Best Transmission Fluid?
                    I was wondering which brand or type of transmission fluid would you recommend, and where can I usually find it? I have also heard that a pump is needed to completely change the oil. And what is a good transmission fluid change interval?
Thanks... more info about transmission fluid would be appreciated.
--- Bror Jace
Honda, of course, somewhat unique or so they say!
It is not always obvious what the current recommended fluid for a transmission is. Older cars may have called for Dexron II, but a bulletin may have been issued now calling for III. If there is any issue, get in touch with with either the car mfg. or the fluid mfg.
Aside from Honda and older Fords, the new Infinity Q45 and Hyundai's use unique fluids.
I also have a Merc. Mystique that has this in the tranny, no filter on that one though. Redline markets a different ATF for Fords Mercon and one for the Dexron goup and Chrysler as well.
If we were talking gear oil, I have to give my thumbs up to Redline MT-90
I have used it for years on multiple cars and manufactuirers.
Gear oil I agree about RedLine. However, watch the GL-ratings a GL-5 cannot normally be used where a GL-4 is recommended.MT-90 is a GL-4 as is MTL.
re: Amsoil ATF
I have no idea how one ATF can meet Dexron/Mercon and Chrysler specs. The friction characteristics for the two types of fluid are different, which is why there are different fluids. Nobody else claims that their ATF can be used in both applications. I suspect Amsoil is fine in Dexron applications, but wouldn't use it in a Chrysler trans.
