Inconsiderate Drivers (share your stories, etc.)
1107108110112113478
  • alfoxalfox Member Posts: 708
    the Firestone/Exploder tire problems a few years back were essentially due to marginal tires run below the manufacturer's recommended inflation pressures, causing the vehicle to handle marginally. We all know that the average US driver is marginal at best.
    Look at the tread on the pieces you see on the road some time - they almost always have deep new tread. Heat accelerates tire failures. Worn tires dissipate heat better than new ones. Therefore, once tires wear a bit without failure they are probably going to run through their tread life without tread separation, provided they are kept properly inflated and not cut up.
    Next, as you travel check out the tires of cars in front of you, and notice how many are under-inflated. I'm guessing that 25%+ of all automobile tires on the road are underinflated, at least 10% seriously so. The price paid is high: 10-20% increase in fuel consumption and 30-40% faster tread wear are cheap compared to the potential consequences of premature tire failure.
    Makes sense to check out youor own now and again, eh? At least, as you walk up to your car each time LOOK IT OVER!
    That was the summer of the SUV tire problems showing up. I wonder how many of those were Explorer tires.
    I check my tires each time I walk up to the car. I also have noted nails and glass in the tread usually before they get driven in deep enough to do damage. It's worth checking your car tires.
  • 210delray210delray Member Posts: 4,721
    This may be sexist, but I'm getting a little tired of it.
    Yesterday, it happened again. I'm going 55 on a busy 55-mph road in Maryland. (Sorry, 55 is fast enough for me on a 2-lane, when oncoming traffic is separated from me by only a painted line). Good wide road with paved shoulders. Woman in Hyundai Accent comes up on my rear, just off my bumper. I slow down to nearly 45 mph, and move to right side of the lane on a good straight section with oncoming traffic a long way off. She doesn't pass! Ok, it''s a cheap little Accent! But I'm trying to let her go!
    The only way I can get her to go around is to pull onto the right turn lane for an upcoming crossroad.
    Now on rural 2-lanes, I really try to allow faster drivers to go around me, by slowing slightly and pulling to the right in passing zones, waving them around when safe with my arm if they don't get the message, OR even pulling off the road entirely if necessary. I don't hold people up.
    I only ask, please pass or back off!
  • navigator89navigator89 Member Posts: 1,080
    I wouldn't call this inconsiderate, rather stupid and dangerous.
    A few days ago on the highway we saw a maroon Chevrolet Optra hatchback (think Suzuki Reno) with its hazard lights on. It was veering dangerously from side to side, and it was doing about 60km/h, and we were doing double that, around 110 or 120km/h.
    Turns out, when we passed it we saw the left rear tire wasn't properly attached, it wasn't in an upright position. It was twisted to a side, and that affected the car's handling greatly.
    I'd don't know if the tire came loose, or the axle/wheel was messed up, but regardless no one should drive a small car like that, especially when you have vehicles around you doing 120 km/h.
    A guy in a Tahoe was driving with a tie-rod separated. When he drove slowly the wheel would track straight ahead, but when he got up to about 35-40 it would shimmy extremely, and he would slow down. Bozo tried about 4 times while we watched to get up to speed with the same results each time. In the process he drove right past a rest area. Dontcha think at some point you'd get out and look at the truck to see what was causing the problem??
  • toomanyfumestoomanyfumes Member Posts: 1,019
    Going around Chicago, I was in the center lane doing about 75, when an old Sentra full of teenagers flys by on the right at least 85MPH. Well, his front struts must have been totally shot because the front end was hammering up and down so bad the tires must have been leaving the road. I was surprised he didn't lose control.
    2012 Mustang Premium, 2013 Lincoln MKX Elite, 2007 Mitsubishi Outlander.
  • xrunner2xrunner2 Member Posts: 3,062
    Teenagers going 85 even in a brand new Sentra is plenty dangerous and "inconsiderate". Chicago metro area has requirement that vehicles licensed in area must be emissions tested periodically. Would be a good idea to also test for basic things on vehicles such as struts, tires, lights, brakes (slow moving stop test), wipers, etc. Know that big job to set up infrastructure, procedures, qualified personnel and so forth. There would be costs, but these would merely be passed along to vehicle owners in terms of license fees. Perhaps tests would be annual.
