HONEST OPINIONS: Are Toyota's Pickups Just as Good as The Big Three?
12346
  • seeligseelig Member Posts: 590
    i pointed out the wieght difference in a now closed topic, and no one seemed to believe that the weight would have a difference on the outcome. i call it denial, but then again, the 2-3 individuals that are making a circus of this topic believe all they will have to do to survive in their tundras is to avoid hitting a stationary object. what can you do or say to convince them of the obvious deficiencies and short comings of the tundra? nothing. they won't accept facts.
  • natureboy1natureboy1 Member Posts: 55
    I'm tired of arguing because we are all going to still walk away in the end with our own opinions.
    The only thing that really bothers me is some people (like obyone) who do not have the b*lls to say that the Toyota Tundra and Tacoma are good trucks (even though he really knows they are).
    I have never once said the Silverado was junk. It's not. It's a nice truck, and if I didn't buy the Tundra I would have bought a Z71 Silverado. My friends and I all drive different trucks and do you think we sit around all day criticizing each other's vehicles? No. We usually point things out that are different, things that are better on one model as opposed to another etc...
    As big of a Toyota fan as I am I can still point out my own trucks weaknesses.
    No truck is perfect. None.
    So here is what I don't like about my Tundra...
    - I wish it was just a bit bigger (just a bit longer actually).
    -I wish it had a little more room in the AccessCab (but I still don't think it is as bad as people say it is).
    -A bit bigger tires and maybe an inch larger rims.
    What do I like about my Tundra?
    - The 4.7 liter V8 is sweet and has tons of power no matter what anyone says.
    -The instrument panel is well arranged.
    -The truck rides like a luxury car
    -It will probably last forever.
    -Great looking truck.
    - Impressed people give you a nod when you approach a stop.
    Ah there are too many to list.
    What do I like about the Silverado?
    - Lots of room in the Extended Cab
    - Plenty of engine choices (and all the engines are strong).
    - Great looking truck.
    What I don't like about the Chev...
    - I don't like the instrumenation design.
    - I think the seats sit too high and are not very confortable.
    - How come it is so hard to find a Silverado with a rear sliding window?
    - Rides a bit rougher than the Tundra, but still rides good...
    There, argue all you want I'm done...
  • chevytruck_fanchevytruck_fan Member Posts: 432
    I don't think natureboy likes the silverado instrumets because he can't read the numbers on them, used to the toyota cheap gauges with no numbers.
  • eagle63eagle63 Member Posts: 599
    "The next tindra will have 4 wheel abs discs, like the Sequoia"
    -so what you're saying is that when the tundra gets 4 wheel discs it will smoke the 'rado in braking even more than it does now?
  • quadrunner500quadrunner500 Member Posts: 2,721
    You mean more than it doesn't? Could be. But you'll have to wait, and wait, and wait. It's the possibility that keeps you coming back for less truck, more buck.
    Did I forget to mention how much better abs is on curves? LOL!
    You're right, there is no point in arguing regarding a truck that isn't full sized. It isn't. Once Toyota loyalists understand this we can move on. And notice that Pluto nor you ever commented on the Tacoma's miserable one star side impact rating? You unknowingly did yourself a favor by ridding yourself of that truck. Unfortunately, Pluto still has his.
    Quad, the Toyota owners must be brainwashed into thinking that their "pumping" or their brakes is an effective way to stop. It really does concern me that we have these uneducated drivers on the road who like to pretend they have ABS by "pumping" the pedal. Scorpio's parents do the "pumping" even though they have ABS. I do hope someone educates them on how to effectively use ABS. What's even more of a concern is that Scorpio is the second owner to post this pumping pedal thing. At least Bama know better. Hopefully Pluto too.
    Good luck on this one now!!
    BTW, natureboy1, does your Tundra have ABS? Do you know how to stop your truck in a emergency situation? What's your opinion on "pumping" them ABS brakes? Be honest now.....
  • midnight_stangmidnight_stang Member Posts: 862
    I guess NHTSA is contradicting that other crash test link.
    http://www.nhtsa.gov/cars/testing/ncap/Cars/2001Pkup.html
    The only trucks I see receiving a lower score than the tundra is the S-10 and Sonoma.
    Another individual pointed out that the F-150 crash video (against the concrete barrier) wasn't so "super-duty". I guess they never took the time to figure out that Superduty's are F-250's, and can be quite a different truck.
