Mazda RX-8
1252628303171
  • gjm4gjm4 Member Posts: 11
    I had the flooding problem about a week ago in my RX8. The car was left out for about 2 days in cold weather (in the 20's). Tried to start it and the engine started up and ran for about 3 seconds and then stalled. On trying to start it again, the car would not start. Did not touch the gas pedal. Called Mazda road side assistance and car was towed to dealer the next day. Tow truck driver told me it was the 3rd RX8 he had towed into the dealership in last two weeks because of starting problems.
    Dealer could not initially start car either. They worked on car and eventually got it going. Here's what dealer wrote on service invoice: "Checked and found engine has spark checked plugs found them fouled removed spark plugs found fuel on plugs replaced plugs still no start flooded contacted tech line cleaned out fuel refit plugs start engine ok cleared codes and changed oil"
    Do not really know why engine flooded initially. Prior to that it was run on a cold night for a trip of about 2 miles and then shut off. This should have been long enough to warm up the engine (at least somewhat). In any event I am concerned about this starting problem for the future.
  • cheezeboycheezeboy Member Posts: 218
    Saw your other post GGuy...thanks for thinking about the horn issue...I will consult my dealer...maybe they know something about the alarm beep....
    I need some enlightenment - so you have a flooded engine. That means that one, two, or all three of the 'chambers' on the rotor has too much fuel in it, right? Then to fix it, you lay down the pedal and crank it for 10 sec; which adds more fuel, right? And the thought is that at some point the spark ignites the fuel, a big bang happens igniting all that fuel, you let up on the pedal and the computer takes over in choke mode? Which adds more fuel?.....I am ~not~ an expert on engines, so I defer to the more experienced brains here!! - just curious as to how it all works to fix the flooding by that method!!...wheee!!!....
  • qbrozenqbrozen Member Posts: 33,726
    well, this is not scientific fact, mind you, but I do understand engines fairly well, so I'll tell you what I believe happens.
    so its flooded. gas is sitting in the cylinders. In order for gas to ignite via a spark in a combustion chamber, it needs to be a mist of fuel and air. So cranking the engine with the pedal down forces the engine to run through several cycles. This effectively pushes out all that gathered gasoline that refused to ignite and fills the chamber with the fuel/air mist that will then ignite via the spark.
  • graphicguygraphicguy Member Posts: 14,098
    http://money.cnn.com/2003/11/10/pf/autos/bestcars04_mazda_rx8/ind- ex.htm
    Of course, I think the styling is great. Since that's their only complaint (minor one, at that), then the RX8 should have been #1.
  • pathstar1pathstar1 Member Posts: 1,015
    When you floor the accelerator with the engine not running, it cuts off the injectors when you try to start it. This was put in around 1989 to help with unflooding RX-7s. They kept it in the RX-8 (done differently, but same effect). It's still hard to unflood this way (takes a long time to pump the gas out), because on a rotory, you don't have a lot of compression unless the engine is spinning faster than about 1000 RPM - it only spins around 300 RPM when starting. Injecting oil into the rotor housing helps a lot to increase compession (by sealing around the apex seals) and force the unburned liquid fuel out. The common oil used is ATF, though I recommend 2 stroke oil. You have to remove a spark plug on each rotor to inject the oil, unfortunatly. If you do this, do not be alarmed by the huge cloud of smoke when the engine starts.
    The first time you press the lock button on the remote, it locks the doors. The second time you press it the horn will beep to confirm it locked the doors. Just press once. On Nissans, if you hold both "lock" and "unlock" for 2 seconds it turns the horn off. These instructions are on the back of the remote. Do the same to turn it back on. I don't think the Mazda works like that, so no help there.
    Truth is, flooring the accelerator has been the solution to a flooded engine on any car....even carburated ones.
    I've been doing it that way since the late 70s (with the cars I owned that were from the early 70s)....a tried and true method that's been around a long time.
    OK, I just read a posting on the RX-8 Forum (from a Mazda salesman no less ;-) explaining how Mazda told them to avoid flooding.
    When you move your cold car, before shutting it off, rev it to 3-4k RPM and while at that rev. shut it down. When you shut it off, the injectors stop but the engine continues to coast down, cleaning out any unburned fuel.