    Chicago did have tests for safety many, many years ago. Think that these were eliminated due to graft and bribes. But, emissions testing going on right now has been in place for maybe 20+ years and do not hear about any corruption for this function.
    Would be nice to have these state-wide in all states. Sentra described would be caught and remedy/corrective action would be required to keep license - drivers and vehicle. Also, maybe pick-ups jacked up about 3 feet off ground would be caught and also be required to put truck suspension back to original factory level. Some will say this is maybe can of worms, but would be worth increased safety to general motoring public.
    If the public were really serious about auto safety they would support this. But they won't. They'll say they want it but if they have to take their own car in and pay for the check, they're against it.
    Had the related problem with E-Check in Ohio for emissions. People want clean air, but want others to have to bear the checks and costs. Instead the silly militants in Ohio have gotten the legislature to do away with E-Check and will not have the funny gasoline with higher costs and lower mileage and even perhaps engine damage later on from the gasoline. But the anti-pollution-check people finally got what they wanted...
    Same would go for safety checking. Payoffs, complaints about having to go would be everywhere till they did away with it again.
    Cincinnati city used to have a safety check requirement long, long ago. Same problems you document. But they caught brakes, lights, tires, etc., that weren't right.
  • fintailfintail Member Posts: 58,805
    There certainly should be inspection procedures for brakes/lights/structural issues/tires etc every time an emissions test is done or even when license tags are renewed. I see a lot of scary stuff on the road.
    Just because you can get it running doesn't mean you should have it out on the road.
    We agree.
    The other poster mentioned that it should be statewide. I agree with that also. Otherwise people turn flipflops to register their car elsewhere. My neighbor registered his one car in next county to avoid the EPA E-Check on his new car after 2 years. Ohio didn't have E-Check in all counties like it should have been.
    I also think of stopping at a gas station far east side of Atlanta back in the 70s and the "mechanic" had a rag stuffed in exhaust pipe of a car up on the rack. He explained that the stations did a safety check for the State and the rag would make any leaks in the exhaust system show up.
    I wonder haow many cars got passed for a $5 or $10 in the palm that shouldn't have passed at the public type checks for safety like that. At least the emissions checking in Ohio was at facilities run by a contracted company. The last few years they had signs up that it was illegal to offer a bribe to get a car through the test. Apparently they had had offers.
    That would be the problem of course, crooked inspection systems. But it might still be worth pursuing. It's a common thing in other areas.
    A few years ago, on an interstate, I passed a car that was still moving at about 65mph. Some part of the rear suspension, a bar across the rear was broken loose and dragging. Looked like the worlds largest sparkler. This bar wasn't just flopping down and around, since it ran crossways to the road and still seemed to have downward pressure on it, it was continously aganist the pavement.
    The lady driving didn't seem to be aware of anything. Of course, this may be how she went throught her entire life.
    My wife won't let me wave at people about problems, or roll down window to try to tell them about them. She's probably right. These days doing this might just get you shot while trying to be helpful.
    Agree, not a good idea to try to tell people while moving that something's wrong.
    I did tell a man parked next to me at a rest stop that one of his tires was nearly flat. That was successful (face-to-face contact).
    Regarding safety inspections, we have them here statewide in Virginia. Any service station or repair shop can apply to the state to perform the inspections. Unfortunately, there are some shady operators who'll just look your car over and give you a new sticker without actually doing any real inspection. They can be reported to the state police, but I doubt many are.
    Two winners for the day:
    Woman in a Camry messes up in a "Y" intersection and cuts across lanes to go the proper direction. Why? She's text messaging as she's driving.
    At a poorly planned interchange in south Seattle, a guy in a Navigator has a hard time turning, and slowly and awkwardly drives all over a couple lanes. Why? He's combing his hair as he's driving.
