bed rugs
After reading some of the postings for spray liner vs. drop liners I'm still confused. Are the newer bed rugs better than the older ones? I am buying a Tundra and am debating which way to go for the bed. I live by salt water, so our climate is especially corrosive.
I've owned several of the plastic drop in liners. They ultimately rub the paint off and stuff slides around all over. But they are relatively easy to clean.
But I feel BedRugs are superior to plastic liners. BedRugs are excellent for a number of reasons: quality, noise reduction, comfortable for sleeping if you find the need, perfect fit, easy to clean, stuff stays in place, etc. I can go on and on. And no, I don't work for the company!
But the bottom line is you have to determine how you are going to use the bed of your truck. If you're going to carry around gravel and dirt, well the plastic liner is probably the way to go. But if you mostly haul groceries, home project stuff, camping gear, etc., you can't go wrong with a BedRug....
if i had to do it again id go the same route
I have 2002 Toyota DCab and I am considering a bedrug.
I live in new england, and am not going to put a cap or torneau cover on the bed
Is having a bedrug still a good idea?
I will not be hauling gravel or heavy equip.
Suggestions?
-wsn
TIA
If my next truck (3/4 or 1T) is to haul a fifth wheel, the Bedrug may not be an option. Otherwise, it's definitely a do-over.
Steel Horse is another brand name, but I have not seen anything on the fit or design details.
Bedrug has a rubber backing that is shaped to fit the floor of the bed and make the carpet surface flat.
Only negative is that it does not protect the sides , only the bed bottom, but so far, no problem for me. The liners do take care of the sides but also do cause rust sometimes,,just make sure you get a good one and check regularly...
see ya
Tie downs still useable with bedrug installed.
