn't apply to my oil sample, thankfully.
I did finally get a test kit from Blackstone Labs. Right now, they are back logged with requests and have about a 2 1/2 week delay in shipping out the kits.
So, I've sent a sample of the same oil to Blackstone Labs for testing. It'll be interesting to see a more detailed analysis of this sample ... and see if their numbers agree with Titan's ratings.
--- Bror Jace
Mark
I got my Blackstone results in the mail on Saturday. Wow, those guys are fast. I'll type them up and post them later today or tonight but overall they're pretty good.
--- Bror Jace
Honda 1.5L 4-cyl
Redline 10W30 oil
Filtech OEM Honda filter
7,232 Mile Interval (July to December)
During the interval I used 1 quart of Redline 5W30 to top off the level. Crankcase capacity is 4.0 quarts - taking 3.5 quarts for an oil & filter change.
Notes from Blackstone: Universal averages show typical waer metals for an oil from this type engine after a routine oil run. Your oil was in use 7,232 miles, easily longer than a routine oil run for the type, (average for this type engine is 3,100 miles) and we found upper end wear normal but lead and copper, from the lower end, reading high. The sodium may show a trace or so of anti-freeze in the oil but this is not certain. This was 10W30 synthetic engine oil with no gas or moisture in it. Use 5,000 mile oil use for next sample to recheck wear and sodium. TBN was 4.5
The following are the parts-per-million readings followed by universal averages in parenthesis.
Aluminum: 3 (3)
Chromium: 1 (2)
Iron: 18 (28)
Copper: 11 (8)
Lead: 19 (5)
Tin: 1 (1)
Molybdenum: 448 (7)
Nickel: 1 (0)
Manganese: 0 (2)
Silver: 0 (0)
Titanium: 0 (0)
Vanadium: 0 (0)
Boron: 14 (17)
Silicon: 14 (17)
Sodium: 75 (28)
Calcium: 2539 (751)
Magnesium: 84 (466)
Phosphorous: 1210 (649)
Zinc: 1312 (776)
Barium: 0 (9)
Flash Point: 400
Fuel: 0.5%
Sustained viscosity @210 67.4
Antifreeze: ?%
Water: 0.0%
Insolubles: 0.5%
Obviously, Redline uses molybdenum as a high-pressure anti-wear additive even in their street oils. The same goes for the high levels of zinc and phosphorus. I'm guessing the calcium is an anti-foaming additive? Possibly the sodium as well?
I think I'm gonna back the interval down to 6,000-6,500 miles and test again using 5W30 and a Hastings filter. That's what's in the car now.
--- Bror Jace
What were the copper and lead ppm in other analysis and miles?
Interesting though on the moly, Amsoil uses almost none, redline quite a bit.
I wasn't sure what to make of their 3,100 mile remark ... but assuming you interpreted it correctly, it's VERY encouraging ... especially considering that I ran the heck out of my little car during that time interval. I take it to 5,000 rpms at least a couple times every day (usually on on-ramps) and I made a few high-speed trips to the West Point Military Academy (at least 1 hour at 85mph sustained) as well as the Thousand Islands region (450 miles in 1 day) during that time.
I think I'm gonna e-mail them about that 3,100 mile standard and see if your interpretation is correct. The differences are significant.
Does Amsoil use similar amounts of zinc and phosphorous? Do they use some other anti-wear additives?
Funny thing about the Moly. Bobistheoilguy said something about this additive making the oil deteriorate over time. I paid $10 extra for these guys to tell me that my Total Base Number (TBN) was 4.5
Um, exactly what does that mean? >;^)
--- Bror Jace
TBN is a measure of the overall ability of the oil to lubricate, "measures the alkaline reserve remaining in the crankcase lubricants to neutalize acidic by products of combustion" In synthetics the TBN initially is in the 10-13 range. the belief is that when the TBN gets down to 50% of original or falls below 2 it can no longer do its job. I don't pay the extra amt for the TBN anymore. Bob can probably explain this better.
Honestly, after 7,232 miles on my Toyota I wish that I had the numbers you got, really good compared to my averages but every engine is diffferent and mine has 140,000 now. For example, my last report was 7,530 miles, lead 42, copper 10 and iron only 5 but my lead has been running up and down for a few years now.