    Both should have their licenses revoked and their vehicles taken away.
    I'm pretty mellow now in driving compared to my younger years, to the point that I let most things blow over without getting overly bothered. I avoid eye contact when there is the potential for trouble, etc.
    However, last Sunday morning at the beginning of a 300-mile trip to the beach, I encountered a truly inconsiderate driver.
    I made the mistake of taking a popular local shortcut between two major highways. It's a residential/semi-rural road with a posted speed limit of 40 mph. Of course, no one likes to go 40. So I'm going the speed limit and what I thought was an earlier Honda Accord or Toyota Camry comes up on my rear. No problem, par for the course, and we're coming to the stop sign at the end of the road in a mile or two.
    When I get to the stop sign to turn right onto the major 55-mph 2-laner, I see a Buick LeSabre approaching from my left. I decide to wait and let it go by. At that point, Mr. Impatient behind me toots his horn. Turns out the Buick was going slower than I had expected, and I could have pulled out (not too surprising given that Buicks are the car of choice for older people).
    However, before the Buick even goes by, I see Mr. I. sawing wildly at his steering wheel, and I knew he was going to try to go around me! Well, I guess male pride kicked in and I literally leapt into the intersection the instant the Buick passed and said to myself that I'm not going to let him get around me!
    I accelerated my 4-cylinder Camry at full throttle, but to my amazement, Mr. I. got into the oncoming lane off my left rear and stayed there for maybe 1/8 to 1/4 mile trying to out-accelerate me in a no-passing zone!
    Very quickly, I was up to 60 and closing in fast on the Buick. Mr. I. finally got in behind me. Beat him! Of course, at that point he was really on my bumper, but there was no way for him to go around without committing suicide, as we had entered a series of curves and of course, the Buick was still in front.
    Now, I had no intention of holding him back forever, just didn't want him to pull that old stunt of going around me back at the stop sign.
    So when the first passing zone came, I let him go. But to get his point across, he cut directly in front of me, coming very close to my left front corner. At that point, I laid on the horn. Good thing he didn't brake-check me!
    It was then that I saw he was driving a previous-gen Corolla. No wonder he couldn't out-accelerate me! I was pretty steamed though.
    Well, in the next passing zone, he passed the Buick and was gone.
    Later my wife told me that his entire rear end was plastered with bumper stickers. She didn't remember what they said, possibly something about rock bands. I was so mad, I didn't even notice any stickers.
    Now, in hindsight, I guess the best thing would have been to swallow my pride and let him go in the first place. But sometimes, ENOUGH IS ENOUGH.
    What would you have done?
  • snakeweaselsnakeweasel Member Posts: 19,625
    Well in my observations it seems that the IQ of the driver is inversely proportionate to the number of bumper stickers the car has. Of course everyone gets one (maybe two) freebees.
    As to what I would have done, well some things are best left unsaid. ;)
    I can't criticize your actions, because I know what adreneline can do. Been there, done that. Afterwards, in retrospect I have not always been happy with what I did, though. Accelerating on someone who is across the line trying to pass can be downright dangerous, wrong or not. The result could have been nasty, and preventing him from getting past you could have put you partially at fault. But only you really know what you should have done, and can learn from any mistakes you find in your own driving. I know - I've done it.
    What was the right thing to do? Probably ignore his existence.
    As I've grown older I have more and more often tried to avoid such confrontations. I might have pulled to the side on the shortcut and let him zoom past to get rid of him, and with luck attract the attention of any cops nearby. The more egregious the other driver's actions, the closer I adhere to the norm, back to the precise speed limit, and to very predictable driving. I figure if they can correctly guess what I'm going to do, I'm less likely to physically tangle with his car, or contribute in any way to his tangling with someone else.
    LOL!
    Thanks for your response. Actually, I pretty much do the same as you mentioned in your final paragraph, adhering to the speed limit when someone is blatantly tailgating, and making it as easy as possible for he or she to go around me, pulling off to the right if there is no other option.
