Toyota Tacoma
I am currently researching the Toyota Tacoma 4x4 pick-up and someone had said that the automatic version is not as good as the standard? Would you agree and in what situations? I drive highway, city, and mountain areas but will not be towing heavy loads on a daily basis? I haven't driven standard yet in my life but am now considering it. Any suggestions or helpful advice?
I personally would never even consider an auto-tranny with a 4 cylinder. Just takes away more of what little power you had to begin with.
If you ENJOY driving, definitely go with a stick. Shifting your own gears is satisfying, and you will have more control over the vehicle while being forced to remain attentitive to your driving. There are some other advantages to sticks, too. If you're battery gets too low to crank the engine while starting, you can do the old rolling and pop the clutch while turning the ignition trick to start the engine. You can also rock the truck by going between reverse and first to get out of a stuck situation. Sticks are usually quicker than autos, and they usually offer better MPGs at the same time.
I think in just about any vehicle that is performance oriented, a stick is the way to go. Family and luxury sedans are a different story.
I have the 2.7 (5 speed) in my long bed, 2wd T100, and although there are times that I feel I need more power, it is adequate most of the time (probably due to the manual trans). Also, there are now a few companies making aftermarket performance parts/kits for Toyota four bangers.
There are most likely some people over at tacomaterritory.com that are running a 4x4 Taco with a four banger and an auto trans, check it out.
joel
The other big advantage (as I see it) with the auto is you get the 4.10 gearing.
I am about to buy myself a prerunner V6 Xcad. I talk three sale men from different Toyota dears.
Two said that the TRD made the ride on Freeway
and City street feel discomfortable than the one WITHOUT TRD. Please give me your oppion.
You made a good choice with the 5 speed. I don't think you'll regret it one bit.
If you go with a 4 cylinder, manual is probably your best option. However, as far as reliability goes, depending on how long you keep your vehicles at some point you will need to replace your clutch. That's not an issue with an auto tranny. And as your initial post states. You have not owned a vehicle with standard before. You may end up putting some wear and tear on the clutch as you become proficient with the standard. Just some food for thought.
Also, Snugtop makes a nice canopy for the Taco but your local Toyota dealer may have a canopy dealer near by that they will recommend.
Good luck with your purchase.
As for putting wear and tear on your clutch while learning to drive, it isn't that hard. Heck, my little sister was driving stick all over town after just a week. Of course, she had a good teacher! :-)
I have now put 26,000 on my '99 w/TRD. I liked the handling of the TRD a lot better than the stock. But, if you drive on bad roads, it can be too harsh sometimes. I'm thinking maybe some Rancho 9000 shocks would allow you to set a softer setting for around town and then be able to tighten them up for the trail.
If you're not a "truck" person, take a long ride with the TRD before you buy it, many people tire of the tight ride and regret it later.
But, off road, the TRD rocks. No bottoming out and bouncing up and down, the truck just reacts and keeps looking for the next big dip or hole. It is a big difference off road.
I have had the 4 cyl 2.7 with 5 spd on both trucks. I've never seen a Taco 4 with Auto. As I've told many people, if you're used to Japanese 4 cyl engines, you'll like the 2.7 If you come from bigger American engines and shift at 2,000 rpm's, you'll think it is slow.
I also agree about hills, if you drive them, the 6 would be nicer. Where I live it is very flat and I have no regrets about the four. Only getting 19-20 mpg though, probably my heavy foot!
I am going to be looking at a 1996 2WD standard cab Tacoma, but as it is very far from here, i would like to see if I can get some preliminary info from you guys before the long trip to see it. To begin with, cabin space is my biggest concern. As I am 6'1", wear a 56 coat, have a 44 waist, and am about 300 lbs, I am worried if I will even fit in the thing! I also wanted to know if the stanard cab can be retro fitted with bucket seats. I read some posts about people doing that, but I think those were Xcabs.
I am very excited about it, but if I cant fit comfortably, then there is no point in even seeing it.
Thank you,
Alex
kip
I wonder about the stereo. Does any one have a decent sound system in a standard cab? Can you fit more than two speakers?
Just curious, Im probably going to buy it now.
Alex
And does anyone know how much it can tow? What kind of gas mileage it gets? at what high speeds will it still feel safe?
thank you
Lunar Mist w/CQ, AB, LX, AA, and WL
The red int lights are a big change, but i already love this truck.
I will miss my 98 XCab though...
Moonroof install next week, Woo Hoo!
Cheers
-wsn
2002 buckets are leaps and bounds better...
Cheers
-wsn
kip
kip
BTW the fishtail-spinout problem can be corected by putting a load in back and/or driving slowly
I would like to know how you compare the 4x4 with the Pre-Runner that has the locking back differential. I know they are very different machines, but can the Pre-Runner handle difficult desert roads? I am not sure if I need a 4x4 for my purposes.
kip
kip
I finally bought the 96 tacoma 2wd reg cab. Does anyone know where i could get my hands on a manual for this car? Whats the deal with manuals anyway? I dont know anyone who has the manual for their car. The guy who sold me this car even had the original price sticker, but not the manual!
Alex
