"No Start" Problems --Talk About Them Here!
HI
Great informative site, please please help me im desperate i bought a 92 Honda civic VTI VTECH 1.6 DOHC B16a2 full dealer history 2 months ago. I was driving and as i dropped a gear i heard a bang the car kept on going fine but when i pulled over i could hear very strange noises coming from the distributor (scraping) so i called the recovery people he came and removed the distributor and sprayed inside the distributor when he put it back on the car wouldnt start at all it turned but would not start (it did b4) he then advised that i needed a new distributor and was towed home. I got quoted 400 uk pounds for it so i got my existing reconditioned only my housing remained for 150 uk pounds and fitted it back and it still wouldnt start no spark when tried with an old plug i took it back and he said it couldnt possibly be the distributor and something else is wrong if it is not the distributor what could it be not inc timing, plugs, leads, at least the distributor should send a spark should it not ? what was the bang was it my ignition coil inside the distributor ? also looking at old invoices from honda the car did have a non start problem due to IGNITOR UNIT FAILURE whats that and where is it located ? im sorry for the long essay but please please help my cars been of the road for 7 days cannot even get to work on time please supply as much info as possible otherwise all my savings what i have left will go to Honda garage who are a rip off in the uk.
Thank you kindly for your help.
A similar thing might have happend to your car. The noise that you heard might have been the weights hitting the housing. You say you have no spark. It does sound like the ignitor has croaked. I would also check up on that reconditioned distributor of yours. Check those weights.
the whole of the unit has been reconditioned meaning the only part being used of my old unit is the housing even the rotating cog rod the rivets you are talking about are they fixed on the housing ? do you think i should just reject the recon unit and get another as if it is a part broken on the housing then i may as well look for a complete distributor. suggestions welcome thanks again
Another place to look at is the bottom of the drive shaft. There is a key that fits into the camshaft. See if it's not sheared off. The key is off centre so that it can only fit one way into the camshaft.
thanks for your help again
You sure seem to know your stuff
The title was amended so that the board doesn't end up with hundreds of discussion that have only 5-6 posts in them. I am sorry if this upset you and I'll try to remember to e-mail next time and explain.
But the Host will do whatever is necessary to keep a clean and easy to read Board going.
It looks like you are getting some good info, so no harm done I don't think. Chalk it up to "housekeeping".
best,
Mr. SHiftright
No, you cannot adjust the weights. The delayed action before the rotor turns after the shaft is turned is correct. Hold the rotor and twist the shaft. Release the shaft and it should spring back. It's really difficult to say for sure what your problem is but I've given you a rough guide what to look for. Good luck.
I would look at a few things before trowing money at it.
First pop the dist. cap and crank over the engine, I'm not that familiar with your car, but the rotor should spin. If it doesn't I would start looking at the timing belt. The bang could have been the belt jumping, and the computer could have compensated for it, but when it stopped the force of trying to spin the cams over from a dead stop could have finished off the teeth.
If you have rotor movement next thing to check is the ignitor, I have seen numerous post on those going bad.
After that look at things like cam and crank sensors, if those go out so will your ignition, also check out the ignition coil. Do you get spark from that?
So here we have a car that has completely drained 3 batteries in the span of 5 months!
I've taken it to another mechanic who tested the alternator (it's fine) and checked for short circuits (none, so far). He says that the car is registering something as "on" and whatever this device is, it's draining the battery when the car sits for many hours.
I'm wondering if any of you have experienced this problem with your cars (Geo or otherwise) and am hoping that you can suggest what device might be the gremlin causing this problem. All devices that I can access (radio, indoor and outdoor lights and vent fan) are completely off when I leave the car so I don't know what else could be the culprit.
Please advise.
I've recently developed a problem on my 99 GLS where the car wont start for about 1 to 2 minutes after I fill it up at the gas station. I'll work the Clutch and gas peddle for about 2 minutes till it starts finally and afterwards is fine till the next time I need to fill up the tank.
I took it to the local import repair; the local VW dealership is too far away and has a bad reputation, and they have been working with VW for 2 weeks trying to understand why this is happening. VW is at a loss and my mechanic has been working on VW's for almost 20 years. They've checked the fuel line and gas cap pressure but the problem still keeps happening. The car basically acts flooded after a fill up and the check engine light keeps coming on. One last thought that VW says is not an issue, but I had Jiffy Lube clean my fuel injectors during my last oil change, after which the problem started, but neither my mechanic or VW says this is a problem
Any thoughts???
Collin
2. If you went to the Quick-E-Mart for 5 minutes would there be a problem?
3. When it does start, does it run rough for 15 seconds?
A vapor bubble could be forming in the fuel rail as a result of a pressure leak down. That leak down could occur as a result of: a leaking injector, leaking regulator into the vacuum line, and leaking regulator back into the tank. The fuel pump could also leak but am focusing on those things that might be damaged by a cleaning.
Leaking injector or regulator into vacuum line could flood the engine. If you removed the intake to the throttle body, there would be a strong smell of gas. Why did you have the injectors. cleaned?
Next time you are in that situation, before starting do this. Turn your key on for 5 seconds then turn it off for 2 seconds. Repeat this 3 times. This will flush out a bubble if there is one. Note that fuel pumps only turn on for a few seconds and then shut off until the car starts.
In response to your questions and comments; which I'll pass onto my mechanic:
1. It only seems to not start when I fill it up with more than 5 gallons of gas ( 14 gallon tank) and after I get it running, it drives fine till the next fill up. You are correct in suggesting that it does run hard for a few seconds after I get it going.
To be honest I don't know alot about cars and how to do more than basic maintenance on them. The reason I had the injectors cleaned, was because I had 32K miles on the car and did a lot of city driving the first 29k miles and I noticed it was a service the oil place offered and asked them about it. They said the fuel injectors were really dirty and I asked VW and my mechanic about it and he didn't think that the oil place could have done any damage; but this all started after I took it to Jiffy Lube. I will pass on your comments to VW and my mechanic as its now going on 2 weeks that they've had it and they are still at a loss. However the mechanic said that it would not occur unless he put more than 5 gallons of gas in the car as he tried putting in a few gallons and could not get the same problem.
