What tools do you carry?
in General
A cell phone and a AAA card.
Other than a flat tire there's not much on new cars you can fix by the side of the road.
I seldom need the tools I carry nowadays--nor should I with a '98 Audi--but they come in handy sometimes for non-automotive tasks that come up at work or when I'm not near my regular tools @ home.
I got the idea for this topic from Jamie Kitman's column describing an interstate jaunt he made recently in an old Lotus Elan. He ran into car trouble and found himself w/o proper tools. I'm not sure how someone who owns 10 old Brit and Italian cars could ever leave home without tools(?).
What about you? Do you carry anything besides the jack and screwdriver your car came with?
Having said that how about:
Jumper cables, a fuse puller+spare fuses, a tire gauge, small portable compressor, small spare gas can(empty but will hold abt 2 pints). Emergency
reflectors or flares, a small razor knife. I've had occasion to use all of these in the past 5-7 years. How about you?
straight and phillips screwdrivers from 1/32 or number 0 on up
standard and metric sockets up to 3/8 inch
assorted flare nut and combination wrenches in both standard and metric
single-edge razor blades
needlenose pliers and 6-inch diagonal cutters
lineman's pliers
2 Vise-Grips, standard 12-inch
DVM
spare fuses and lamps, at least one of everything
25-foot 3000 pound logging chain and 24-inch bucksaw with two spare blades for downed timber on the road (yes, it's an SUV and I vacation in designated international wilderness areas, what's your excuse??)
20-foot woven snap-strap for towing
jumper cables
empty 1 gallon jug and empty 1 gallon gas tank
duct tape
washer fluid and a spare quart of oil
winter survival kit for 36 hours, including heater, in appropriate weather (this is blizzard country)
cell phone
extra medicine for 2 days
small roll of pink construction site warning ribbon
I tend to at least touch everything once per year, even in my 2000 that hasn't had one running breakdown. I really should put a spare V-belt back in now that I've got the 2-year mark, will do that next payday. I have had to replace belts twice in east Hell over 35 years of driving, and one was a serpentine.
I too, don't get paid to work on my vehicle, so that being the case, it better be in a toasty shop with all the tools. ie; mine.
The only time I ever lift a tool without getting paid for it is on my own vehicles and if it is not warm and dry, that vehicle sits. LOL!
NEVER ONCE used any of it so I no longer bother.
And, yeah...carrying flares is a good thing to do.
I remember seeing a display of flares in an auto parts store once. The sign said..." When you NEED flares, you can't buy them!" True!
dangerous coz u can get stuck in the middle of nowhere in the middle of the night or u can run out of gas while you are crossing the railroad tracks! it can be expensive coz each time u wait until the light comes on, your fuel level can be quite low and the pump starts sucking on dirt which in turn can block your injectors and so on.
so i always fill up when the needle reaches 1/4 or half.
Combo screwdriver
Couple of fuses
handi-wipes
flashlight, small enough to stick in mouth
cell phone
paper towels
piece of folded cardboard to kneel on.
in the case of ford explorers, at least, and I have heard rumbles of several other of their SUV line, the way the gas tank baffles are laid out, you can stall on low fuel with a quarter-tank left... if you are making a turn from stop or heading uphill. another reason I almost never drop below the half-full level. my gas tank is plastic, so I don't have to worry about the condensation from air in the tank starting rust any more.
Under the front seat is a small toolbag with 3 different sets of Exelite tools another vise grip, set of pliers, side cutters and needle nose as well as a set of US open ended wrenchs down to 1/4". In the back of the Astro is a battery air compressor that will go up to 160lbs(if you wait long enough), empty 3 gallon container, tire sealing solution, a large light with a big single cell in it, in the front door is a double c cell Mag lite and for emergencies is a cigar lighter plug in light.
In the center console is a battery laser pointer.
On the dash is a Garmin Street Pilot Color trac with a 128mb data card and the western US highway system(called Metroguide) downloaded. (That way I can tell someone where I am right down to the 1/1000ths of a minute). I carry 2 cell phones, one on a different service than the other and a pager. I used to have a portable cb but got rid of it a few years ago.
In addition, I have a supply box with various types of tape, tubing and wiring nylon line and poly line and various gas and electric fittings. There is a metal folding stepladder that goes along, a gallon of washer fluid(RainX) and a quart of oil, a box of latex exam gloves and pair of leather gloves as well as a pair of cotton gloves. I have an emergency kit with airways, H2O, fire starter, water proof matches, lighter, first aid stuff, flares, signal mirror, whistle, 2 moving blankets, battery cables, and a poly tow rope.