    This sounds like it will work fine to me (but not on a carburated car - it would make the situation worse). In all the years we've had fuel injected rotory cars I've never heard this one. Kudos to Mazda for figuring this out while all us "experienced" owners didn't. As I suspected, the RX-8 is paying dividends to those of us still running the older technology (I have a 93 RX-7).
    Thanks people for the info....I will assume that all that unburnt gas then makes it way through the exhaust, which then ends up on the ground, which, in turn, makes the eco-friendly people more upset..
    pathstar1....I was hoping I could, somehow, reduce the horn beep on the second press.....not really sure why it has the loud beep in the first place -- does this car need to make noise to attract attention? I think not!....
  • carlikercarliker Member Posts: 285
    Have you received your $500 debit card from Mazda yet? Any problems using it? I wonder how that is working out.
    Got the debit card and already spent it. I got it about 3 weeks ago. Fot the "free Maintenance" card about a week ago. I plan on using it next week for my 5K miles oil change and tire rotation.
    I called my dealer to see if the tire rotation was included on "free maintenance". He said "no", but my dealer offers free lifetime tire rotations on every new car purchase, so it's a moot point. It just so happens they offer the free tire rotations every 5K miles, so that coincides with the oil changes.
    graphic - The dealership that I got my vehicle has no such deal concerning the free lifetime tire rotation. I would have been rather angry if I found out that it wasn't covered under the 4 year free maintenance. Tire rotation IS regular maintenance. Why wouldn't that be covered? I knew they were going to do this. That is exactly what concerned me about this deal when they proposed it and why I didn't feel it was good enough to keep the vehicle.
    I understand your reasoning about tire rotations, but how much could that cost?
    Let's say the tires are good for 30K miles (considering they are high performance tires, that's about as much as you'll get from them).
    I see coupons in the paper all the time for tire rotations at $10 per. That's all of $60.
    Just putting it into perspective.
  • acf930acf930 Member Posts: 3
    Hey guys,
    I just bought my rx8 after researching and drooling over it for a year. I got it in titanium with black chaparral leather. It looks hot and drives great. This is also my first car in stick and even my first time driving in stick. The dealer told me it's one of the harder cars to learn manual in, but after practicing and driving the hell out of it, stick has become second hand in just a day. I only have 200 miles on it but i will soon tack on more. The only thing i don't like is the gas mileage. I bought this car thinking i was going to get better mileage than my explorer, but it doesn't seem like it so far. No big problems yet, except the fact that it draws too much attention on the road. This is definitely a bachelor's car.
  • suavechavosuavechavo Member Posts: 39
    Sorry if this topic has already been discussed, but,is the RX-8 selling well?
    I've been scoping them out at the local dealership near my home (Dallas) and they have like 50+ cars just sitting back there. I've been checking them out for weeks now trying to find the 197 hp models and so far I've only seen two; a red base model and a silver w/ tan leather/black cloth combo seats and touring pkg and nav. At first I thought the tan leather was factory, but then I didn't see it listed as an option on the window sticker. Very nice.
    Also anyone know if the 18" rims are a stand alone option on the 197 hp model? I've tried to build one on the Mazda site, you can only build the 238 hp model.
    Sales are better than expected for the RX8. Mazda has already re-adjusted their projections upwards based on sales in Japan, U.S. and Europe.
    MPG has been widely discussed. It's not going to be an MPG champ to begin with, but it does get better as the car gets more miles on it.
    You can't get 18" rims as a stand alone option. You have to go to at least the sport package to get them.
    I can think of many cars that would be easier to learn manual transmission operation, but once you master it, you're in for the drive of your life.
    acf930 - I found the MT in the RX-8 to be ultra smooth and simple. I don't know what that dealer you had was saying. I had a BMW Z3 before. The RX-8 was easier and a delight to shift (short easy shifts). The only problem I had was that it would occasionally get caught when I was trying to shift into fourth gear. This may have just been an isolated quirk with the vehicle I had.
    graphic - The fact that it isn't expensive to do tire rotations was my whole point. Why couldn't Mazda just cover it? I just had a feeling that the 4 year free maintenance was going to have fine print. At least you have a dealership that realizes customer satisfaction is what sells cars.
