GM's triplets Venture, Silhouette, and Montana
kkollwitzkkollwitz Member Posts: 274
I have a Chevy Venture. So many of the posts in each of the three current discussions apply to all three versions that I've started this unified discussion. Please post any common topics here.
«13456732
  • catamcatam Member Posts: 331
    I agree it would be nice to have all the posts on the GM trio on one board. If everyone follows suit, it will make things much easier. However, my guess is that all this board will do is add one more to the list I check on each visit.
  • dlubindlubin Member Posts: 66
    I read all three - it'd be a lot easier to just read one. Maybe the hosts will lock out the others and let this one go forward as the 'authoritative' group for the GM Minivans.
    -Dan L.
    '01 Montana
    '00 BMW 528i
  • missedbassmissedbass Member Posts: 48
    I think this is a good post since the drivetrain and chassis are the same.
    How many Venture,Montana, and Silhouette owners have had the leaky headlights,water in the jack compartment, and engine knock on start up problems?
    Let's watch this one for a week or three and see how it goes. (That'll also give me time to get caught up from my move that killed my computer last week).
    Steve
  • cdn_river_mancdn_river_man Member Posts: 7
    We bought a 2001 reg Venture Van last summer and enjoy it. We are experiencing a thumping noise from the back end whenever we hit a bump. Any suggestions as to possible cause? It is going in to the dealer's in 3 days to be checked out.
    Denis
  • kkollwitzkkollwitz Member Posts: 274
    This could be the tire jack getting loose in its right rear cubby, or the spare tire under the car.
    checked the jack before and it is ok. Took the spare tire out for the winter and put it into van, thump is still there.
  • ronsmith38ronsmith38 Member Posts: 228
    Could be the load leveling compressor loose if you have that feature.
    Just back from the dealer and they were unable to figure out what was causing the thump. However the complaint is on record and we will see what develops :-)
    Thank you to those who offered suggestions
    Denis
  • bob550kbob550k Member Posts: 148
    After an 5 month search for a used Premiere, I found a '99 with 24,000 miles on it. We've had it for a few thousand miles other than a bad electric door lock switch, no complaints. Engine knock on start up doesn't hurt anything so what's the issue? I have the complete service history provided by the factory and the former owner didn't have much to complain about. This is a heckuva nice van, I found it to be the most comfortable, with the best options on the market and what a great bargain at $18,000 and still under bumper to bumper warranty! Along with the powerfull V6 the car gets good MPG and this car has every option that was offered except the 16" wheels. Very nice and very comfortable.
    Last night we had a record low of 17d F., the lowest it's been since we bought our Venture two years ago. This morning there was a small transmission fluid leak at the gasket. Could this be related to the unusually cold weather?
    This will seem like an odd question, but my '01 Montana (w/ Montanavision) has red stick-on dots all over the place - on different panels, under the hood, on the backside of the rear view mirror..
    Any ideas? Some sort of quality (or lack of) check?
    -Dan L.
    '01 Montana
  • bcd99bcd99 Member Posts: 45
    I have a 2001 Silo and since the weather got cold the gas shocks that lift the door only open it about halfway. If you open the door fully the shock hold it there. Anyone else have this problem, I'm thinking of complaining to the dealer. My father-in-law 1988 Olds 98 has the original gas shock on his trunk and hood that still work and open fully, I think a 2001 should not be having problems already.
    Aren't the hatch supports covered under the bumper to bumper warranty?
    I've even had that issue with my BMW, but only when it's brutally cold, and it sat outside for a while. The van sits inside most of the time, so I don't have any experience with how it acts in the cold
    I agree with you, 1/2 way is unacceptable.
    -Dan L.
  • hhuahhua Member Posts: 16
    Our 2000 Silhouette (3.4 v6) 16K miles has very minor oil leaks at the gasket between the manifold and the head. I can see three steaks of oil running at the driver side front bank. There are no leaks from the passenger side. I can't see the rear bank so, I assume there are no leaks there. There was oil trace below the leak on the oil pan. I never see any oil dripping on the garage floor. I cleaned the oil pan and will keep monitor it.
    Just wonder if this is a common problem, should I be worry that the leaks will get worst, and have the deal fix it now while it is still under warranty. I would hate to have the dealer try to fix this minor problem, and may introduce a more serious problem.
    The car has been very good so far, we got 21 mpg avg since new. Only minor problems were the liftgate water leak, and the passenger side power slide door problem. Both problems seem to be fixed now.
  • offhamoffham Member Posts: 344
    I would go for this as I have found interesting info on the other two.
    Suggest the the three separate vans be archived and we kick off with this one. Also the Chevy Van Owners is not getting a great following.
