Chevy Venture Care and Maintenance
My AWD Astro is fast approaching "front brake pad time". It's getting close to 30,000 miles on the originals and I won't go past 30k on them. My experience for these Astros is that they have just OK brakes, not really great brakes. I'm not much for national chains but Firestone does have a lifetime national warranty on brake jobs. Any experience with them? My last Astro "wore" brakes from a regional tire company, Les Schwab, but I was never really happy with the brakes after they installed them. They really went to a lot of work trying to make them work as well as they did when new but in spite of replacing the front calipers and pads twice and finally replacing the rotors, the van still pulled slightly to one side or the other. The problem was sometimes it stopped straight ahead too and you didn't know which of these options IT was going to pick for you.
I have a notion that I'll probably take it back to the dealer. I just want the best brakes possible for it and I really don't care if the pads are really hard and make a lot of noise(heh, heh I'm hard of hearing). I don't really care if they tear up the rotors, I just want the best brakes possible on my Astro.
Recently, the van has been experiencing a vibration and what I can only describe as a 'bucking'. It seems as though something in the drivetrain is binding up and then freeing again. This happens at all speeds and in all 'gears'. The dealer noticed that the CV joint on the front driveshaft was shot and replaced it for $1300. They thought that fixed the problem. Guess what? The problem is still there and the dealer cannot figure it out. One thing compounding the difficulty in finding the problem is that the 'bucking' does not occur consistently and the vehicle must be driven for about 15 minutes before it starts occurring.
There are two major issues here as I see it. The first is that I believe the front driveshaft design is defective since I had 2 fail on me. I think this would go unnoticed in these vehicles until around 90K miles when the front driveshaft falls apart.
Secondly, the bucking we are experiencing is a major binding in the drivetrain. Since it occurs at high speeds (as well as low speeds) and if the drivetrain locks up at these speeds it could send the vehicle out of control and possibly flip it. I believe it is a malfunction in the viscous coupling and asked the dealer for a schematic of the design to try and diagnose it for them (these trips to the dealer have cost me $1500 so far without fixing the problem). I am an engineer and I thought I could help out here seeing that the problem was not being fixed and that this 'binding' could potentially be life threatening. The dealer ignored my request.
This is a warning of a potential problem with this vehicle. If the problem isn't solved and if this turns out to be fatal for me or any member of my family, then at least we've documented it here and warned others.
C
This sounds like what happened to my 1998 Venture. It turned out to be a clogged injector. Venture injectors are very prone to this if you use the wrong brand of gas. Do not use BP gasoline - it may be the worst for this. Marathon gasoline has worked very well. What fixes the problem is to replace the injector which costs about $150 for the part, and start using injector cleaner once a month along with Marathon gas or some brand that will not clog the injectors. My mechanic also tried a special machine to clean all the gunk out of the injectors. This worked for a while but the problem came back. Had to replace the injector and use the right gas for a long term solution. I'd get a mechanic who could figure this out. You may also notice that your gas milage really suffers when this problem happens. It's because that cylinder is not firing a lot of the time. You may also smell gas fumes too. Good luck.
Today was the 1st cold day in the area, around 20F. When the vehicle is up to full running temperature, the guage never got above 1/4 & spent a fair amount of time bouncing a little below 1/4, which it never has before.
Now, before the really cold weather hits, should I change the thermostat? Is this something a simple DIYer could do? Took a quick look & it didn't seem too easy to access it.
Just a reminder to change you oil with cold weather season comming on I guess.
Thanks Happy Holidays to all
I have had the following done.
Engine bucks at 65mph, 45 mph
1. fuel system change
2. Fuel pump change
3. new wires,cap, rotor and spark plugs
4. New Injectors
5. replace wire connector to dist. (Cure idel problem)
Will a bad crankshaft sensor cause this.
I am stump to the problem and wondering if anyone else has cure the engine bucking problem.
Does anyone know the procedure to replace low beam headlamp? Or...where to get that info??
Thanks for your help..
Mark
Dave
Thanks for the response..
Mark
Did you ever find the problem with this 99 astro van bucking problem?
It didn't work.
t
I'm trying to sell my '98 Venture but my front wiper are currently stuck. The driver side pivot is the problem. So i bought a used set of the pivots (which also includes the whole linkage) but i'm unable to undo the motor from the assembly.
The problem is the T30 screw of the moving part. I can't seem to be able to unscrew it without the motor turning on me... anyone has the right trick to get the motor out fo the way ??
Thanks a million.
Etienne from Montreal
Any ideas on what I should expect to pay for a good tune-up?
CAN ANYONE Help!!
I have a 2000 Chevrolet Venture LS van with 120k miles on it. It has recently started making a horrible popping noise under the front end(i call it firecrackers as this is what it sounds like).
I 1st noticed it while idle at stop sign 1 day. I had to look around for kids.... thinking someone had lit a box of firecrackers and thrown them under my vehicle. It stopped, only to return lasting longer and louder.
Thanks in advance for your comments & suggestions!
Fuel & air filters
clean MAF sensor & throttle body
PCV valve
Ignition wires
and the big killer - change the spark plugs.
My mechanic said just plugs & wires were over $ 600.00 including labor. The labor is the biggie, they have to rotate the engine forward to get to the rear plugs. I'm going to try to tackle it myself in the spring, good thing the plugs only get changed every 100K miles. I like our Venture but boy is is a pain to work on & when the mechanic does it the labor charges are brutal....Took me all day to change an alternator, can't imagine what that would have cost!
Took a look underneath, rear driver's shock is leaking fluid. Am I safe in assuming that the leak in the shock is an air leak as well and causing the compressor run more than needed (and if the shock is replaced, should do the trick?)
