Spark Plug Wires
How long do they last? Does it depend on the make and model of the vehicle?
Is it necessary to change them for every tune-up?
My car needs a tune-up really soon (165 000km) and I was wondering if it's a good idea to change them.
adc100 is right on in his estimate for service life on plug wire harnesses, IMO.
--- Bror Jace
This topic will self extinguish as fewer and few cars are made with plug wires due to emission requirements.
I thought I could stretch the plug wires longer with the "lifetime warranty" wires but when I tried to remove them, 2 of the 6 wires pulled out of the boots. Now I just buy the standard grade replacement wires knowing that I will replace them in 3-4 years.
I changed the wires on my 1996 Camaro this past winter. The wire set was $75 (Moroso Blue Max), and I, of course, did the labor. In order to access the wires, you have to drop the front end of the exhaust system, and the shop manual says to remove the power steering pump. I opted not to remove the pump, and all together the job took an agonizing 5 or 6 hours. Absolutely NOTHING is readily accessable on that car. Good thing I wasn't paying for the labor !!
I took my dads '96 Lesabre in for a tune up, an oil change, changing of the spark plug wires and replacement of the pcv valve.
The Total was around $400 cdn. SO DAMN $$$$. My friend told me that I got ripe off and it would be cheaper if I had gone to a independant shop (very hard to find a reliable one) But this is a one time thing since I don't need to replace them for another 150 000kms.
seriously, in US$, I would expect a dealership computer-assisted diagnosis and tune-up on a recent car to suck up
$80-120 diagnostics
$30-40 spark plugs
$40-60 wires
$5-14 PCV valve
2 hours labor (call it $48/hour here)
and you'd still get a little ripped off on the parts, but not seriously. if you snap open a cold one and diagnose the car yourself with the tested ShadeTree Evaluator (yep, there's an engine under the hood, har har), using factory parts would cost something like
$10 spark plugs (from local chain parts house for the factory's own plugs)
$20-50 factory fitted plug wires (depends on source)
$4-7 factory PCV valve
1 box bandages about $2.50
1 tube Neosporin or similar antiseptic about $3.00
1 police fine for the neighbor calling about the cussed-blue air $50
and of course, if the ShadeTree Estimator didn't catch other parts and adjustments failed, extra costs at the dealer.
why the difference? your dealer does not get parts from multiple sources, and the factory parts department sticks them for a number of service replacement parts. the dealer's parts man has his "adder" for parts department profit, and the service department charges a flat rate programmed into the computer that often provides an "adder" for profit there. they may or may not charge the Mitchell's number of hours, depending on how badly warranty reimbursement hacks them, but they will make up the difference somehow.
the major cost difference is usually the computer diagnostic required for a successful tune-up nowadays. they might stick you double for the parts, depending on how evil the distribution chain is and whether that dealer wants after-sales service business, and the labor charges are usually required to be posted by regional laws.
the rest might be real and "pretend" exchange differences between $CDN and $US, which out of $400CDN, I would expect to be in the $100 range.
Is he telling the truth? Are they worth upgrading given their exceptionally high asking price?
OEM wires are almost always good. NGK makes excellent replacements. Big buck, exotic wires are a waste of money with a stock engine.
I have been having problems on my 5.7L chevy truck engine. I replaced all my ignition components last fall because of low power and arching of wires and coil. All was fine untill recently. I checked the wires again and I had one that was arching which was replaced.
I checked the wires again last night and although none were arching at idle, when you touched and moved the wires, they would arch. These wires only have 3,000 miles on them. Is this normal or are my wires shot?
Wayne
Wayne
fleetwoodsinca,
I'm positive I have the correct plugs with the gap set to factory specs. The coil was new but that doesn't guareentee that its not bad.
By the way, I used to sign on to Edmunds as wtd44. I noted along the way that you were a VERY close username, and to help keep ID's easy to ascertain, I switched to Fleetwoodsimca. My decision to do so was aided by a need to reformat my hard drive and reinstall my software! For good measure, I changed ISP's at the same time...
I really like my Accel Thundersport wires for imports. Mine were fairly cheap at around $40 for a Honda 4-cylinder, they look nice (3 colors to choose from) and have only 150ohms resistance (if my memory is functioning correctly this morning).
I'll replace them again after 70,000 miles or so (maybe one more year). Still, they look brand new and it'll be hard to throw the 'old' ones away. <:^(
--- <b>Bror Jace
BTW, NGK also makes very good wire sets.
Brucer, most sets will say if they are for the street or not. Taylor sells sets of wires that should not be used on the street. I'm pretty sure wiring with a resistance of 150ohms per foot is street-legal. I've had no problems with radio interference in the years I've used my Accel Thundersports.
Yes, you shouldn't use "race" wires on the street for the reasons you mentioned.
--- Bror Jace
My theory is that older engines, especially flathead engines like the ones made by Briggs & Stratton for lawn & garden equipment are spark-plug friendly. Even when these get fouled, a quick trip under a wire wheel and they are fine.