    I didn't pull off while on the shortcut, because there was no suitable location, and I figured once we got to the major road with passing zones, he'd go around me. I guess I steamed him some more on the shortcut (without realizing it) by slowing down considerably for an older, well-dressed gent who was standing on the edge of the road retrieving his Sunday paper. I routinely give wide berth to pedestrians and bicyclists on the side of the road.
    Yes, it was a dangerous situation not letting him pass, although the road was straight at that point and I could see that no oncoming traffic was present. Initially, I was in total amazement/shock that he really tried to pull it off, since I jumped out of the intersection so quickly and had the advantage of a shorter pathway.
    I certainly regret though that I gave in to an adrenaline rush, male pride, or whatever it may be called. It ruined the first part of a nice drive to the beach!
    Its hard looking back at our own actions at times, but that's what separates thinking drivers from the mindless ones (the majority??). We live and learn, and we hope continue to live.
    Good luck - hope the rest of the day at the beach made up for the stressful beginning.
    What did the Buick driver do wrong compared to the idiot in the younger brand car behind you? Yet you are critical of all Buick drivers:
    >"...surprising given that Buicks are the car of choice for older people."
    I had driven Buicks for 25 years. Am I an inconsiderate driver now? Or am I inconsiderate 25 years ago? Or do I just recognize quality in a car and dealership?
    P.S. I don't have any bumper stickers on either LeSabre. I did get a bumper sticker for my son's school, "Honor Student at NorthXXXX School" but I didn't put it on...
    Now on a serious note: the steroid-rage type driver behind you needs the police called on him. I try to be aware of police numbers where I drive, State, Sheriff, local police, on a regular basis. But that's impossible.
    What I would have done is fumed, slowed slightly in speed, then pulled off to make the dope pass.
    And a "cellular dime" dropped on these drivers may save a life somewhere else later.
    I probably would have done the same thing, 210, but I am young and jerky. It's a good thing I don't drive an old Dodge Power Wagon or something...or he could have brake-checked me, and I simply would have rammed him into oblivion and kept on going.
    Buicks have a rep, deal with it. If all those Centurys didn't sell to 80-somethings, it wouldn't be so bad.
    Yesterday I saw an early 90s Deville driven by a VERY old couple in a center lane of I5 in Seattle going about 45 mph as surrounding traffic in all lanes was going about 60. Reputations come from somewhere...
    I've personally never called the cops on a bad driver, although I would if I thought it was a drunk. But otherwise...I don't know if it would make a difference. They can't do anything on hearsay.
    Seriously more of the "elderly," careful drivers around here have Kias, Hyundae, CTSs, and larger BMWs. The Kia and Hyundae brands seem to have replaced the American brands for many elderly. What's interesting is that they aren't gravitating to Camry and Accord on reputation.
    Their slow careful driving is good. I can't tell if it's poor eyesight or fear of driving that makes a few people go so slow. But they are inconsiderate because they will hold up traffic by driving dangerously below the limit. Right hand lane on multiple lane roads and going slowly I can handle. You said the Caddy was in the middle of the freeway!!!
    A good friend in Tennessee won't hop on the interstate to drive to edge of Nashville or south to Murfreesboro for shopping. She doesn't like to drive in the speed atmosphere so she uses the local highways. They live 1/4 mile from I-26... She's being considerate. Others should do the same.
    Around here it is Buick and Caddy, Avalons, etc for the mass market, and of course a few in big BMW and MB and LS. I am pretty sure I have never seen anyone under 60 in a Century that wasn't a rental. I think the larger cars actually attract a younger driver. Not that that's saying much.
    I can't call driving that doesn't keep up with the flow "good". Especially with bad lane discipline. It's no less dangerous than having a wide speed differential the other way. If there is one thing that needs to be preached in drivers ed, it's that It is not encouraged enough. Like that Caddy...I bet the driver had no clue of what he was doing.
    It's funny...around here, I often avoid the highways for local errands simply because there are so many idiots out there. Strangely enough, I see less stupidity on city and suburban roads. It's a much more relaxing journey.
