I bought a 2005 Nissan Altima in April of 04 and at about 7,000 miles the car needed a new engine. It started with the car stalling. I took for service and they told me that some butterfly screws fell into the engine. At that point they "replaced the engine with a new one." Now 7 months later the car stalled at a red light. I took it in for service this past weekend and they tell could not find anything wrong with it. I don't know what to do. Any suggestions.
However, my question is: the old owner used premium gas only for the car. I am a student and want to switch to regular. Is it ok if I do that? I understand there might be some lowering of performance, but I am happy as long as I don't get knocking and it gives me a smooth ride. I am going to use it for general driving only. I talked to the mechanic and he said the ECM will take care of that, but he didn't sound too sure. Could someone please clarify? I feel so bad already, car breaks down in 2 hours, and now if I have to buy premium gas, I will be in a total mess.
Thanks to all who respond, Bodhi.
I also have a 2005 Altima and have had similar problems. You are correct it is the struts that are bad. Just today I had both the left and right replaced. This is my second time for the right strut. It sounds like you may need new struts. I asked them what is the problem with the struts seeing that I have only had the car for less than 3 months when the first strut was fixed. They told me that the struts installed in the car were defected and that new ones should be fine. Well, guess what? They were not. Lets hope that this time around it works. Good luck.
Greg
There are other reasons for the light to come on such as a loose or missing gas cap, a spark plug or cylinder misfiring, or a bad mass air flow sensor. Mass air flow problems are rare. Some auto parts store like autozone or advanced auto parts will reset the light for you for nothing.
Re: Air conditioning not effective [meegs24]
"I have the same problem in my 1996 Altima. For the last few summers i've almost died in my car. Sometimes my air works and sometimes it doesn't. It often doesn't work on really hot days. They air will blow cold for a second or two if at all and then it blows out hot, muggy, wet, nasty air. I had my a/c recharged last week but that didn't do anything. I've talked to many mechanics and no one knows what is going on. If anyone has any suggestions please let me know. My wife and two daughters are dying without a/c. Thanks"
My 97 GXE does the same. Not exactly like that but it doesn't get cool like other cars I've been it. It takes a while to cool down and when it does it's still a little muggy. Maybe Nissan put in a crappy A/C they have to save money somewhere when creating an "affordable luxury"
I'm at a lost and been having this problem for about three weeks. Don't know what to do. Can't find a trusted mechanic, etc. HELP ME PLEASE.
any of you have similar problem.
i have some troubles w/ unbalanced disk brakes, noisy tires, shock absorbers etc.
The car only have 6000 miles.
i think the problem is into the electronic computer.
please send me info about this, and technical data related that speed & relation of auto trans. when came the shift at what speed.
or if the computer is gobernated what is the maximum speed.
Regards.
Go find another Nissan dealer or a trusted mechanic, word of mouth is the best recommendation of all and I'd personally write a letter to the owner of the dealership and the Consumer Office of the city you live in. You'd be surprised how that can help. No dealership wants negative publicity at all. Even call a television station that has a consumer watchdog and "sick 'em" on the dealership. Never underestimate the power of the consumer!!!
The Sandman :sick:
(We're no longer an Altima owner as we traded our Alty in for a new '05 Mazda3 S and are very happy. We're zoom zooming outta here. Ciao all!)
http://www.tirerack.com/tires/CompareMostPop.jsp?autoYear=2002&autoMake=Nissan&autoModel=A- ltima%203.5%20SE&autoModClar=&sortCode=49560&width=215/&ratio=55%20&diameter=17&minSpeedRa- ting=H&minLoad=S&search=mostpop&vehicleSearch=true&speed_rating=HR&speed_rating=VR&speed_r- ating=WR&speed_rating=YR&speed_rating=ZR&
146.00 each
When I turn off the A/C, the noise temporarily goes away. I think the problem has got to be with the A/C... does anyone know what the problem is?
I thought I was the only one with the problem until yesterday I drove past another
old Altima and the same horrific screeching noise came out.
Help. I have suffered too long with this. If someone knows how to fix the problem please post it.
thanks.