  • zoomrx8zoomrx8 Member Posts: 11
    Mazda does cover tire rotation under its free maintanence agreement. However, Mazda reccomends rotation every 7,500 miles, so they will only pay for rotation at that interval. For tires that cost $250 each and last approx 22,000 miles that rotation schedule is rediculous. My Mazda was just serviced, I was informed that since I only had 5100 miles it would be $18.00 for rotation. Of course I said ok do it. When I picked up my car the bill was $0.00.
    BY THE WAY THIS WAS NOT THE DEALER I PURCHASED THE CAR FROM.
    For south florida residents be warry of Lou Backrodt Mazda. Realy a pestilence of everything wrong in a dealership. I almost traded my Rx8 because of them. I had my car serviced at Gunther Mazda. What a difference I felt like I was the king of England the way they treated me. I would reccomend them completely.
    oh boy....I am concerned....I, too, purchased my RX8 from L. Bachrodt Mazda.....hmmm.....but I have not put on enough miles for a service yet. Zoomrx8, I hope that yours was an isolated incident. I am planning on going to this dealer for service. If not I may have to follow your lead.
    suavechavo...I have the AT model and as GGuy said, you have to get the Sports package to obtain the 18" wheels. But it's worth it!!!
    Yeah, I figured as much. I don't really like the looks of the 16"ers, so that’s why I thought I'd ask.
    I went back to the web site and I now figured out how to build a 197 hp model and it did have the 18” wheels under the sport pkg option. I do wish, however, that the 197 hp model was available w/ a 5 spd. I was reading CAR or EVO magazine @ Borders last month and they had a small article regarding the 197hp model, and it stated that a 5 spd was available in Britain, I wonder why we don't get it here?
  • golf_nutgolf_nut Member Posts: 12
    would you want the lower HP model?
    For that matter why do you want the AT?
    NO 5-speed here in the U.S. since MAzda saw no sense in offering the 197 HP in 5-speed when they already offered a better alternative with the 238HP with a 6-speed.
    Manual trannys are much more popular in Europe than they are here.
    When I bought my 8, the dealer told me that my car could possibly have 260 horsepower if I was lucky (I would still never know). He said the reason, Mazda dropped the first horsepower to 238 was because they were getting variation during testing in different cars--some cars had horsepower results as high as 260 and some were as low as 238. Since, mazda couldn't guarantee 260 in every car, they marketed at least 238 as the standard. Is this true?
  • sphinx99sphinx99 Member Posts: 776
    Sounds like a salesperson trying to sell a car.
    Yea...that sounds like some "double speak".
    The reason for the variation in HP has nothing to do with the engine. It's quite powerful and could make even more HP.
    The issue was one of catalytic converters. Mazda wanted them to last 120K miles. Mazda's tests coudln't confirm that they would last that long. So, they "detuned" the RENESIS a little bit to assure the cats would last 120K miles.
  • the_big_hthe_big_h Member Posts: 1,583
    remove the CAT!
    J/K!!!! :-D
    graphic - Did you want your tire rotation done with your oil change after the first 5000 miles? Zoomrx8 mentioned it is done free after 7500.
    Yes...my dealer offers free tire rotations every 5K miles. It's curious since the tire rotations aren't called for with the RX8 except every 7.5K miles.
  • ashutoshsmashutoshsm Member Posts: 1,007
    (I'm not a regular here, so sorry if this video has been posted already!)
    They call ... hold yer breath for this one folks ... "The RX-8 the best car they've test driven all year".
    Bear in mind that 2003 saw Top Gear test drive some pretty kick-butt cars - like the Lotus Elise, and the new Swedish Supercar with a ridiculous (more than the McLaren F1) amount of HP.
    And that Top gear is, IMnsHO, the most respectable performance testing and car review show on our dear planet.
    http://www.mazda6club.com/applejax/topgear.wmv
    Also, it macthed the track time of what (to my somewhat trained eye) seemed to be the track edition Z AND ... hope you're holding your breath again ... the MIGHTY BMW M3 SMG!
