Opinions on the Crown Victoria Police interceptor?
I am seriously thinking about getting a 1998 Crown Victoria With police interceptor package. I have seen lots on ebay and they are dirt cheap and in awesome condition. What are your opinions on these cars and what is common as far as repairs and defects.
there is also a long line of cab companies and some private buyers in line to get the few "police specials" that are sold because once rehabbed (but then, we have all followed cabs that are fogging mosquitoes with their exhaust) they are very solid vehicles that take a lot of abuse and keep running.
so... short version... unlikely you will get a cream puff. likely you will have to sink a lot of bucks into the car to get it into top shape. but if you do, there is a good chance you can get your money out of it over time.
This is why many states require disclosure of any vehicle used in police work, to protect the consumer against buying these basically beat to hell machines.
If someone has rebuilt one, and can prove it with documents, you might take a chance, fine, but don't pay too much because when it comes time to sell, you won't get many takers.
The problem is the idling, even at 100k odometer the tranny and engine may have the equivalent of 300,000 miles!
When I bought the car, it looked almost brand new. It had been repainted, cleaned up, guaranteed that everything worked, and guaranteed to pass inspection. Right now, it's sitting dead at about 117,000 miles. I think it's the starter, but I'm not sure. Drawing from memory, here's what I've had to put into it...
10/98: New Starter/radiator hose
12/98: New fuel pump
02/99: New belts, valve cover gaskets, front oil seal
02/99: New starter (I delivered pizzas back then, and was rough on 'em, I guess!)
02/99: New tires/alignment
04/99: New front brakes
06/99: Two new power window motors (both left-side ones...failed at different times, but when the driver's side failed, I gave in and fixed 'em)
09/00: New front brakes, freeze plug, service tranny
10/00: New radiator
04/01: New heater control valve
01/02: New distributor
This thing was pretty well-equipped for a police car: power windows/locks/mirrors, tilt wheel, AM/FM/cassette stereo, cloth seats, interval wipers. Everything still works on it, too! Well, except for the starter, that is ;-)
Cars are machines, they require maintenance, whether we get it done or not, and sometimes things break. Heck, even copying machines require technicians to fix and adjust them weekly or monthly - they don't even go down the road in inclement weather!
Officer Friendly then gets a code-3 call for a medical assist 12 miles away, and he puts on the gumballs and screams over to the Weak Arms Apartments and spends the next 30 minutes helping the fire or ambulance guys deal with an overdose or a heart atttack. yes, the cop car is idling and locked.
it's then time for the Donut Hut, and the car idles while the three shift officers select some dainties and guzzle coffee.
you get the idea... cop cars are running in idle a lot of the time. building up carbon, moisture in the oil, the alternator loaded by the laptop, five radios, the radar set in standby, the siren set in standby, dome light on, and so forth.
it isn't that one cylinder of 8 fires at 500 RPM, it's that the car spends 7-1/2 hours running per shift, up to half of that in idle, some of it running flat-out, and the rest stop-and go....... then the next cop gets in, and maybe on Tuesday the engine will get shut off for an oil change.
So I'm guessing that either they just missed my car somehow, or police cars in general, just fall though the cracks. It does make sense, though. For instance, my Gran Fury has a 4-bbl carb and about 35 hp more than a civilian M-body that year, and enough beefing up to bring the already marginal mileage down to horrible levels. That's probably the main reason that the general public can't buy a police car...because it can't pass the emissions test! Similarly, Ford and GM offered 351's and 350's in their police cruisers, although the civvy models back then only had 302's or 305's. This may be a myth, but I've also heard that a few 454's made their way into the 80's Caprices.
So my guess is that these vehicles were not designed to pass the emissions test, their VINs were never put into the appropriate data bases. Or, I could be totally wrong here, and my case was just a fluke!