Then since it's winter I have two sets of tire chains, a grain scoop shovel(for moving snow), a bag with my down sleeping bag,ski gloves, insulated pac boots, extra socks, knit cap, balclava,and Whall cover-alls. I always carry a box of heavy duty garbage bags and a couple rolls of paper towels and a fresh plastic container of wet wipes. Sometimes in the winter I also take along my Oly Mac chain saw. I won't go into what I carry in the way of fluids on board but I do have MSDS sheets for all I carry.
I know I've forgotten a few items but that's mostly it. OH ya a AAA card................
Are Astros THAT much trouble?
.a Leatherman
.a Swiss break down wood saw
.a Browning folding saw
.a Woodings Cruising Axe
.a KaBar military knife (heavy duty)
.12 Meals Ready To Eat w/ 12 chemical heaters
.Well equipped First Aid Kit
.Common over the counter Rx; Tylenol;aspirin
Benedryl; extra instant cold packs and heat
packs
.six one litre bottles of water in pack
.several 120 hour candles in a can
.several 44 hour candles in a can
.Brass enclosed candle lantern w/candles
.water/wind proof matches
.Gerber Strike Force fire starter
.two down mountain sleeping bags rolled and
compressed
.Hudson Bay Wool Blanket
.military rain poncho w/thinsulate liner
.Gore-tex lined -30 degree down parka w/hood
rolled and compress in bag
.Gore-tex over pants
.Gore-tex, thinsulate LL Bean Hunting Boots
.Serius Wind/Waterproof thinsulate gloves
.2 pair Trekker Mountain Wool knee socks
.2 pair lightweight fleece liner socks
.Serius balcava
.Compass/topo maps
.MountainSmith Back Pack
.Walking staff with carbide tip and rubber tip
.Coleman Black Cat Catalytic Heater w/fuel
.100' rope
.nylon two strap
.compressor w/12V outlet and 12V charger
.2 Rx Stout mystery books (Nero Wolfe)
.Cell phone
.CB Radio
.portable digital multi band radio with seper-
ate long line antenna. Extra batteries.
.4 D Cell Flashlight; extra batteries/bulbs
.3 D Cell Flashlight; extra batteries/bulbs
.2 AA Cell Flashlights; batteries/bulbs
.l military goose neck 2 cell flashlight with
several different colored lens
.12 hour light sticks; Yellow/Red
.Folding Military entrenching shovel
.compact 35MM camera w/film
.compact 8 x 35 binoculars
.compact folding triangle warning kit
.surplus military tool bag w/tools
.extra pair of glasses
.lip balm
.sunglasses
.extra boiled wool watch cap
.Quart 5W30 oil; duct tape; plastic bags
All this and more fits in waterproof compact bags that can be removed in a minute. Any thing with an expiration date is noted on a pad and replaced when necessary. A list of all contents is immediately inside each bag. The BackPack is self contained, medium sized and is used to store specific items.
I carry all of this in a rather small area in the rear of my current SUV, a 2001 Isuzu Trooper. I remember not so long ago when a 100+ vehicles were stranded for days on Route 81 in the PA Mountains during a terrific snow storm.
While this may be rather anal to some, it is rather fun when sitting in the garage with a couple buddies having a beer and discussing our "kits" and what trips each of us have planned.
Have a sealed metal box at a cabin, so animals can't get in, with some essential supplies. No electricity. So, the SUV stuff could come in handy there also.
I love retirement:)
P.S. One Litre Bicardi Rum for Medicinal Purposes
>3.5 pound polyester/cotton sleeping bag
>set fleecewear
>3 sets wicking synthetic winter socks
>deerhide choppers with 2 liner sets (mittens from Hell for those in warmer climates)
>5 bottles isopropyl gasline antifreeze (undrinkable)
>certain amounts of ready cash
>chopped gallon jug (disaster chamberpot)
>pint cooking pot for snow melting
>candle lantern with 6 refills
>mechanics wire for slinging same overhead
>24-hour candle furnace
>burns anywhere matches
>antihistamine, aspirin, rolaids, etc
>2 days of necessary prescriptions (asthma and heart attack patient)
>DC cord for the PCS phone
>2 movers' quilts for extra warmth always in car
>2 sets batteries and bulbs for the 4-cell lantern
>big bag gorp
>empty gallon jug
>flashing bike safety light with extra batteries to catch attention
>roll of showy fluorescent pink builder's marking tape to catch attention
>I put the Sorels boots in for every long drive
>couple paperbacks
>two grocery-size paper bags with handles
>roll tp in ziploc bag
>scoop shovel
>half dozen kitchen garbage bags
>weatherproof oversize rain suit
and I have been remiss in not adding lately, especially since this weekend looks like heavy weather and I plan a road trip...