  • abc246abc246 Member Posts: 305
    I hate this topic but am posting this so people do not pump ABS brakes.
    When you pump ABS the computer must start calculations over again and again. The only way an ABS computer knows if a wheel is sliding is by having it slow or even lock. This starts a calculation and triggers a dump valve and starts an electric pump. Once the process has started it is very effective and most systems can pulse the brakes between 10 to 30 times a second. If you pump the brakes all this must start again and the process takes time to start.
    By the way, has anyone noticed that the Silverado sometimes pulses the brakes just one or two times on moderate unloaded stops? This is the electronic brake distribution system reducing the brake pressure to the rear discs. The system is sensing the coefficient of friction by getting a feel for the surface and to an extent the amount of load on the truck. If it found no slip (such as when loaded) it would allow the higher brake pressure to remain. My Toyota used a mechanical arm valve attached to the rear axle, but the newer systems are much more effective. I believe the Tundra uses the electronic system also with ABS.
    The Silverado ABS system seems first rate. I have used it in 4 lo on ice and was very surprised at how well it works.
    So what's the deal, can the silverado out-brake the tundra or not? (we all know it out-breaks the tundra, but I'm talking about out-braking :))
    Everything I've seen says the tundra can stop faster.
    From Truck Trend:
    Braking 60-0 mph, feet
    Silverado empty: 133 ft
    Silverado #1000: 135 ft
    Tundra empty: 127 ft
    Tundra #1000: 141 ft
    lol so when braking is most important, loaded, tundra falls behind lol, who wants to bet bama's next message says something about shakerado with hyundai quality?
    He's still got to answer about misinformation he posted about engine choices.
  • tbundertbunder Member Posts: 580
    i have to admit you guys all sound like a bunch of kindergarteners arguing over the legos. i love to debate, but this is ridiculous. you guys aren't debating, you're being factually blind.
    first off: the NHTSA is a federal organization. id trust their data, and it says toyota's aren't that safe. certainly not as safe as fords or chevys.
    second: its a known fact that the tundra CANNOT keep up with any domestic full-size in hauling, towing, or passenger capabilities. one engine, one suspension, one bed. you must abide by what toyota thinks works in todays construction business or whatever the call for a heavy duty work truck.
    third: it may have the TRD off-road pkg. available to it, but read the new Four-Wheeler magazine, and find out just how lousy it is. again, they said its suspension basically sucked and was too car like. actually, they, i quote: "would not recommend for off-road driving". it also had less power and torque than the ford and chevy.
    fourth: the bottom line is this- tundra is nice. but it is like having a baby normally. you must take what god gives you. whereas the other three are like selective fertilization. GET WHATEVER THE HE77 YOU WANT! (pretty cool analogy if i do say so myself)
    fifth: with all the choices among todays big 3 truck manufacturers, the tundra just can't cut it. it just can't tow as much, haul as much, or carry as many people. there are no arguments to this information at all by you toyota boys. its all proven facts.
    conclusion: the toyota boys in japan can outfit the tundra with as many tacoma transfer cases, wheels, tires, beds, suspension systems, differentials, transmissions, and whatever else they use interchangably between the two, but one thing will always be true: they will NEVER compete with the other three trucks on the sales floor or in our society as a respected truck, nonetheless even a "full-sized" truck.
    there, the smack was just handed to you on an 8' ford bed that nearly 25% deeper than your tundra. blind consumerism- its what you toyota tundra owners must be practicing. because you did buy your tundra when there are numerous types of configurations out there on the market with more power and options, all for a lot less money. dont see a "limited" silverado do you? its cuz they dont charge you extra for all the goodies. they're included and considered standards.
    oh yeah, HAVE FUN WITH THIS ONE NOW!
    ivealwayswantedtosaythatwuzuphillbillybob
    smile, at least you can trade them in (the blind who bought tundras, and tacomas for that matter). :o)
  • diploiddiploid Member Posts: 2,286
    to see what kind of forums will pop up when Nissan brings out its full sized truck and Honda unveils its first pickup truck ever.
  • stumpy5stumpy5 Member Posts: 4
    "246 of 266 sonjaab by sc0rpi0 Nov 26, 2001 (10:41 am)
    Yes, taliban seems to like the HiLux, it seems to be serving them very well in
    the rugged conditions. I wonder how a Chevy would do as an anti-aircraft
    launching platform :)"
    What are you basing your post on as serving them very well as an anti-aircraft launching platform? Have any terrorist shot down anything other than couple of drones from the rusted out Toyotas? They are probably all ways falling thru the rusted out beds before they get a bead on bomber or fighter....:)
    And, what "rugged conditions"? Are two thousand miles paved roads tuff on Toyotass?