    And a funny inconsiderate driver rant from Craigslist
  • coldfootcoldfoot Member Posts: 49
    I was driving on a 2 lane road a few weeks ago and I saw a oncoming car awerve into my lane. She ran me totally out of the road. I had to do that to avoide a head on collision. Well she was reading a book. Now aint that something to get your gander up?
  • euphoniumeuphonium Member Posts: 3,425
    1955 Chev 2 door, 2 tone black/yellow = 210 delray. Remember it well.
    Any driving action that increases the chance of filling out a form afterwards is a no no. It just isn't worth it.
    Onramp to the three lane freeway - the guy behind accelerates to pass you before the white line ends moving to his left. That's when it is tempting for me to do the same, but then I remember it's not worth filling out a form.
    I have no criticism AT ALL for the Buick driver in this situation. He or she was simply going slightly slower than I anticipated, and that in turn enraged the driver behind me for waiting "too long" for the Buick driver to pass through the intersection. At least that's what I assume because he (driver behind) tooted his horn at me.
    As I said, I probably could have safely pulled in front of the Buick, but chose not to. Even if I had gone, Mr. Impatient behind me would NOT have had time to make a full stop and pull in front of the Buick without forcing its driver to slow down or even brake, a clear violation of the yielding the right of way.
    I just made a general comment that Buicks are often driven by older people, and older peope in general tend to drive more slowly.
    Thank you, I feel better.
    I've had all kinds of cars driven by elderly people, BMWs, Caddys, Chevrolets, Accords, lots of Camrys, pull out in front of me at intersections where they had a stop sign. They either don't see the oncoming car (it has DRL) or they don't perceive speed of approach or they just figure I'll have to not hit them!
    Occasionally happens. Women, men... Scary.
  • black_tulipblack_tulip Member Posts: 435
    First, let me congratulate you on your writing skills. The surroundings and the emotions involved come across quite clearly and precisely from your description.
    I have been in some of those situations where sometimes I have even played the role of Mr I when at one time, it seemed that the driver in front of me would not budge from the stop sign without a written invitation. Anyway, I completely understand what you did but at the same time urge you to keep your cool next time. A crash risk is never worth the small amount of satisfaction you got.
    Thanks for the compliment. I write/edit as part of my job duties, so I guess I'm trained in that sense. Plus I've been on vacation for a week and that allowed me time to summarize the incident in my mind before I posted it.
    Yeah, I sometimes toot my horn at people to get moving -- a notable example is the traffic light closest to my home where the left turn arrow is short, which normally allows only 3-4 cars to get through. If there's nobody in the next lane intending to go straight, then the all-green light never comes on, and you're stuck waiting for an entire cycle. So I do toot if the person in front doesn't move.
    I agree with you totally about keeping my cool, and I almost always do so nowadays, in my older, mellower years.
    It's interesting to speculate (after the fact of course) what would have happened if Mr. I. had crashed head-on into an oncoming car. Though not likely, because the road was straight at that point, and I would have pulled off to the right to minimize the chances of that happening, what would Mr. I have said to the police officer (if he survived)? "Uh, officer, I was trying to pass this car in a no-passing zone, and he wouldn't let me."
    I could feign complete ignorance, saying that I simply accelerated fast out of the intersection and didn't even realize Mr. I was in the wrong lane. After all, I don't believe his front bumper ever caught up with my rear door handle.
    And the oncoming driver probably would have focused only on the car headed straight for him, not on me.
    Since I was taught that the horn is basically and emergncy-only tool, I hardly EVER use it. Thinking about it, I can't recall the last time I used the horn on the road.
    Using the horn to get the wife or kid's attention, or saying goodbye when leaving doesn't count:)
    How much of a horn blower are you?