Mark
I will send you a copy of my report.
Mark
I had forgotten, but, just 1 month before the oil change I replaced the aluminium valve cover and put in a new gaskett.
The Universal averages are in parenthesis.
Aluminum: 14 (5)
Chromium: 2 (6)
Iron: 37 (39)
Copper: 31 (15)
Lead: 12 (9)
Tin: 1 (1)
Molybdenum: 4 (9)
Nickel: 1 (1)
Manganese: 18 (0)
Silver: 0 (0)
Titanium: 0 (0)
Vanadium: 0 (0)
Boron: 20 (21)
Silicon: 28 (12)
Sodium: 91 (190)
Calcium: 1564 (774)
Magnesium: 684 (604)
Phosphorous: 1049 (824)
Zinc: 1132 (942)
Barium: 1 (9)
Flash Point: 395
Fuel: <0.5%
Sustained viscosity @210 63.4
Antifreeze: ?%
Water: 0.0%
Insolubles: 0.5%
They added this comment. Silicon and sodium can show anti-freeze in the oil, depending on the type coolant and oil in use. If that is the source in this sample, it probably would not be enough to harm the engine. No moisture found and this oil does not appear to be moisture damaged. copper could from bronze or brass engine parts, but could be an oil additive. Alulminium, ckommon to pistons, was high, reading near three times normal. It is possible to have a contamination problem at the upper end where little gets down into the used oil. TBN was 3.5.
My questions:
Could the installation of the new Valve Cover be the cause of the increase in Aluminium and Silicon? The air filter was clean after 3,000 miles.
What is TBN, and is 3.5 good or bad?
Assuming that the copper is caused by engine wear what can be done to minimize it?
armtdm, thanks for the comments. I see that Amsoil uses more zinc and phosphorous as anti-wear additives while Redline uses a little less of those but adds molybdenum as well. The trace of moly you are getting may be from piston rings.
I e-mailed Blackstone Labs regarding the intervals. I also asked them about the TBN number. let's see how they interpret my TBN of 4.5.
--- Bror Jace
"The universal averages are based on all the samples we have run for that type of engine. If information about miles on the oil was supplied, then that is averaged as well. If you run the oil longer than average, we expect wear to read higher, though generally, iron is the only metal that will be directly proportional to miles on the oil. As you run the oil longer, we look at three things; insolubles, wear and TBN. If insolubles increase above the limits, then we suggest changing the oil and/or filtration. We don't generally worry about iron reading above average, but if the other metals (aluminum, chrome, copper, lead and tin) start to show a dramatic increase, then we'll tell you to change the oil."
On the issue of TBN, Blackstone Labs said the following:
"The TBN (Total Base Number) measures the amount of active additive left in the oil. If the TBN drops down below 2, then we'll tell you to change to the oil. In gasoline engine oil it generally starts around 8-9 and drops as the oil is used. Your reading of 4.5 is still okay, though the oil is starting to lose it's active additive."
--- Bror Jace
Conventional 7
Blended 8
Synthetic 9
I just bought a NEW 2002 Eurovan, weekender, noticed the high rpm about 3 to 3.5K during test drive on the freeway so they're spinning that engine to haul the big box. Hence maintenance is important, I want to euro to outlast me.
Hence: In my situation would you guys get testing, and at what intervals and for what purpose, expecting to save what kind of money?
Many thanks in advance
58VW
For me, I just like to keep track of the wear and establish a change interval. On the several cars I have and do use it on I have yet to spot a problem but I just like seeing it. The cost doesn't bother me nor does the cost of synthetics. I just like to go overboard. However, it has formed an opinion for me on oil filters (three best are Mobil 1, Amsoil and Pure One) air filters (only OEM work best, even better then foam) and I have some data to back those beliefs up. But, for most people that is worthless info and I understand that.
You would need a baseline, say at the first oil change but there will be some high numbers due to engien breakin. I do it once a year either at the oil change (on some cars I change oil once a year, or every other change for those I go about 7,500 between changes.