    Read the post 'bin Laden's ride' below that was posted a month ago....
    bin Laden's ride…
    While listening to the Sept. 20th Coast to Coast radio show, yesterday,
    the guest was Robert Young Pelton, whom has a book "The World's
    Most Dangerous Places". I watched this guys 4 wheeling expeditions
    and sole survival tips on a couple of Discovery shows.
    My ears perked up on yesterday's show when he said he camped
    right next to Bin Laden's farm in Afghanistan. He was telling of the
    methods of Bin Laden used of raising cash to build his army of thugs
    up. He used his Saudi dad's heavy construction equipment to
    cut thousands of miles of roads and then paved them. When he got
    paid from the road building, he used some of the cash to buy his
    wheels of choice for himself.
    A brand new shiny red Toyota Landcruiser. And, for his crack team
    of rocket launching thugs, he bought 1000 Toyota 4 door Hilux pickups.
    I did a googol search and got over 725 hits with bin Laden Landcruiser
    and Hilux trucks. I skimmed thru the first 100 or so and read multiple
    UN Reports of him spotted at areas of rockets launched from several
    Hiluxs, Honda Civics, and Mitsubishi micro vans. A common trend
    was that all the vehicles caught fire and burned up from each
    rocket launch, killing all the occupants!
    Stumpy---Disposable people and trucks, oh what a feeling Toyota...
  • bamatundrabamatundra Member Posts: 1,583
    Better recheck those braking numbers of yours. The June '01 issue of Truck Trend tested the Tundra loaded with 1350 lb. against the EMPTY Wimperado and found that it easily outbroke it. They ranked the Tundra "Best in Class" for 1/2 ton full size extended cab pickups.
    This same issue also found that when the whimperado with its largest available engine (5.3L) was out towed by the Tundra (and the Tundra got 3mpg better mileage while doing it). Where's the beef?
    It's a good thing that you already traded off that Lemonado of yours and took it in the shorts. (Consumer Reports ranks the wimperado as a "Used vehicle to Avoid".)
    The Whimperado has less front seat legroom than the Tundra. Edmund's said that it had "Toyota Corolla like footspace. (and they have the nerve to call it "full size"). Hmm: The Tundra comes standard with transmission and oil coolers (optional on the wimperado) Add this to the fact that you have to upgrade the suspension and tires just to put a tow hitch on it and it becomes clear that the Chev just was not built to be worked. When you do - it breaks quick. (Heck - they break quick even when they aren't worked.)
    The GMC Denial's base price it $43K. And Quad wants to compare it to the Tundra. LOL. Add the fact that it is an import - (The Denial is built in Canada) and I think I will stay with my US built Tundra.
    As much as the Chev pack would like to prop up their runt of the 1/2 ton litter - it just aint gonna happen. Even Chev realizes this - they gave it 40% less powertrain warranty than the Tundra.
    "Better recheck those braking numbers of yours. The June '01 issue of Truck Trend tested the Tundra loaded with 1350 lb. against the EMPTY Wimperado and found that it easily outbroke it. They ranked the Tundra "Best in Class" for 1/2 ton full size extended cab pickups."
    BAMA Your summary is insufficient you need to show some numbers.
    Ryan
    I have posted the date and source of the test. Anyone can check this for accuracy and see that Quad is fibbing (as usual). Good Luck on this one now!
    I stand corrected he used wimperado instead of shakerado and used runt of the litter instead of hyundai quality,
    funny enough he didn't respond to tbunder. guees you start getting phsyco like bin laden once you start driving those trucks. hey maybe bama is bin laden and wants to bash American mfg's?
    Shucknet
    "Another good point made by some people already is that tires affect braking. Toyota sends out their trucks with street tires and Chevy sends theirs out with all terrain tires."
    WELLLL - NO. They both send them out with street tires(standard). You infer that Off-road tires hurt braking performance on the street. The Truck Trend article (06/01) compared a Tundra with off-road tires to a Shakerado with street tires. The Tundra demolished the Shakerado in braking performance both loaded and unloaded. Does this mean that the Tundra with street tires would embarass the Wimperado even more?
