Lifespan of struts
                    Just curious to what you think the typical lifespan of a set of struts is.  I have a 94' Civic EX that I just purchased, it has 94K on it.  Even though the car does not have excessive bounce or feel like the struts have blown, it does ride rough.  What is the typical lifespan of a set of OEM struts?  What would be a typical repair bill be to have them replaced.  I could probably do this myself (I have a factory manual and am quite mechanically competant) but feel that air tools would probably be necessary to do this.
Type of driving, cornering, starts, stops etc. all contribute.
Shocks are speced at so many pounds [100-250] of pressure to move 1 ft per second [most shocks have less than a 8" to stroke [+- 4" when mounted under load]. The expansion resistance is usually twice the compression resistance. Pretty hard to lift up on the body [center of front bumper] with 500 pounds in a 3rd of a second smoothly. Same with pushing down except the springs are compressed so you need to exert [150 x3 x2 plus the 500 pounds for shocks...roughly 1400 pounds in 0.3 secs.
Know any human that can do that?????????????
The old fashion push and watch the bounce only tell you that they are way past worn out!
Generally they are down to 50% of new firmness around 40-50,000 miles.
Obviously a lighter car needs lighter shocks function of spring stiffness!
hudrahead
Yeah the franchise places can be very rapacious-some actually squirt oil on the struts-see it is leaking gotta be replaced. Another favorite is to cut the CV boots. Be careful out there-thieves abound.
My experience with shocks is about 50,000 normal for shocks, and 80,000 to 100,000 on struts. Street driving only. Very little time on dirt roads.
The bounce test on struts is really unreliable. Watch for leaking, wallowing over a bump when vehicle is heavily loaded in the back, or a lot of little visible bounces on concrete roads
The bounce test is pretty reliable for shocks.
But the car drove quite reasonably. I was quite surprised. I just didn't know that you can drive for so long on the same struts.
They pass the bounce test, but that's just for basic safety and I prefer my car to have much crisper handling than that.
If I decide to keep the car and have some serious suspension work done (CV joints and/or axles) in the coming year, I'll have them replaced with high-performance units.
Does anyone think it makes a difference whether you have a strut-type suspension versus one with A-arms (wishbones)?
--- Bror Jace
Do you have new [not worn out 1/2 tread or better]OEM tires at the correct psi.
95k [7-8 years] is a long time to keep the same shocks on a car. I assume you are planning to keep the car another few years so why ride in misery!
Bror Jace, my impression is that your Honda struts are just as difficult to evaluate as are MacPherson struts. Like you, I am faced with replacement on a 92-95 Civic. OEM struts are very expensive but apparently wear rather well. Can you suggest a brand that provides control at least as good as OEM at a lower price? Thanks.
I'll probably go another 10 -- 15 on the front ones, and 20--25 on the back.
My problem is that after changing the struts on my Mazda I know how smooth new ones feel.
Yettibutt, I have had good luck with Monroe Sensatracs on large cars but, like you, would like to hear from others regarding these on the Honda Civic.
Leo
With struts the bounce test aint worth squat. Nada. The struts have springs which can absorb the bounce all by themselves. I've seen new cars that bounced more than my Mazda did, yet the Mazda Struts were bad. All 4.
Better tests are wallowing and most certainly leakage.
Leomort. To me the biggest factor is the ride. When the struts were replaced on the Mazda it rode better than I have. My KYBs are softer for the normal bumps, but absorbant and firm at the same time on rough roads. I can't believe the difference a premium shock makes. The car is sporty yet comfortable. The High end Gabriels and Monroes are supposed to be good as are Bilsteins, but the only premium ones I could get were KYB. If you want to dump it at 200K certainly take the rough ride for a little longer.
probably keep the car until Fall 2003. At which time it will have about 225K. If the car is still mechanically working, it will be relagated as a third car.
I'll call the Toyota dealer and see what they said about how long their struts.
What do struts usually run $$$$
Leo
You might want to consider replacing only the front ones. You will enjoy the comfort at a lower cost. I did mine in pairs front one year, and back ones a year later. No major problems.
Talk to the Toyota dealer. They don't really have a recommend mileage replacement for struts. Only when the car starts to ride rough or they start to leak. Cost per strut is around $125-135 + $90 labor to put them in.
Leo
When new struts are put in you almost always also need new dust boots and top insulator (big rubber composite washer between the strut mount and body). In almost all cases replacing the front struts changes the wheel alignment, so that has to be done. Even with air tools and a lift it can take several hours to change struts.
Leo
Can anyone say if it sounds likely? Shifty?
sgrd0q "Acura RSX Problems & Solutions" Mar 23, 2002 9:10am
I'm not sure how your car is aligned, if shims of some type are used, but these can sometimes fall out and cause a similar type of noise. As for the struts, usually they kick up a fuss louder than a click.
The ride and handling were still fine and it passed the bounce test. As far as I could tell, the ride was fairly equivalent to the 2002 Subaru Legacy L I test drove. (I ended up buying the Outback wagon though.)
I last had the car fully loaded about a year ago when I moved and it did just fine with the loads, although the engine kinda groaned a bit under it.
If the automatic transmission had held out, I'd probably have gotten to 200,000 on those struts. Or further. So there ya go...
My outback sport has 115K miles, and was just in for service where I asked them specially to inspect the struts (I am pretty sure it is struts all around on that car) and they said they were no problem, no need to do anything yet, and those struts are the originals. As for the feel, it is hard to say...I think it pretty much drives like it did when it was new, but I know since I have been driving it since new, and the process of strut decay is so slow, I would probably not notice if they were getting worse. I have not yet looked into the cost of replacing them, but I have been thinking about doing so, and figure it would cost about $800 installed to go with OEM. Sound about right?