Oil analysis is trend analysis, only after getting back 2-3 samples can you starrt to form an opinion, thus, can be expensive.
WAYNE: Universal averages show typical wear metals for an oil from this type engine after 3,000-4,000 miles use. All wear in this sample matched up well with those averages except lead, which shows excessive bearing wear at 55 ppm. Silicon is also high and typically indicates poor air filtration, especially if this engine has not recently been opened for service. No fuel dilution or anti-freeze was found which would have caused the high wear. Suggest dropping back to 4,000 miles and resample. Hopefully wear will improve.
here are the results with the universal averages in paranthesis.
aluminum 4 (8)
chromium 2 (2)
iron 17 (46)
copper 6 (25)
lead 55 (20)
tin 6 (4)
molybdenum 3 (40)
nickel 1 (1)
manganese 1 (2)
silver 0 (0)
titanium 0 (0)
vanadium 0 (0)
boron 49 (42)
silicon 46 (35)
sodium 6 (26)
calcium 804 (1501)
magnesium 1339 (576)
phosphorus 582 (842)
zinc 752 (1011)
barium 0 (0)
sus viscosity@210 F 62.3 (55-61)
flashpoint 395 (>365)
fuel % <0.5 (<2.0)
antifreeze % 0.0 (0)
water % 0.0 (<0.05)
insolubles 0.4 (<0.6)
Truck had intake manifold gaskets replaced about 7,000 miles before analysis with one oil change in between which could have caused high silicon levels.
I have used Mobil 5W-30 conventional oil from the time truck was new untill about 14,000 miles when I switched to full synthetic 5W-30 Mobil 1.
One reason I don't think oil has held up well is that most of the anti-wear additives were lower than average. I will be retesting soon but with only 3,000 miles on the oil change.
I'm going to get my oil tested at my next change this spring/summer and assuming my results are similar, that'll be it for the rest of this vehicle's life. I'll stick with the same brand of oil and interval until I get rid of it.
wtd, thanks for posting your results again. Yes, if you lug your motor, I might suspect Mobil 1's reduced high-pressure wear preventatives (ZDDP) for your higher levels of lead. You might remember that I've had a problem with Mobil's decision to cut back on this stuff. I hope your next result comes in better. Keep us posted.
Oh, and silicon might be used by Mobil as an anti-foaming additive. Have you had the air filter serviced on this truck before? Your head gasket replacement is another likely cause.
--- Bror Jace
1993 Geo Prizm (Corolla)
118,000 miles
8,150 miles one oil (7 months)
40% highway driving
Amsoil 10w30
3 quart capacity
1 quart makup oil
changed filter (pure one)at beginning and after 4,000 miles
I use an Amsoil oiled-foam air filter
Aluminum: 0
Chromium: 1
Iron: 15
Copper: 9
Lead: 7
Tin: 0
Molybdenum: 8
Nickel: 0
Manganese: 0
Silver: 0
Titanium: 0
Vanadium: 0
Boron: 0
Silicon: 36********* flagged for observation
Sodium: 0
Calcium: 3214
Magnesium: 382
Phosphorous: 1157
Zinc: 1536
Barium: 0
TBN: 2.86ml
Fuel: <2
viscosity 100degree celcius: 10.1Cst
Water: Nil
Solids: 4.0% volume******flagged for observation
Infrared:
Hydroxy .057
Antiwear loss .967
Oxidation .806
Nitration 1.874
Oxidation/sulfate .000
Says to continue using and track/trend data
Company is PdMA 1-800-476-6463
They even give you a picture of the wear metal in your oil magnified 400 times
Thanks Guys, you are a wealth of infomation!
Ryan
Moly has only come back once at around your number and I don't know why, usually <1 ppm. They do not use moly for a high pressure additive so why the 8 is confusing . Red Line does though!
TBN is very low and I would be concerned. Wear metals are all excellent.
Your % of solids are extremely high indicating dirt which would correspond with the higher silicon on a car with your mileage (not from gaskets) However the iron PPM is good so not much wear if the silicon is, indeed, from dirt
By the way, Amsoil 10W30 has about 15ppm of silicon as an additive in the event you did not know this. I have this in writing from their chemist. So, subtracting the 15 your silicon count is more like17 ppm. Personally, I have tried the foam filter, my oil analysis indicated to me that the OEM filter on my Toyota did a better job of filtration then the foam for what it is worth. Plus, they eventually fall apart!