    I hope this clears things up for you.
    the funny thing is with braking with a load (and mind you this is a very light load) the tundra gained 14 feet the silverado 6, like to see a 6000 thousand lb braking test.
    Its funny because that is all bama can cling to is braking performance everything else the tundra loses. IT must be hard driving a bin laden mobile that you always get passed in.
  • plutoniousplutonious Member Posts: 799
    make these statements about Toyota supporting the Taliban and such are out of line. Now how does Toyota know how every vehicle of theirs is going to be used?
    That's like saying Ryder rental trucks supported McVeigh and Nichols, and Boeing supported the Taliban with their 767s.
    That's the dumbest thing I've heard. Really.
    What about people who do not get the magazine
    Gotta back up your info
    Page number would be nice too
    When the Chev pack starts losing an argument, they resort to personal attacks. It just reiterates to me how WEAK the Chev 1/2 tons have become.
    Their defenders are running scared trying to change the subject to the Taliban. Sad!
    What do you thin GMs new import - the Denalis? 100% assembled in Canada. Those GM execs are getting rich by outsourcing US JOBS!
  • sc0rpi0sc0rpi0 Member Posts: 897
    Oh my, lets not get into a political arguement here. You've all seen the picture of a HiLux with afghan fighters in it in Kabul airport (think it was Kabul), it's been in the news/net a lot lately. It must be working out for afghans pretty good to use those Toyotas, since they keep using it as a part of the war effort.
    As for the hummer......alright, so you are comparing a oranges and apples. Real good. Hummer is not that great of a vehicle. Sure, it is used by the army, and it looked fun in "Broken Arrow", but that doesnt mean it's good. It's slow, it's a horrible gas guzzler, it's about.....2x or 3x as expensive as a HiLux. Yeah, it's got armor, but thats what it was designed for. HiLux on the other hand is a simple 4x4 truck.
    Rugged terrain: I guess mountains, lack of roads, and desert do not qualify as rugged terrain.
    As for the rocket launching: lets not mistake human stupidity for disposability. So they were dumb enough to launch it that way. So they paid for it. The bystanders would make sure not to do it again. Should I start drawing parallels to the driving habits of people in this country? the big US of A might just come out looking stupider than few poor Taliban fighters.
    >bama-pst.272....."does this mean the Tundra with street tires would embarass the Wimperado even more?"<
    i just want to say thanks Bama, as i did not know that the silverado was tested with all terrain tires, until you pointed this out. should make an even bigger difference if the rado had street tires eh?
    By golly, you are needed here.......
    I think it's envy, they see how Toyota trucks work in desert in worst of conditions, and still run, and well....it'd be an interesting experiment to "donate" a Chevy to Taliban as a part of sabotage effort :)
    That's good, "sabotage effort." Funny, but probably accurate at the same time.
    Put down your pom-poms and go back and READ my post. I said that for the Truck Trend test, the Tundra had off-road tires and the Wimperado had street tires. GEEEEZ!!!
    I know your upset bama driving your taliban mobile that doesn't hold but one edge over the silverado, braking. I know your idol bin laden drives them but I think it is time you got rid of the talibanmobile and got a real truck with truck with better acceleration, more towing and hauling, longer lasting, more interior room, bigger pickup box, mroe options and configurations, a actual truck interior.
    In other words get a CHevy Dodge or Ford and give up on bin laden the taliban is going down and your taliban mobile won't be so popular.
    bama bin laden sort sounds like a match to me.
    since you quote the truck trend article so much how bout a page number (was my last post invisible?)
  • ndahi12ndahi12 Member Posts: 235
    To the person that posted that the Silverado outsells the Tundra: You must surely know that Toyota's aim is to sell 100,000 units per year. That is it. Here is a quote from truck trend:
    "Toyota will have no trouble moving the 100,000 Tundras per year it can build in the new factory at this time."
    And you know what, TT was right. Toyota has met its sales figure in 2000 and as of October 2001 Toyota has sold 89,563 Tundras. They will meet the sales figure for this year as well.
