Acura RSX Maintenance and Repair
Here is the new place for owners to discuss Acura RSX problems and solutions. Thanks for your participation.
Revka
Hatchbacks / Station Wagons / Women's Auto Center Boards
Revka
Revka
Hatchbacks & Station Wagons Boards
Revka
Anyway the dealer duplicated the noise but couldn't figure out what it was. By the way it was not the brake pads, apparently.
Also, I get the click when moving the steering wheel abruptly from side to side when that car is stationary.
Now, lately, I started noticing some changes in the handling of the car - I get this floaty feeling, but only sometimes. Then under hard acceleration all of a sudden there is a pull to the right. It is totally not linear and happens only sometimes. It is most definitely not torque steer. Also, when going though a pothole, again only sometimes, the car shifts/steers to the right. It is quite disconcerting, as for a split moment you get the feeling that you no longer control the car with the steering wheel.
Can anybody suggest what may be wrong? Thanks in advance!
For the click, I don't know, I don't have it in my car.
I honestly don't think it will hurt you if you change it earlier. I've been told that they've put some detergents in the oil for you to break in your engine. But that's hearsay.
Other than that, the only thing changing your oil more frequently is going to hurt is your wallet.
Still having a lot of fun with the car.
Would love any any feedback from other people who own the car?
now the question is: have any of the owners had any problems with the check engine light coming on and off? or when you step on it hard and passing the 4000 rpm where the i-vtec engaged it feel lithe hesitation?
I own an RSX-S, and the Bose system does stink very much. It sounds good on paper (in-dash 6-CD changer, 7-speaker sound system, AM/FM/CD/cassette, etc.), but sounds poor in real life. I plan on buying a Basslink all-in-one subwoofer to replace the Bose Richbass Woofer in the hatch.
acurarsxnut1
I've been looking at different tires on tirerack.com, plus ones that are 225 instead of 205 for more grip. If anyone has any suggestions about a name brand performance tire which would be good year round and has VR rating let me know.
acurarsxnut1
acurarsxnut1
Pry the covers off using the screwdriver cover with the cloth(to prevent scratching) starting AT THE TOP. BEWARE! The bottom of the covers have tabs that insert into the surrounding area, lift the cover up at this stage and do not pry out the bottom!
Now attach small pieces of the foam tape around the speaker that will fit against areas of the cover and keep it from rattling. Replace the covers STARTING BY INSERTING THE BOTTOM and your rattle/vibrations will be solved. I did this on mine with no problems, but if you muck it up it is your responsibility.
The moral of the repair is that design engineers shouldn't count on their tolerances being followed perfectly in the manufacturing process. : - )
719b - Your right, I'm going to take my car to Hagerstown Honda's quick lube this Friday on my way on vacation to get the oil changed and see what they think. I suppose I'll take it to Rosenthal Acura for the 30,000 mile checkup. Have any of you had any of that so called required maintenance done other than oil/filter and tire rotation? I'm interested in what they usually charge to get that BS done.
uthinx - Thanks for the directions on how to take care of the speakers. I was always scared to mess with it in case I might break the tabs off, then I would have to pay to fix it instead of Acura. Did you mention the problem to the Acura dealer at all, or is this what they told you to do? Anyway, I think I will try that out and see if I can do it without screwing anything up. Thanks again to everyone.
Have any of you talked in that RSX vs WRX chat? Man, they are nuts in there. I think the entire chat is biased towards WRX. I laid into them good, and man they really like to fire back. Bad comparison of the two in my opinion, but I guess to each his own.
acurarsxnut1
What you need to learn is to make your arguments sound rational, and not get so excited. You sound ridiculous in there (not to mention paranoid), calm down.
I meant to say that I will replace the Bose Richbass woofer, or at least drastically augment it, by putting an Infinity Basslink all-in-one subwoofer somewhere in the hatch area. It will obviously not fit in that spare tire area.
I'm still trying to see if I can use both a Basslink sub *and* the OEM Bose woofer. On the other hand, the Basslink would way overpower the Bose, so maybe I'd be better off taking out the Bose to save weight and maybe sell it on Ebay.
The other thing I noticed is that the overall acceleration of the car seems to change - some days it feels as if it has plenty of pickup, while at other times it feels labored and sluggish. Does anyone else experience this, or know what factors contribute to it? Could outside heat/humidity effect performance? If so, would it be this noticeable?
Hot, humid weather will hinder your RSX's peak performance.
From the acura web site:
To achieve this 40 horsepower boost, 3-rocker arms were used for both the intake and exhaust valves. the new "intelligent" i-VTEC™ system accounts for much of the difference in performance in the Type-S. A higher redline, tougher engine components,
recent posts about being down 1/2 q to a q of oil during the first few changes spells big problems to come. It seems that the engine might not be able to handle the high revs. For the money being spent they should put in a solid v6 like the tiburon or eclipse. Stay away from this.
Second the handling was poor on the front end. Similar if not worse than the Legend. They still haven't fixed the poor weight distribution. A recent post about wet traction is troubling. when you spend 25k on a car you shouldn't have to change tires to make it safe.
this car will be a problem
BTW, the RSX-S has 142 ft-lb of torque, not 145.
And handling is fine, as is the weight distribution. The car was criticized for using the McPherson struts, but so do BMWs! You do have a point about the tires. Just don't race when it rains/snows and you'll be fine. The RSX-S should have come with, or at least have had an option, to be equipped 17" Dunlop or Potenza tires.
Yes, RSX has poor weight distribution of 70/30 whereas most others FWD are 60/40. The BMW you mentioned has a perfect 50/50.
Bruno
Not there for the left turn. My friend has the same problem.
2)My right lock switch for the door is not working at all time. Is that normal?? Any switch to enable the looks switch?? I am not happy with it.
Design problem. What the hell did they put a ugly plastic section in the back seat for? It's so small in the back that you wish to lie down across the seats but that plastic crap gets in the way:) Also Why they made the hand break so long.