Some engines, especially newer, hotter-running motors actually wear away the electrodes but if the electrodes aren't worn and using a piece of fine-grit sandpaper you can easily get the electrodes down to bare metal.
Is that cleaned spark plug going to work as good as a brand new one? What else could be wrong with an old plug whose electrodes still look sharp necessitating its replacement?
--- Bror Jace
Those were the dayyyys!
For our lawn & garden equipment, I find myself pulling plugs and cleaning them often. These machines sit for a year at a time, sometimes and when trying to start them after the've been still for half a season or more is tough. (especially the older ones) They tend to flood initially and they'll never start unless you pull the plug and clean the carbon and gasoline off it.
Anyway, we have an old Jari sickle-bar mower that is easily 30 years old and uses the ubiquitous CJ-8 in its B&S 4hp motor. I got it out of the barn where it was about 35F and it would not start as I predicted. I let it sit in the bright sunlight and warm up to about 70-80F for nearly 2 hours. I also changed the sparkplug ... but only had a slight newer one from a newer machine.
The machine fired right up. There was some discussion about what worked, the warmth or the newer plug. I think the warmth ... but I got new plugs for both machines anyway.
--- Bror Jace
I just think that if the plug isn't damaged or worn, it should not be much of an issue.
--- Bror Jace
The best way to clean a plug is to use a cleaning agent like carb cleaner. But then, as much work as it is to get the things out, I am reluctant to put the old ones back in. The platinum plugs are expensive, but so is my free time.
Seriously, thanks for the info. I thought the ceramic insulator might get damaged over time and my lil bro' swears that he's gotten bad plugs right out of the box for things like chainsaws, etc ...
Now for the brand wars: I've used a number of different plugs in my Honda and NGKs work the best (most MPGs). I lost a touch of mileage with original Bosch Platinums and haven't been able to take the plunge and pay for their +4s ... but they do look neat. >;^)
I bought Split-Fire plugs once. Never again. I had them in my car for 3 weeks, noticed no improvement and sent them back for the promised refund (and I got it). After only 3 weeks, the plugs had already started to corrode significantly. I don't think I've ever seen a cheaper-made plug. <:^(
--- <b>Bror Jace
1) The plugs are made cheaply. The lack of resistance to corrosion was apparent after only days. I can just imagine leaving these in for a year or more ... especially during the salted-road season.
2) The spark probably jumps between the center electrode and only one of the prongs of the side electrode. Assuming this is what happens, it makes this plug no more effective than any other.
The Bosch +4 looks awfully neat but I hate to spend a lot of money on the unknown. Also, I wonder how do you measure the gap on a plug like that? Is it easy to adjust? CAN you adjust it? I'm also a little gunshy about spend more than $2-3 on some 'wonder plug'. <:^(
Like I said above, I've found nothing that gives me better MPG than the factory spec NGK V-Power plugs. And, at $1.99 each, I can change them every 25,000 miles with no trouble at all.
I was in an Advance Auto Parts today looking for NGKs for our Honda tractor, etc ... but they didn't have any. I was going to pick up some CJ-8s and RJ-17LMs for our other machines. The store had a display featuring all of these common plugs so I picked up and handful and headed for the checkout.
Little alarms were ringing in my ears and I couldn't figure out why ... at first. I looked at the packaging ... Hmmm, Allied Signal. Hey, aren't those the guys that make P.O.S. Fram filters? Yep. I put the plugs back on the rack and walked out the store. Maybe I'm just a miserable b@$tard but I wasn't gonna buy them. Nope, not on that day.
--- <b>Bror Jace
I asked the guy at Advance Auto who had a direct pipeline with a test engineer at Bosh who of course indicated that the +4 was the 7 the wonder of the world (or is it the eighth). Anyway, I asked if the spark only jumped one gap at a time. He indicated that he saw a film where it jumped more than one gap at the same time. Can't swear to that though. Also I believe the +4's are used in Nascar circuit. I'll try to find out. If they are used here they must be good.
Later,
Al
In the past year or two, Champion Sparkplugs have had a renaissance and are (at least in some applications) quite impressive. The story I have heard is that they quit listing applications that were "close/close enough" and did a lot of direct vehicle testing and came up with many, many new specs and plugs. I replaced a set of 4 original equipment NGK's with Champions in a Kawasaki Vulcan at 4K miles, and was shocked by the improvement. Yes, this is anecdotal and proves nothing, except that the Kawa engine liked the Champions...
Theoretically it keeps the gap constant because it has multiple electrodes to wear down instead of only one,,,these days most platinum plugs last a LONG time as it is.
Rando
I have not heard anyone say the splitfires worked well
It was greatly noticeable if you changed the original bosch mutiple electrode plug with their conventional plug the performance diminished the dealers and those who worked primarily on german cars would always insist that you use the oem multiple design bosch had rather than the conventional bosch plug