Further with a TBN under 3 (started out over 10) it has lost over 50% of its value, a key inidcator of remaining life and getting close to under 2 which most people would say is minimum. Dump the oil and change it IMHO!
Your molybdenum is up and that would suggest to me ring wear ... unless you've used some fairly exotic oil or additive in the past that had moly in it. If you had used Red Line in this test, your moly would be in the hundreds (mine was 448ppm). Add the two together though (silicon and a trace of moly) and I'd suspect ring wear from dirt getting through your foam filter. Many rings have chrome and/or moly in their metal ... but your chrome level was low. Anyway, you'd think that with using two Pure-One filters, they'd have trapped more of the metals and solids, eh?
I don't know how efficient foam filters are ... but you might want to clean and generously re-oil it ... or go back to paper for the next test.
K&N touts their oiled cotton gauze as better than either resin-impregnated paper and foam ... but you'd expect them to. I have a K&N cone filter on my car and it was on the entire time I used my Red Line oil, the sample tested above. BSL even commented that my air filtration seemed to be working well ... and it's been around 30,000 miles since I last cleaned my filter. My silicon level was 14ppm.
--- Bror Jace
My personal opinion is that Mobil had went the route of Castrol and other off the shelf synthetics and has more hydrocracked oil in it than it used to and less PAO. I have some old typical data info for Mobil 1 and their specs then were better than they are now. If my next analysis is not any better, I will think about switching oil brands and maybe going back to a regular conventional or synthetic blend.
There is no reason why I should have excessive lead levels in this truck as I have taken excellent care of it since new and have never abused it. My opinion is that the oil has not been up to the job. Before this analysis, I changed the Mobil 1 every 3,000 miles. I just did the 5,000 mile change to see if analysis would support going this long and it did not. My faith in Mobil 1 has been shaken.
I thought that as long as TBN was above 0 it would still neutralize acids. I do, however, understand your recommendation to change it due to the fact that before long the TBN will be zero. I have just changed it to the newer Amsoil formulation that say on the bottle that it exceeds the new API SL GF-3 specs. Do you guys think this new/more robust additive package would allow for a similar oil change interval of 8-9,000 miles with filter change every 3,000?
Thanks again
Ryan
goto http://www.bobistheoilguy.com and select the section called oil analysis located on the bottom left side of page.
hope you find it of use.
bob in jville.
Member STLE
Lubricant Specialist
I doubt the foam is having trouble with the winter air ... but I know very little about foam filters. Honda power equipment often uses a sparate piece of foam in front of their paper filters as a way of catching the big chunks in a cleanable piece of the element. I like this idea.
I have no info on Amsoil oils. You might want to check with armtdm or wherever you get your Amsoil from ... a jobber and if the shop/dealetr is fairly clueless, I'd e-mail Amsoil directly ... and make them accountable for the products they sell. I got into a discussion with an Amsoil user on another forum and he stated that at least one of their grades was a blend of PAO ... and an ester. But is that polyol or some other diester? Either way, I'd assume that this is their top-of-the-line oil. Who knows what their blends have in them?
Conventional wisdom is that a TBN below 2.0 is trouble and it means that your oil has lost its ability to protect your motor.
I have heard for some time that K&N air filters (oiled cotton gauze)might be sacrificing some micro-filtration efficiency for greater flow. The theory goes that this is fine for a race car that needs to be free-breathing for short periods at a time but poor for a car the owner will want to keep their engine for 100,000 or more miles.
Well, my test results show that silicion (sand) did not make it's way into my engine even over an extended drain interval. For the first time in 112,000 miles, I stuck my hand downstream of the filter into the plastic intake tube and swabbed the area. All I found was a light, fine coating of a reddish oil dust ... almost like oily talcum powder. I assume the reddish powder was a combination of ultra small dust and the red filter oil that you get with the filter as well as cleaning & recharging kits.
--- Bror Jace
