Is Distilled Water Necessary for Flushing the Cooling System?
I'm going to have my cooling system drained and flushed. My mechanic says he refills with tap water, but someone else said that will lead to corrosion and I should use distilled water.
What is the correct answer?
Do you mean using distilled water to FLUSH the system or to FILL it?
Chuck
My next point is a new vehicle has NO CALCIUM deposits in the cooling system, but later with poor water quality the calcium deposits build up leading to less affective cooling due to the insulating property of the calcium buildup. This means it takes longer for the hot engine to transfer its heat to the liquid water due to the calcium barrier.
Using distilled might not make a huge difference, but it definately won't hurt and is likely to help extend engine life.
Well, if that doesn't convince you, then replacing the heater core when it plugs up with calcium deposits might....and is an expensive repair unless you do it yourself. Your also extending the life of your radiator.
I do a engine flush with regular water, then I drain the water at the block. Only then I add distilled water. There is some regular water left behind to combine with the distilled water, but I can live with that.
Is it a good idea? Yes.
Will it do much harm? That depends. Depends on the engine, the coolant and the cooling system?
Would I worry about it? Absolutely not.
You see, I do alot of marine work and most of which having cooling systems that pull directly from the water the boat or vessel is in. Salt water systems see the most, but freshwater aren't that bad.
SE92692,
If the system is backfilled, meaning that the flush and/or water is pushed out, while the new coolant is pumped in, then yes, all of the water is gone, maybe a minute is left, but it will mix fine with the coolant and the additives in the coolant are designed to counteract any problems the minute amount left may cause.
There is so much contamination in the cooling system, from casting, machining and everything else, the minor amounts of minerals in the tap water won't make a whole lot of difference.
In a battery, YES. Coolant, not likely.
Don't get me wrong, I am not saying it is a bad thing. Anything you can do to enhance the life of the engine is a good thing, just that it isn't an absolute. If you have a water softener, then distilled or another source should be used.
The chemicals and salt from the water softener system will eat at the copper in the head gaskets, which is why salt water marine engines use stainless steel in their headgaskets.
Thoroughly confused now? LOL!