>extra long wicking underwear set
>rabbit fur balaclava and fleece gloves
>lowfat crackers etc
>the second first-aid kit
>used screwdrivers for use as ice grabs in case I have to haul my sodden, frozen butt out of an ice break-through (a single 4-in-one and a 1/2-inch cabinetmakers' screwdriver won't do it, a pair of super-stout blade-through Philips #1 or #2 would be much better)
>canoeists' dry sack to hold a full change of wicking synthetic clothing and keep it dry no matter what
>second LED camper's light, 30+ hours on two AA cells and good for reading by (places like www.rei.com and www.piragis.com sell them around $20-25)
I don't think a hip flask makes a lot of sense the way our fine regional constabulary assumes if you have been in the ditch a day and still have a gleam in your eye, you had an elephant's snootful when you spun in there in the first place.
and of course, as always, enough tools to do half of a disassembly/reassembly of the Exploder and log a forest, as way up the list.
and the 35mm with spare film and battery in the front for documentation in the face of insurance claims agents who think it's their own money, not mine....
This may be one of the really great topic areas around. Lets hear from some more folks on this topic.
TP tends to be too quick to disintegrate for use as a wipe rag on cars; a half-used roll of paper towels is of great value, and of course the shop rags when they're on sale at your local parts place are great for wiping down nasty messes. not very water-absorbent, though they are good on grease.
Everyday kit:
a basic tool wrap with combination wrenches (ASAE and metric)
a 3/8 and 1/4 socket sets (ASAE and metric) (including universal joints)
a full set of screw drivers
a variety of pliers
a large adjustable wrench
two flashlights (big and small)
jumper cables
wrags and a towel
bungees
a full first aid kit
a compass
a swiss army knife
tire gauge
a pack of moist towlettes and tissues (good for toilette paper too)
a couple bottles of water that I rotate to the fridge for fresh bottles when I change the oil
floppy hats and sun screen
hitch receiver with 1-7/8 ball
chain extensions
a 4-wire harness extension
an adapter for the RV plug reciever to accept a 4-wire trailer harness
when I change the serpentine belt, I put the old one in the car
when I change the plug wires, I put the longest old one in the car (two of my cars now have coil on plug, so that item is out of the car)
an extra hose clamp
razor blades
electrical tape
duct tape
a hand broom
extra circuit breakers (fuses)
When I pull a trailer I have a kit in the garage that I put in the car that has:
rope
bungees
a small jack
an air pump
a can of fix-a-flat
In the winter I add:
boots and thermal socks
a warm coat
a blanket
I have a pair of warm gloves I leave in the car year round
an 8' chain
a small shovel
I don't carry motor oil normally because my cars don't use oil, but I'll throw in a quart when I travel.
When I travel, I do build a travel kit.
appropriate clothing and boots and a blanket for cold weather
I also throw in a 3/8 torque wrench because I had to change a water pump 800 miles from home once I also carry food when I travel
a spare headlamp (I had to drive overnight on an 800-mile trip with one headlight because parts stores close at 8 p.m. on Saturday night in Detroit).
I am pretty meticulous about maintenance, and wearables get replaced long before they wear out. I did have a flat recently while traveling in the old Explorer. Left front tire and I can speak from experience on Explorers and tires; it's the car. I wish I had something to kneel on and I could have used two rags, not one. Some dry hand cleaner might be a good addition if I could find some. I put a pack of those moist towlettes in the car instead and added a towel.
I haven't had to use the tools on my own car nearly as often as I have on cars belonging to others. But I feel better that the stuff is there.
the rest depends on how good the AAA mechanics are
but in the hands of most people, a cell phone is arguably the more appropriate tool for any mechanical adjustment :-D
Seriously
I carry jumper cables, screw driver, two cresant wrenches, flashlight, pliers, cellphone, and AAA card.
If I'm going to the trap, sporting clays or rifle range I'll be better armed
John
i was going to look at the air filter and it requires a straight-head screwdriver and a hex key wrench for the clamp. all i had was a phillips and needle nose pliers:-)
soooo what is needed for an adequate starter, nothing major, tool set.
do i need metric and non-metric sockets, wrenches?
kragen's has those Team Mechanix kits. cheesy?
thanks.