    A) a leaner - at least once a day, usually to make a point
    B) a blaster - hitting the horn as the guy cuts you off
    C) a tooter - using your horn as a non-emergency communication device:)
    I'd like to think that I use the horn only for emergency situations, but occasionally I fail and give in to impatience. But generally, other than pure emergency blats (as in "I'm already in this lane and you're going to hit me if yoou keep coming over!) I use it in only a few situations, such as:
    - If someone is waiting to turn out of a side street on my right into my path, and is (a)not looking at me, and (b) is rolling, they will get a short "Look At Me" toot every time.
    - If someone is asleep at the wheel at a light that turns green, after 3-4 seconds the car behind owes a short toot to wake them up.
  • hercules00hercules00 Member Posts: 134
    I almost never use the horn. I may have used it maybe 7-8 times in my driving career till now, mostly for morons who cut into my lane without checking into their rearview mirror. Otherwise, I have not really felt the need for it. I am also kind of patient for the people in front of me at stop lights. I never honk.
    Interestingly, honking is also definitely a regional phenomenon. I never get honked at where I live and drive (Richmond-DC). However, I am always in shock whenever I go to Jersey City/NYC. Over there people honk even if you stop at a stop sign!!!
    One frequent kind of inconsiderate drivers I come across are those who will leave their headlight beam on high. The ones coming at you are easier to handle, you flash once and they mostly dip and even if they dont, they are gone pretty soon. However, what do you do with the ones in your direction right behind you? The internal mirror has the auto-dimmer (plus my spoiler is shaped such that it almost always cuts off the headlights) but the exterior mirrors do not have them. Is there some way you can tell these people to turn down their lights (other than having a searchlight fixed to the back of my car which I can direct at the driver's face, but then I may risk the chance of getting shot at :) ?
    I say let em get in front and of course return the favor. :(;)
    I usually only honk to wake someone up before they plow into me, or if someone pulls out from a side street and causes me to slam on my brakes. If someone is snoozing at a light, I'll flash my lights before I honk.
    I too tire of the high beams people...do they not have a blue night on their dash? Even my fintail has this I also tire of tall trucks and SUVs with lights aimed too high.
  • xwesxxwesx Member Posts: 17,959
    hahah.... Okay, I am behind the curve here (just now reading a July 4 message), but one of the few times I have been pulled over was when I WAS pulling a trailer!
    I was driving my father's old '79 F150, pulling a car dolley with a '74 pinto wagon loaded on it. I had driven to Roseburg, OR from Helix (Pendleton), OR to pick up the wagon after my brother had driven it to college and it threw a rod 10 miles from school. The trailer was in the midst of an overhaul and did not have tail lights on it. Sure enough, at about 1830 after the sun had gone down, I was pulled over on I84 about 20 miles from Pendleton. I am sure I was quite the sight with a menagerie of old vehicles putting along at 50 in a 65. The OSP officer was probably so befuddled that someone with an Alaska license, driving an Oregon truck, would bother to drive 250 miles away to nab a '74 Pinto and take it all the way back to Pendleton that he let me off with a warning.
    I knew I was going to get pulled over at some point, too. I was just amazed that I made it to within 35 miles of home before it happened. Unfortunately, there was no time to fix the trailer properly before heading out. I was scheduled to fly back to Alaska early the next day and if I did not get it then, my brother would have had it taken to a scrap yard. Ah well, the fun little memoires... :blush:
    Don't follow gravel trucks and if you drive in Alaska, don't be surprised to need a new W/S when you get home.
    Hahah! Amen to that, euphonium.
    In my '96 Subaru, I have driven about 105K miles in the last 5 years, 99% of which were accumulated in Alaska. I have 18 chips in the windshield (mosquito-sized or smaller), but have yet to need it replaced. Most folks are lucky to last more than a year or two without a crack that requires replacement.
    Maybe road hazards are fairly common everywhere, but I am amazed at some of the things I see scattered about the roadways up here..... water tanks, pallets, sheets of styrofoam, tires, RIMS, garbage cans, water cans, random building materials, you name it. :sick:
  • hammerheadhammerhead Member Posts: 907
    Bob- A couple summers ago we had both inside duals let go on the motorhome within 150 miles of each other - the first with a big bang, the other only marginally less so, but both were loud & clear as to what happened. I'd guess with so many tires on a semi trailer, one going away might not be noticed, but we sure knew about it on the bus!