    The Tundra has been the best launched Toyota ever.
    here ya go courtesy of http://www.pickuptruck.com
    Ford F-Series
    753,280+0.7% YTD
    October 2001: 102,424
    October 2000: 65,225
    Chevrolet Silverado
    591,224+16.2%YTD
    October 2001: 88,881
    October 2000: 47,956
    Dodge Ram
    287,344-12% YTD
    October 2001: 30,255
    October 2000: 31,395
    Ford Ranger
    239,768-18.7% YTD
    October 2001: 22,098
    October 2000: 19,103
    GMC Sierra
    172,329+7.7% YTD
    October 2001: 28,009
    October 2000: 13,621
    Chevrolet S-10
    140,211-26.6% YTD
    October 2001: 15,307
    October 2000: 19,502
    Toyota Tacoma
    136,647+12.3% YTD
    October 2001: 14,719
    October 2000: 11,517
    Dodge Dakota
    130,691-14% YTD
    October 2001: 15,033
    October 2000: 14,179
    Toyota Tundra
    89,563+4.9% YTD
    October 2001: 13,281
    October 2000: 7,837
    wow the silverado sales were up 16.2% over oct 00
    In their review of the best truck on the road and off, Truck Trend compared the Silverado, F150, Dodge and Tundra. Of course the three other trucks had the 5.3, 5.4 and 5.9 engines while the Tundra had the 4.7. Still the Tundra won the comparo. Here is a quote:
    "And the Winner is...
    Which to pick? In terms of overall performance and sophistication--on road and off--we have to say Tundra. If you need the proverbial "just a skosh more room," and are willing to trade a bit of the Toyota’s polish for it, it’s hard to beat the Silverado. After that, it’s Ford’s F-150 in third place, and the aging-but-still-popular Dodge Ram in fourth."
    Here are the numbers:
    ------ Tundra ----- Silverado
    0-60 --- 8.06 ----- 7.79
    Load --- 9.86 ----- 9.34
    1/4 ---- 16.16 ---- 15.83
    Load --- 17.34 ---- 16.88
    60-0 --- 125 ------ 141
    Load --- 139 ------ 147
    Slalom - 56.8 ----- 57.6
    In this test the Silverado had the optional 5.3 liter engine and the Tundra had the 4.7 liter engien. The Tundra lost the acceleration and slalom. It won the empty and loaded braking unlike those who said otherwise. Please stop spreading misinformation.
    I'm guessing the 0% financing has quite a bit to do with that. You see a huge spike in the silverado, Sierra, Tundra and the F150 for october 01 vs. october 00. (guess the financing didn't help the ram much though)
    I'm surpised by the under-performance of the s-10, dakota and ranger, while the tacoma out-performed without any pricing or financing incentives.
    those figures are pretty close. I sure would love the results if the comparo used Ford's 4.6 and Chevy's 4.8, but no way. It would have been a slaughter (in Toyota's favor, that is)!
    I think I could sacrifice .27 seconds going 0 to 60 to get a truck that doesn't fold like a pancake in an accident. I sure liked natureboy's pictures. Worth a 1000 words.
    So much for the advantage of having 4 wheel disk brakes, at least in this case. That shows how superior *snort* Chevy engineering is - disks not stopping faster than drums.
    In the future, Toyota will probably offer a 5.3L V8 or an engine roughly that size. When that happens, the Chevy boys will scrap their 5.3 and then use a Duramax diesel for comparison.
    Truly pitiful and pathetic.
    The S-10 doesnt seem to be a popular truck anymore, there are better choices. However, Xtreme version sounds fun, but thats more of a S-Runner type vehicle. I'd not drive an S10 if one was given to me free, I've had enough trouble with the previous one.
    Now you are being totally stupid and insulting.
    Perhaps you do not fly Boeing airplanes these days, because Boeing is an Al-Queda (Not Taliban, get your facts straight by not watching CNN) airplane company?
    It's actually interesting to see how the Big3 are singing the patriotic song because they are losing money in this economy. GM with it's 0% really gave the Ford and Chevy a big one, since Chevy and Ford are now losing money with the 0% deals (but they can't ditch it because GM will grab the market share from them), and how Toyota is still going ahead as it always were. I've never seen Tacoma ads on tv before, in the last year, at least. Looks like the big3 need to give incentives just to get the people to buy their cars....like slipping drugs into the beer....just can't get it any other way :)
    are you not seeing the 0% interest commercials on tv right now on the-TUNDRA. you know, the one where a japanese company is playing "saved by zero", an american classic rock song. also, just saw an ad for the tacoma over the weekend. a fisherman is fishing, and a tacoma comes and dives underwater and grabs fish by his hands. then it asks if you're tough enough to drive a tacoma? looks like toyota is slouching too, why else would they offer 0% since you say its to sell vehicles that aren't selling.
    ryanbab just posted sales data - guess you didn't read it.
