GM 8.1L using up too much engine oil
have a gm 8.1L engine that uses too much engine oil
1st 5,000 miles 1 quart of oil, 2nd 5,000 miles 1 1/2 quarts of oil, 3rd 5,000 miles 2 quarts of oil
gm answer so far is that that is acceptable
dealer admits it is a problem but hands are tied until gm comes up with an answer
last oil change switched from 10-30 to 5-30 hoping to lower oil pressure
any idea's or solutions would be great
Bill
like i said before i switched from 10-30 to 5-30 weight oil to see if i use less oil but only 500 miles sense i changed over so too soon to tell
will get back to you after a few more miles
will
Dinu
The engine is available as an OPTION in the 2500 regular duty and heavy duty Silverado/Sierra pickups, the 2500 Suburban/Yukon XL, and the 2500 Express/Savana vans.
I am not sure if this is the base engine in the one ton trucks, but I know it's not in the vans, they still have the 5.7L as the base engine.
There is also an informational bulliten from GM but the dealer has to call it in to get the full details, here is the number and description of the bulliten, you will need it if you are going to talk to the dealer, they WILL NOT offer up this info, and might not even know about it.
#A001705C 8.1L L18 ENGINE POOR OIL ECONOMY - 8.1 CONSUMPTION DIAGNOSIS GUIDE HIGH HOT INTERNAL LEAK LEVEL LOW MISFIRE NOISE PLUG RING SEAL A001705C SUPERSEDES A001705A A001705
As a sidenote, the 8.1 is also being used as a marine engine. I don't have any first hand knowledge of it, but I hear from other boat owners that it's considered a "throw away" engine, meaning that once the cylinder walls are worn out it can't be bored and rebuilt. Evidently the bore is already maxed out for the block.
not too worried about rebuilding the engine, i will have bought another truck by then, but it would be nice if i did not have to check the oil all the time
2000 miles have gone by sense i changed the oil and i am down a quart
this time i am not going to add any oil and see if the oil stays at the add line on the dip stick
by leaving the oil at 5.5 quarts and lowering the oil pressure it might not use any more oil, will see (has worked on other vehicles in the past)
and yes i will check it at every full up
that is what gm and the shop manual state
1 quart every 100 gallons of gas
if you have used 8 quarts in 6000 miles then your truck engine is considered to be using excessive oil and gm will have to do something about it
first they will test oil level for 1000 miles and go from there
let me know what happens if anything
will