    Cheers!
    Paul
    Well said. I had a similar (somewhat) situation to the one that 210delray recounted. Earlier this summer (late April, I think), I was headed to a friend's house at about 2100 on a Saturday evening. The sun was still up and bright in the sky, and I was on a two lane, 55 mph road, just about to turn right (with my own turn lane) onto a two lane, 50 mph road with nasty frost heaves and a curve not far beyond the intersection. As I was slowing for the right turn, I see this little blue Corolla (odd, isn't it??!) barrelling down on me pretty fast, but still 10-12 car-lengths back. I make the turn and begin accellerating to 55 (yes, I'm bad.... I usually drive 5 over if conditions are good). I glance in my rear view to assess the location of the Corolla.... assuming that he made the turn since he was in the turn lane.... and there was no car there. Puzzled, I figure that he must have made an "oopsy" and continued straight.
    As I glanced in my two side views out of habit, I caught the Corolla out of the corner of my eye..... in the other lane, trying wildly to pass me! I briefly thought it was a little funny that I was not even trying to make speed quickly, and by the expression on his face, he was really determined to pass. I immediately thought of how idiodic his maneuver was, considering that I was bound to accellerate out of the turn and because a blind corner was just up ahead. Sure enough, at that moment, a car appears ahead of us. I had reached 55 at this point, and the Corolla had pulled even with me, but still needed to get another 20 feet or so ahead of me to pull in (without literally cutting me off). I briefly thought to brake and let him in, but then wondered what would happen if he did the same thing? I decided to do nothing out of the ordinary. After all, he had put himself in that situation, so he could do the evasive manuevers. He braked, whipped in behind me, then immediately passed again after the car was past us. Again, on a blind curve with a second blind curve just up ahead.
    He made it, and I am glad for it because if something would have gone awry there... there were steep banks and no shoulders to allow for decent manuevering should it be necessary.
    I wasn't upset about it because he had done nothing to really affect me, but I had never seen someone try to pass right on an intersection like that. It seems like an unwise move and while I did not make an effort to stop him, I wasn't going to make an effort to accommodate him either. I just behaved as though he was not there while preparing in case something unexpected happened because he was there. :surprise:
    If the item falls off the truck and hits your windshield, it's theirs; if it is an item on the road and the wheel picks it up and throws it, it's not the truck's responsibility.
    Trucks around here have signs trying to imply they're not responsible for items that fall off their truck, but the wording is actually that they're not responsible for items the tire kicks up.
    Either way a good practice is not to be behind trucks with dual wheels that kick up a lot more of the road trash...
  • marsha7marsha7 Member Posts: 3,703
    Years ago an old friend of mine installed superbright airplane landing lights on the back deck of his car...you guessed it...when someone would not turn off their brights, he would flash them for 1 second as a wakeup call...if he needed to do it twice, it was not easy for the driver in the rear to see...somewhat drastic, but it is what I wish I had for these idiots...
  • grbeckgrbeck Member Posts: 2,358
    Go to Manhattan...the horn is apparently an essential part of a driver's tools. I believe that if drivers couldn't use their horns, traffic would grind to a halt.
  • mark156mark156 Member Posts: 1,915
    I honk only in tunnels! LOL.... I love the echo!
    People driving with their bright lights on drive me crazy! Isn't it funny, that it seems to always be a General Motors car with the brights on! I'm not trying to be prejudice, but the person driving seems to be a little on the "older" side.
    The cars that I drive, the high beam control works by pushing the turning signal indicator lever out..... GM has a problem because the turning signal is like a switch, you click it inward to turn on the high beams and click in inward again to turn them off. Apparently, it must be easy to turn it on without realizing it because I see so many driving with the high beam on.