Was your sunroof factory installed? Mine is. And do you notice the noise constantly? I now hear the rattling/flapping noise when the sunroof is both open and closed. I'm taking mine to a different service center this week to see if they can diagnose the problem so I was wondering what exactly your issue is with the sunroof.
Thanks!!
The deflection buttons do not change the choices, it's stuck on the center only, if you push either of the defrost choices neither ones change nor does the floor or any of the mix combinations. The AC does not come on either. I've checked all fuses in the driver compartment and under the hood beside the battery, they checked out ok. Could the AC unit being low of coolent cause this? Are their any other fuse locations?
TIA
AL_T
I took it to a freind who has a shop, he hooked it up to his scope, drove it, said the cam sensor signal misses at times. (???) He also suspected a problem with the distributor. The dealers say they can't fix it if nothing shows up as being wrong. Also, occasionally the gauges die (speedo, tach, water temp). They just drop to zero for awhile, then mysteriously pop back on. The problem never replicates itself when the shop has it, but invariably comes back to haunt me.
I swear, if I took the car in for just an oil change or something, they would find 15 things on it that need fixing, but they can't seem to locate this problem.
Anyone? Please?
I have encountered on the road other newer Altima models with the same problem. May be it is a defect. Have you had any other response from the forum?
:lemon: :lemon:
Hello Everyone:
This is my first post to this board as I am a new (and unhappy) 2005 Nissan Altima 3.5 SE owner. Please bear with me while I explain my problem. I know that post #798 was similar.
I purchased the car on Friday, July 1, 2005 and immediately went on a 400 mile round trip for the 4th of July weekend. While on the Ohio Turnpike, at highway speeds, I notice that the car was running rough on absolutely smooth pavement. It remains constant while going from road to bridge surfaces and also when I put the car in neutral and coast. I would describe it as a low drone and vibration. I assumed that a tire (or tires) were out of balance so back to the dealership I went on the following business day which was Tuesday, July 5, 2005. The dealer balanced the tires and said the problem was fixed. I drove the car later that week only to find that the infuriating vibration was still present. Since it was the weekend and there is a very good Discount Tire store near my home, I took it there. They said that all of the tires were still out of balance. After a rebalance and match mounting the problem was still there.
I took the car back to the dealership on July 13, 2005 and returned to get the infamous “Could Not Duplicate the Problem” line. Now I’m more than just a little bit perturbed. I drive to the airport on Thursday and you guessed it, vibration still there.
Back to the dealership for the third time on July 15, 2005 where I would end up spending most of the day. A service technician (and I use that term very lightly) went on a test drive with me. This guy said he couldn’t feel what I was talking about! Now I’m going nuts! They can’t fix the problem so I guess they just decide to go into denial that it even exists. I test drove a 3.5 SL model and it was smooth as silk. I drove a different 3.5 SE and the same vibration was there. At this point the service tech AND the service writer where in the car and still refused to acknowledge the problem. They put 16 inch rims paired with Continental tires on my car and the vibration did not go away. I’m being told that this is just the way the car rides. What a bunch of hogwash!
The service manager is now involved but I’m not expecting much.
Can some please tell me what is up with the 2005 SE 3.5 model? Is anyone having a similar problem? If so, how did you deal with it? Any suggestions would be greatly appreciated.
I’ve read some of the posts here and will have my dealer check out the force balancing, steering components and struts. Has anyone had this problem, had it definitively diagnosed and fixed so that it did not return?
I have a 1995 Altima GXE with 218,000 km on the odometer. The problem is while
driving at highway speeds and a little slower, all of a sudden the RPM needle goes to
zero, ( engine dies ) then it hesitates, then will fire up again and run for 15 - 20 seconds,
then dies. After turning the ignition off, I'll start it again, where it will run for a short while then repeats itself. Yet when I ran it down a 7 mile hill on idle, it did not quit. Error
codes read knock sensor and mass air flow sensor. Voltage for the mass air flow sensor
does not go over 2.250 volts , even at high rpm. Any suggestions?