  • carnaticcarnatic Member Posts: 3
    we have a 1999 Pontiac Montana. Has only 22,000 miles on it. Been in the shop over a dozen times. Sliding door problems, brake problems, anti-lock problems, coolant leak, transmission fluid leakage, electrical problems, drivers seat problems, more squeaks and rattles than a yugo. In summation--typical General Motors Junk. Would not recommend one and I have purchased my LAST General Motors product! SO BEWARE-before you buy one--check out the reeports on them!!
    Sorry to hear about your problem vehicle. I believe your Montana is one of the few lemons out there for this trio. By reading the posts on this board, the vast majority of owners are quite pleased with their GM vans and the infrequent problems. Good luck with your next vehicle.
  • rayt2rayt2 Member Posts: 1,208
    To anyone interested....Got my Extended Component Engine Warranty for the engine knock in mail yesterday from GM, 5year/100,000 mile for engine only. Guess I won't be keeping this vehicle for 10 years after all.
    Ray T.
  • dirkdaddydirkdaddy Member Posts: 313
    Hey, I had just proposed this 3way forum just last week, I got beat to the punch.
    FYI - We just got a used '98 Olds Silo GLS EXT in December 2001, and its been wonderful. I have only had a few minor things to fix (normal on a used vehicle)and the van looks, feels and drives like a new one! With the steep depreciation curve (sorry folks, just a fact) these are excellent used values. This thing has very comfortable seats even in the back, every feature you could get at the time, and even in houston traffic we get 23.5 MPG on most tanks, and one tank I got 24.6. Its like a luxury car, a pickup and van all in one.
    I do have a few minor issues I need to address, such as a small coolant leak that I think is from the intake manifold gasket - that's one of the few known problems on this motor. Thanks to these boards I know its not just mine.
    Anyway, if in the future someone has a question for the service manuals, I forked over the $100+ and bought a set. I also am a weekend mechanic and can help diagnose problems.
    S
  • jpc47jpc47 Member Posts: 62
    Glad to have on on board Dirkdaddy. I also will go along with the triplet suggestion. Only problem I have is the ticking on cold start. I don't like it, but I haven't heard anybody actually having a breakdown because of it. Will this problem get worse?
    I answered this on the Montana board, so I'm reposting an edited version here for posterity.
    I don't have GM's info in front of me, but basically new motors like the 3.4 are engineered for gas milage and low friction. Piston skirts have been greatly reduced, piston rings are lighter and there are fewer of them than they used to use. This is part of the cause of the startup noise. Also, GM makes them a bit "loose" so they spin easier and you get better gas milage. This is why some new cars have "acceptable" oil consumption of a quart every 4-5k miles. On the 3.4, you certainly can't argue with the milage of these things. I get 23-24.5 around town/commuting by rolling into the gas instead of stabbing it.
    Also, I remember reading on this on a past message on the Montana list that basically a bullitin explains that a supplier got a tolerance slightly off on the fit of the piston, but when the motor heats up and metal expands, it fits just fine. I belive its just a noise issue and not a motor problem. Just think, you could have endless transmission problems or pulling to the right like a lot of Honda Ody owners, this noise is a non-problem in my book.
    If someone has the "official" GM line how about posting it?
    Hope this helps, DD
    is actually called "piston slap" by GM and their official word on it in the latest TSB is "normal conditon". When I first documented complaint at dealers they noted on repair ticket "Customer states engine making a ticking/knock sound duriing cold start-up. (Reply) GM is aware of problem and is working on a fix". Previous TSB's admitted it as a problem with a fix in the works, now it's normal, I say GM is just covering it's butt at customer's expense. But if you complain about it you will get a extended component warranty for the engine only. You have to document complaint at dealership then file complaint with GM customer service.
    I have NEVER had a GM product or any other new engine do this, it is not normal. The only problem is time, how long after the warranty is gone will it last before major failure? No one knows, it's a gamble. I prefer GM to back up their claim in writing if this abnormal condition is normal in their eyes. I spend 30k on a new truck, which I normally keep for 10-12 years, I don't expect to hear lifters or pistons tapping right from the getgo, if you have a 3 year lease I would'nt be so concerned, but to each his own from one backyard mechanic to another.
    Ray T.
    "No one can take advantage of you without your permission"!
    Truer words never spoken!
    Ray T.
    My rear washer won't spray. I hear the pump running, and there's plenty of fluid. I understood from an earlier post that someone had a kink in the fluid tube stop flow to the rear. Can anyone suggest where I might look for a kink in the line?
    Add some fluid to the reservoir. Even though there is plenty of fluid, the pickup for the rear is mounted high in the reservoir so that you will have fluid for the windshield long after you run out for the rear.
