Ford Expedition Care and Maintenance
I have found that using turtle wax gives a great shine. I use their wax and car wash. Iam interested, what do you guys use to wash your tires? You know, to make them look shiny black. And what leather cleaner is best?
Ray T.
i have experience this air con problem on our Ford Chateau E-150. Twice we injected freon and it was okay for two weeks but back with no cool air. Culprit was a pin hole freon leak at rubber hose and fitting for the air con system. Refer to a car air con techn and pinpoint the leaking hose.
I have a 04 Exped. XLT that is having a intermittent starting problem that the dealership service department first claimed they didn't see happening. Experienced it once by the Service Manager but claim has not happened since. Because it is not a pin pointed problem or one that they can get a code on, they may give you the run-around or tell you they can't fix it because it is intermittent and they can't get it to happen for them.
When you have a problem like this with a dealer be sure that you are documenting everything that is going on so that you have a case when or if they start jerking you around saying they can't fix it. Had a service manager tell me that Ford told them that if they can't pin point the problem or get a code on the problem not spend time troubleshooting the issue. I spoke to a rep from Ford Motor Company and she said that what the service manager told me was wrong.
So beware if your truck is under warranty they may be reluctant to give your truck the full attention it needs. I am by no means saying that all service departments are like this because I have found a service department that has said that they will do the necesary work to resolve my problem....
And, by the way, I recommend turning off your CAPS LOCK. People tend to ignore messages typed in ALL CAPS.
SUVs and Smart Shopper
Take care