Check it out here: http://www.mercuryvehicles.com/vehicles/marauder/
Other law enforcement agency vehicles might be a different story. Highway patrol cars last more miles, as they are driven a lot of miles every day, but by one person, and should be well cared for. But even then they are subjected to high speed chases on occasion. I think I would stick to a program car or just buy a low end new car if I needed one.
0-100 is 17 seconds; [0-130 takes under 32 secs] and top speed is 152-153 mph and stops in 129 feet from 60.
No matter how much money you sink into that fancy Nissan, you're never going to get the feel of a RWD(pos trac) V-8 cruiser.
q45man-The idea is to get a ready to go heavy duty car, do a little overhauling, like around $300 to $400 for replacing nessesary running gear, like steering parts, suspension parts, and tune up. Not going out and paying big bucks for a car that need all the performance mods that you speak of to drive the total cost up to around $16,000. In reality you can go to a government auction and get FBI cars that were used by agents, not police departments, and they have all the same features of the regular police cars with out the ragging the cop cars get. Average auction price is around $11,000 for a 60K mile car that isn't all dogged out.
The 94 Q45 is a RWD Viscous Limited Slip [3.55 diff] All aluminum 32v V8 [ 278 HP/300 torque STOCK] with 5 arm independent rear suspension.
You missed the point that without the mods [new Tokico shocks cheaper than oems], the sway bar $50 from a junk yard, etc... the $10,000 used 94Q way out performs even the 2003 [planned] Crown Vic in all respects !!! and has a much longer more durable life.
http://nlectc.org/testing/vehicles.html
See " Michigan State Police test 2002 vehicles" under publications on right of page.
They compare Crown Vic, Impala, Camaro, Intrepid Police cars. 60 pages in pdf ..accel, braking, handling wet and dry. NONE make it above 127 mph with a tail wind [except of course the Camaro].
Makes you ill to see how BAD most are.
The CV stopped in 140 feet. CV 0-60 8.42 secs
Compare to the 94Q 0-60 7.4 secs, 15.4/93mph in quarter and a stopping distance of 129 feet.
Both the CV and Q weigh in at 4040 pounds and the CV has 5 more cubic inches of engine [4.6 vs 4.5 liters] the CV does have a 3.27 rear diff vs Q's 3.538 yet the CV get 1 mpg worse city EPA mileage. Both get the same on highway averaging combined is worse for CV by 1 mpg!
For details see the web site linked in previous message.
The point about 1 mile 0-120 mph CV acceleration is that if you are stupid enough to run you have about 30-60-90 seconds to hide while he's catching up. Or a trunk full of James Bond goodies.
These are 0-60 and 1/4 mile times for '89 model-year cars. I think the times were with two people on board...
Caprice 350 TBI: 9.82sec and 17.62sec at 79.83mph
Gran Fury 318-4: 11.77 and 18.63 at 76.20
Diplomat 318-4: 11.84 and 18.79 at 75.53
Crown Vic 351VV: 11.98 and 18.86 at 77.05
Mustang 302PFI HO: 8.60 and 16.59 at 87.03
Gran Fury 318-2: 14.98 and 20.23 at 71.55
Here are the top speeds, as well, with 2 people on board. For one officer, add 5 mph.
Diplomat 119 MPH
Gran Fury 120 MPH
Caprice 122 MPH
Crown Vic 119 MPH
The Gran Fury with a 318-2 maxed out at 113 mph with two officers aboard.
IIRC, the hp ratings for these cars were: Caprice: 190, Crown Vic, 180, Mopar 318-4: 175, Mopar 318-2: 140.
Just out of curiosity, does anybody know how much weight all the police equipment adds to the cars, in general? For example, if my '89 Gran Fury weighs about 3500 lb (the title said 3505), then how much would one weigh with all the junk they throw on it when the Michigan police dept does their tests?
Friend of mine bought an old cop car from Fairfax, in Marin County, and stuck on the back cage was a little label that said "Thank you for not smoking".
Isn't that hard to do anyway with cuffs on?
