High-pitched engine squeal at cold startup?
when starting up on a cold morning, when first cranking the engine, there's a short (1-3 second) high-pitched squeel that comes out. What's the cause?
one or two drops of oil behind the idler on the bearing stops it for a month or two. big old squirts of oil will glop up the belt, and you will never be rid of the squealing and flinging, so don't try overkill.
--- Bror Jace
I'll repost and let you kno how it works.
your friend was lucky they don't call him "lefty."
yes, all known keys to the car are in my pocket, ignition switch in LOCK, and the doors are locked for a very good reason any time I reach into Moving Parts Land; thanks for thinking about it, I appreciate it.