    ... I'm off to the "Real World Trade in Values" board tos ee how much my nice sub 10K mile Mazda 6i wil fetch, when I upgrade to the RX-8 this evening :)
    ashu don't play with my fragile little mind >:-O
    Well, I would rather have the 238hp model w/ the 6 spd. No doubt. But I just couldn't afford it. Every one I see is over $30K and the lesser hp models seem to be readily available @ $25K, maybe even less w/ discounts. Also, w/ Dallas traffic and my 70 mile commute, the A/T may not be too bad a choice.
  • evaddaveevaddave Member Posts: 156
    I could easily drive to the dealer to find out the answers, but then I might actually find myself driving an RX-8 home! So instead, I'll ask here.
    What happens if the front door shuts first? I realize it won't latch, but if the front door gets closed, and then the back door gets closed, does the back door dent the front door or chip its paint?
    Has anyone hauled around ice hockey equipment in the RX-8? It doesn't really matter where it fits, just as long as I can get my equipment bag and sticks *somewhere* in the car. :)
    Dave
    IIRC, the front door will NOT close if you don't close the rear door first. I think some RX-8 owner said the front door will 'bounce back' if there's no rear door to lock with.
    there is a trunk passthru over the center console in the rear seats, so sticks can pass through there I assume.
    And then you should be able to throw those gigantic hockey equipment duffel bags in the back seats if the trunk doesn't fit. But I actually think the trunk would fit a big hockey duffel bag.
  • kewl1kewl1 Member Posts: 11
    What a great video. I had not seen that one before. Thanks for posting that site.
    Sort of makes me want to head to the track....to hell with the cost of replacement tires!
    Nice video ashuto.....but I have to say, I will never drive my baby like that!.....but it's nice to know she can do that!
    and I love my AT....nothing wrong with it. Fast enough for me. If I want faster, I can ride a sportbike......well, except for the rainy days!!
    needless to say, either model is a great ride!
    Yes, the Top Gear video had the RX8 match the track times of the 350Z and (are you holding your chest big_h) the mighty M3.
    Aside from their minor quibbles with the styling (which myself and 20,000 others who have bought the car, disagree with them), they fell all over themselves about the car. They didn't like the rear tail light treatment, but I disagree with them on that point, too.
    The doors bounce back open if you try to close the front doors without first closing the rear doors. The front doors won't close if the rear doors aren't already closed.
    Can't comment on loading ski equipment in the RX8 because I've never tried. You do have a pass through that could work if loaded from the trunk. Surprisingly, I can fit an awful lot of stuff in the trunk. I wish the trunk opening was bigger, but if they did that, the styling would be all screwed up.
    how under control the RX-8 looks even during extreme powersliding maneuvers, even when he 180'd it!!!
    a high performance car that's easy to drive, very cool :-)
    ... you do mean "When they 360'd it", don't you?
    They do it at least twice! Awe-frikkin-some! So - how many of you owners have tried that yet? And if not, what's your excuse?
    Notice how he finishes the 360 and says, very genuinely honestly ... "Perfect!", with almost a hint of surprise in his voice! Yeah!
    Now if only I could decide which color RX-8 to upgrade to from my 6 ;)
  • rorrrorr Member Posts: 3,630
    Well, I've just watched the video a couple of times; excellent.
    Did anybody notice the lap times posted by the 911 turbo? Watch the video and note that when they show the lap time for the 350Z (1:31.8, same as the RX-8 and BMW M3).
    911 turbo posted a 1:31.0.......only 0.8 secs quicker than the RX-8.
    Maybe they just left the 911 in 3rd for the whole lap...
    The fact that the video showed the Porsche 911 only 0.8 secs quicker than the RX-8 shows that the test laps/timing were obviously faulty. The BMW M3 must have been carrying a half dozen 50 pound cast iron weights in the trunk as well. When other vehicles are timed, I don't see such hard launches and tire scorching as you see in the video with the RX-8. Nice video images though.
    did you ever see the timed laps of other cars done by Top Gear???
    are you being sarcastic?
    I haven't tracked what you own - your profile says Mazda.
    And I trust Top Gear to be more honest than junk like Consumer Reports and JD Powers etc
    IMnsHO - if they say its as fast as an SMG M3, I'd suggest you believe them.
    ON THAT PARTICULAR COURSE
    big difference there ashu ;-)
  • s852s852 Member Posts: 1,051
    I watched that show a few times when I was in London last year.