Cheers,
I posted earlier the same exact things as yours. Except for the smoke. Mine is a 2.5 auto though. My guess is maybe your piston rings haven't set yet. Check your oil level. But I am just guessing. As far as the vibration I think it might be the electric fans kicking on. Except for the smoke I wouldn't lose any sleep over the other things.
I worked for Goodyear for many years and also own a 95 nissan altima. I've had this car since new, I had the same problem with my nissan. The problem is the ignition coil, when the coil gets hot it makes the veh shoot down, yes it will restart but only if the ignition coil cools off. You must replace the ignition coil.
Shekhar
Did you get your car fixed? How much did it cost? Thanks.
CODE 0440 EVAP EMISSION CONTROL LEAK. CAN YOU TELL ME WHAT KIND OF PART DID YOU BOUGHT FOR THAT ?
As for the interior comfort, lately the central piece of plastic imitating metal housing the air conditioning controls has started crepitating whenever the car slows down or accelerates, makes a turn or goes over a bump. I was thinking it could be the differential dilatation coefficient or simply poor assembly; does anybody have any idea if that could be mended (and, if so, covered by warranty)?
Thanks a lot.
Vlad
I'm sorry to say, but I have the same problem in my 2.5S. I had a visible vibration in the steering wheel at around 55mph, but I thought it was from a light crash about 3 months ago. I went for the semi-annual maintenance and they confirmed a tire imbalance and "corrected" it. One day later, the vibration is there again, but at least not visible. Don't know what the problem is, but, to be honest, after reading the posts on this forum, I'm not going back to the dealer, because I already know the outcome. Sorry I can't encourage you more.
Vlad
I suggest that you find a tire shop that has the Hunter GSP 9700 balancer.
This machine measures road force and a lot of other goodies ( of course you need a knowledgeable technician operating it )
Trust me . I've been down this road many times. This machine, along with a good tech., will solve your problems. You probably have a slightly out of round tire/tires,
and only the Hunter 9700 will tell you this. Call around and find a shop that has one of these machines. Since your car is new, you can use the machine print-out to take to your car dealer and get a new tire , if needed. But remember, don't have the car dealer mount and balance it. Go to the tire dealer.
I get the car back, and guess what. That very day, I'm driving it and the gauges all go dead again. I called the service advisor I had been working with and told him I'm coming back to show him. They see the problem and get to work on it. They say I have a short in my instrument panel cluster making my gauges go haywire, but can't say if that would contribute to the dying issues.
They've had the car for two full weeks because the part was on back order, but I'm supposed to pick it up tonight.
The dealership was kind enough to give me a loaner vehicle for the two weeks while my car was in service. (I had purchased an extended warranty when I bought the car and that was one of the provisions) As icing on the cake though, while I was driving the car I was involved in a parking lot incident that damaged the back bumper cover. Very minor, but the cover will have to be replaced, and guess who gets to pay for that...
HAVE THE SAME PROBLEM WITH MY CAR .
CODE 0440 EVAP EMISSION CONTROL LEAK. CAN ENYBODY TELL ME WHAT'S GOING ON WITH THAT ENGINE LIGHT?
CODE 0440 EVAP EMISSION CONTROL LEAK. CAN ANYBODY TELL ME WHAT'S GOING ON WITH THAT ENGINE LIGHT?
I have a 2003 Altima 2.5 SL and I just had my front left strut replaced for the second time. I have less than 24K miles on it and it makes me doubt the reliability of the car. What also concerned me was the dealership started off by telling me it may not be covered under the warranty...what B.S. Fortunately, they changed their mind.
I have three year lease up in July 06 and was considering buying it, but now I am not so sure.
This was my first new car. All of my previous used cars never had a strut problem except for a twenty year old cutlass with 270K miles.
My advice to anyone out there with an Altima is to get the struts replaced or at least checked before your warranty expires.
:sick:
All in all, it pays to check the wiring "beyond the fuses and relays"
Lesson Learnt!
I noticed the same thing last week and I have an appointment with the local Nissan service this week to have this problem checked. How did they treat the case? Did they take it as a problem or did they claim it was a design feature that we should learn to live with?
Thanks for any response.