    Ford F-Series: + 0.7%
    Ford Ranger: -18.7%
    Toyota Tundra: +4.9%
    Toyota Tacoma: +12.3%
    "looks like Toyota is slouching too, why else would they offer 0% since you say it is to sell vehicles that aren't selling?" Your words, Tbunder.
    Toyota is enjoying an INCREASE (does that mean slouch???) in sales, while Ford a decrease.
    Also, Toyota will sell its goal target number - the number of trucks produced (so their trucks are selling). Ford produced more trucks than it could sell, which means theirs aren't selling.
    Just thought you'd like to know.
    the tacoma has 2 tv commercials
    they are offering specials on toyota vehicles so please dont say its the big 3 cashing in on patriotism
    Yeah, I saw the Tacoma commercial, I forgot to add that, I've never seen adds for Tacoma on tv until about a month ago.
    Lets look at this 0% deal, shall we?
    Chevy announces 0% on ALL models
    Toyota announced 0% on Corolla, 4Runner and Tundra.
    Not the entire product line has gone to 0%, there are cars and trucks in Toyota that sell anyway, without the drugs in beer. What Toyota is guilty of is making too many Tundras. If you look at the dealership, they have about 4x1 ratio of Tundra to Tacoma, and even though they filled the quota, they can't sell them all. It's a screwup on the Toyota part.
    If you are not aware of this simple fact, let me enlighten you on how companies sell stuff to people. First of all, marketing department determines which segment of population the product is targeted at (this happens before the product is released). When the product is complete and is ready for release, the marketing begins an advertisement campaign, which is designed to appeal to that specific segment of population. Hence the american rock classic.
    I'd love to see some typical Japanese commercials instead of the stupid song, but it simply would not sell. Why do you think the domestic automakers are doing the "We are doing everything we can to keep the economy rolling"? it is desinged to appeal to the patriotic sense of US citizens. Doesnt make the company patriotic, the company is giving the 0% to stay in the market share, it's all about money. But people hear this caring voice and funeral music, especially with that road rolling into the sunset, they feel an urge to run to the dealership to be patriotic. Then they also buy a cheap plastic flag to stick out the rear passenger door window. This is the same patriotic sense that you have when you accuse of Toyota not being made in the US, stealing work from US workers....well, guess what? You really ought to protest the Bush administration these days, since Dubya is about to "open" the Mexican border, then Toyota is going to be the least of your problems. They'll get you in Iowa too.
    "they can't sell them all. It's a screwup on the Toyota part."
    Why cant they sell them?
    Jorge Bush is going to open the border. You would think that, being from Texas (a state run-amock with illegal and legal immigration), he knows first-hand how disastrous that would be. That whole problem needs to be solved by improving Mexico (and I don't think that's America's responsibility either), not letting Mexicans into the US. You would also think the US government would have learned its lesson after the first amnesty in the late 80s and 1990.
    Looks like he is relaxing the immigration...just saw it on the news last night. Apparently, now instead of illegal aliens, there'll be a lot of illegal-now-legal aliens.
    Improving the Mexico is nice, the US needs to do that, because the two countries are tied tightly these days. Don't know how they would do it, inflow of capital would be nice, but with all the tax rebates, and economy down the drain, there wont be any money for Mexico for at least two years.
  • boaz47boaz47 Member Posts: 2,747
    Math must not be some peoples strong suit. If Ford has a .7 percent increase in YTD sales of it's F series trucks is that losing ground to the Tundra? Lets see .7 percent times 753,280 equals about 5273 units and the Tundra's 4.9 percent of 88,563 equals 4388 units. That would be assuming they had the same increases as they did last time. With almost ten times more units sold in a year I wonder how long it will be before Ford feels the pressure at this rate? Isn't the 102,424 F series units Ford sold in October more than all the Tundra's sold all year? It wasn't that far off of the Tacoma's total sales figures either. If you don't sell that many trucks it doesn't take many sales to make it look like you had a big increase. But 16% increase for Silverado is staggering when they were already outselling Tundra 5 to one. But then that is just how it looks to bankers and investors.
    "But 16% increase for Silverado is staggering when they were already outselling Tundra 5 to one"
    This made my day
    I'm curious...you never explained your pumping of the brakes and how it was better than ABS which can pump it up to 30 times/second. Even Bama got his with ABS. Would you care to explain why you stated that ABS is unproven technology? OR are you ignoring this post?
    GOOD LUCK ON THIS ONE NOW!!!