    The RX-8 looked good in the video.
    The production values of Top Gear is almost like a movie. Makes shows like "Motorweek" look like they were done on a home camcorder.
    Thanks big_h and GG for the responses.
    What I'm trying to figure out with the doors is the worst-case scenario. The back door latches into the body, and the front door latches into the back door, so if the back door is open, the front won't stay closed. No biggie there.
    I have here at home, one twelve-year-old girl. Being an adolescent, her brain (and her friends' brains, too) isn't always in gear, and what I'm worried about is two of them getting out the passenger side and slamming the doors shut. In the worst case, the front door meets the body just as the back door tries to shut. If this did happen, whic parts of the back door would contact which parts of the front door?
    If I were to check this out at a dealer, here's what I'd do: Open both doors, hold the front door against the body of the car, slowly close the back door to see where it made contact. I'm hoping something soft like an armrest is the first part of the back door to meet the front door. Or maybe there's a safety mechanism built in that keeps the back door from closing all the way.
    For the hockey stuff, are there any pictures anywhere that show the RX-8 with the trunk lid open? I looked through the Mazda web site for such a picture, but there was none. I checked the Edmunds Photo and Video gallery, too. Nothing with the trunk lid open.
  • dcaslindcaslin Member Posts: 4
    I did the slo-mo "worst case" door test the first day I got my car. I had a disturbing memory of a pickup truck with a rear-opening back cabin door and metal touching...
    It turns out the RX8 does a much better job of protecting itself. The interior part of the back-door touches the exterior paint area of the front door. Luckily that part of the back door is all relatively forgiving plastic. Unless you really slammed the back door on the front door, I don't think you'd do any damage. Even slamming the back door, I imagine you'd just get some scuffs.
    Has anyone actually shut the doors hard in the wrong order (and is willing to admit it)? You can blame a familiy member or friend if it makes you more willing to come forward.
  • rx8_canuckrx8_canuck Member Posts: 5
    Anyone got any good tips for storing my RX8 for the winter? I have never had a rotary engine car before, so any tips would be appreciated.
    Anyone notice that the interior of the car scratched up pretty easy...
    I have had my RX8 for four months and love it. Thought hard about returning it on the refund offer because of the dealer, but just couldn't do it because I enjoyed the car soooo much.
    Not alot of RX8 on the road in Vancouver. Better for me... I look like a rock star.
    In Vancouver? Winter? Sorry, I grew up in Vancouver. You don't have winter ;-). I'd drive it all year. If you insist, following is what I do.
    I store my RX-7 3rd gen for 6 months every winter (Edmonton).
    1. Fill fuel tank.
    2. Make sure the tires are at full pressure (perhaps highway setting from the manual - they will loose a bit of air after a few months).
    3. Change oil - oil accumulates acids, and you don't want that sitting in the engine. If you've only been driving on freshly changed oil for a few weeks, then that is fine.
    4. Remove battery, and charge it at least once a month with a good quality charger. It's not a good idea to charge the battery when it's connected to the car. Do not let the battery terminals contact/disconnect more than once when you connect or disconnect them. This can damage electronics in the car. In other words, be deliberate when disconnecting and reconnecting the battery. I use an insulator when installing the battery (a rag or plastic battery terminal protector) so it does not accidentally connect. Always disconnect the -ve terminal first when removing the battery and reconnect the -ve terminal last when installing the battery. That way if your wrench contacts the chassis there will be no spark.
    5. I put my car up on jackstands, but this is probably not really necessary. I do it so I can sweep under it and watch for leaking fluids.
    Fuel stabilizer is not necessary for storage up to about 8 months.
    Been doing it this way for 6 years now. Starts right away in the spring (after I install the battery). You will not loose any odometer readings, or upset the ECU trouble code system by removing the battery. Bonus, if you remove the battery and put it up on jackstands, anyone who wants to steal it will have to really work to drive it away.
    Thanks for the tips!
    Doesn't get cold here like the Chuck, but there is a lot of rain and sometimes snows, and don't mean to wimp out, but I would rather be riding in my forerunner. Not nearly as fun or cool, but I don't think my baby will drive nearly as good in the cold rainer slippery conditions. It is already getting a littly squirrely.