    Mark
    2010 Land Rover LR4, 2013 Honda CR-V, 2009 Bentley GTC, 1990 MB 500SL, 2001 MB S500, 2007 Lincoln TC, 1964 RR Silver Cloud III, 1995 MB E320 Cab., 2015 Prevost Liberty Coach
    Are you talking daytime or night for the high beams? Can you describe better when you see this problem with cars... especially GM.
    I've not found any problem with pulling the turn signal switch toward me to operate the low/bright switch. It's been that way since my 77? or 80? Cutlasses.
    GM cars in some cases used the high beam lights with reduced voltage for the Daytime Running Lights. Some of those are a little bright--but people do not have their brights on.
    The Only other extreme I can come up with is that automatic rain-sensing wiper systems on GM cars are set so they turn on the headlights to comply with some states' laws that you must have headlights on when you need the wipers. The cars have the headlights on even though the wipers are not sensing water on the windshield. People don't realize the regular headlights are on and they may have the headlights in bright position. It's daytime and people expect the DRLs to be working, not the headlights. I discovered it about 6 months after we had the car.
    I think Mark is suggesting that GM's switch can result in some drivers inadvertantly turning on hi-beams when operating the turn signals.
    GM uses a toggle requiring the same 2-step motion (pull stalk, release) to raise hi-beams as to lower them. By contrast, the hi-beam switch in many other cars, like my VW, is a 2-position stalk, toward the front for hi-beams, toward the rear for lo-beams. It is simpler to operate, with only a single step (flick it forward for hi, pull it back for lo.)
    Actually, in my personal experience I have found the reverse to be true, with the 2-position switch more prone to inadvertant hi-beam operation. While I always found the GM-style toggle annoying to operate, it requires a more positive action, and is less prone to inadvertant operation.
    Thanks. I wasn't sure if some people got their brights on during the daytime because of the automatic rain-sensing wiper setting or it they had extra bright DRLs.
  • andre1969andre1969 Member Posts: 26,120
    with regards to the high beam switch, but when I got my '76 Grand LeMans, which I think was one of the earlier GM cars to have the switch on the turn signal stalk instead of the floor (regular LeManses still had the bulb on the floor), I found myself accidentally turning on the high beams when I'd try to signal left or right. It's the type you pull back toward you, which is no different from the Chrysler products I've had, but on the LeMans it seems much more sensitive than, say, my '79 New Yorker. They might've improved them over the years, though. I actually don't remember having a problem with the high beam switch on some of the newer GM cars I've had, but at the time when I drove them regularly, I was probably just more used to them. The newest GM vehicles I drive on a regular basis these days are my '85 Silverado or my uncle's '97, but I can't remember the last time I drove either one at night when I'd need high beams.
    As for DRL's, I don't know if this is the case any longer, but when they first came out, they operated the high beam at 60% of its normal power, which, while not as bright as 100%, is still much brighter than your normal low-beam. It was common for people to run around with their DRLs at dawn and dusk, when they should have been using their normal running lights. So they'd end up blinding oncoming traffic and drivers in front of them, yet their taillights would be off so people behind them wouldn't see them until it was often too late.
    I think the DRLs are designed a little more intelligently nowadays, but back when they were still fairly new I wouldn't be surprised if they caused as many accidents as they prevented!
  • li_sailorli_sailor Member Posts: 1,081
    I assume this is in jest, but...I work in Manhattan and although I agree that horns are used there more frequently than anywhere else I've been, it's almost entirely of the useless impatient prodding variety. Also illegal, and I often observe traffic cops admonishing offenders that it is meant for emergency only.
    I disagree, it would have little effect on traffic but it would certainly be less annoying if it was curtailed.
    Again, this is illegal. It is required that one dim their brights for oncoming traffic. I was once pulled over when I (may have) forgotten to dim them...this was near the end of a late nite 200 mile drive where the last hour is on a 2 laner where I had been flipping them on and off frequently. I got no ticket, my SO convinced him he was mistaken or my lights malfunctioned (she's very convincing :) )
    I find almost all offenders dim them when you flick your brights to remind them. to those that don't, I keep them on when reciprocation is not forthcoming.