    The kink is a possibilty as well, but I can't help you much there, except to say that I would first look at the rear door, thats the only area subject to movement.
    If you go to the silverodo post on engine knock the same problem with piston slap is noted. there has not been any engine failures due to the knock. If your van is still in warranty and you make enough noise they will take your van and replace the pistons. That's what I hear. The last thing I'll do is have someone tear down the motor just to replace pistons. I don't have too much faith in dealers or repair shops these days. I agree you should not hear any noise from the engine especially after paying out $30K. I bought a 6 year/100K warranty, if the motor goes I'll get it fixed under warranty otherwise I'm not going to worry about it.
    Prior to buying my 2001 SiloI had a 99 VW Passat Wagon. Loved the car, sunroof, tiptronic tranny, great gas milage, fast turbo 4cyl. EverythignI expected from a German engineered car, ecept the repeated problems that made any American look like a gem. Every 1000 miles the check engine light came on, it lost oil (not leaked), it was in the service manager possesion more than it was in my garage. After 2yrs of repleacing eveything except the engine they said it was the gasoline causing carbon build-up. They said the oil comsumption was normal. Three weeks after it was changed by the dealer (2 yrs of free maint) there was no oil in the pan at all. So to sum it all up there can be a lemon from any carmaker.
    P.S. This triplet section is great, would be great if there were fewer threads instead of honda oddity this and honda oddity that.
    Just FYI, when I noticed my used '98 Olds wasn't getting rear wash fluid either after filling the tank, I had someone hit the switch while I was looking at the tank and saw fluid was spraying out of a unattached hose behind the tank. Seems GM used a short peice of special hose to adapt from the pump (mounted on the tank) to the hard plastic line. Mine had zero slack and was not really long enough to reach deep inside the rubber adapter hose , so the pressure would blow it off. I found some small dia vac hose worked as a conversion, but it required using some small wire zip ties to keep it from leaking around the small dia plastic hose.
    We love the van and its a excellent vehicle. I like the highway gearing the best. The transmission works very well, and the passing gear at highway speeds is almost un-noticable to passengers but moves the van well.
    My latest problems are the squealing brakes in the front and disappearing coolant. I will look at those front brakes soon, but all the parts are new, must just need some of that antisqueal TLC. The coolant - I can't see where its going but not in the oil. I'm guessing the intake gasgets are to blame, but letting it get worse for now. Will pressure test it to see if I can find the leak. Maybe try some of that glow in the dark you put in the coolant.
    The procedure in the GM service book for replacing the intake manifold gasgets is pretty involved but not rocket science. A lot of stuff has to come off the motor such as the valve covers, alternator, thermostat, throttle body, coil packs, EGR, upper and lower intake manifold, pushrods(!) etc. I'm guessing (book didn't say) that in practice the mechanics take loose the front motor mounts and tip the motor to the front to gain access to the rear.
    If I felt better about dealers doing the same quality work I can do, I'd take in into them, but I'm thining of doing it myself all in one day. I have to use my air tools and garage for something to justify it once in a while!
    DD
  • mjb56mjb56 Member Posts: 170
    I've been posting in the Montana board about a coolant leak related to a lower intake gasket that just cost $743 to fix (as the coils and plug wires were corroded as well). I just don't think these thing should be happening to a 2 1/2 year old vehicle with only 45K. We previously had a 1990 Transport that we sold with 120K. Had no engine problems and the thing is still running around with the current owner probably putting in less $$ than I am. What can be done about this poorly designed product?
    ps. the triplet board is a good idea. Lets keep it up!
    The lights (headlights, dash lights, etc.) on our 99 Venture sometimes fluctuate in brightness on about a 1/2 second cycle. This most often occurs the first few minutes the car is running. Anyone know why?
    As I understand it from my father who is an expert in eletronics and has various GM cars, the GM alternator charges for a while, then it stops and takes a voltage check of the battery, then charges more if necessary. I belive the output of the alternator is varied depending on the voltage deficit of the battery. The cycling is somewhat normal, especially after a heavy current drain such as when you start your vehicle. However, if your battery is weak and requires a LOT of charging to keep its voltage, it could behave in the manner you describe for longer than normal periods of time and maybe about to die. Suggest you have the battery load tested at an autoparts store or shop if its the original one. The alternator could also be faulty.
    DD
    I have a 96 Cutlass Ciera that did this somewhere in the fir 10K, dealer replaced battery, and some other things. A yr later it was still doing this and the replaced battery, after warranty ran out the told me it was alternator and that if I did not replace the alternator ($450) I would be left on the side of the road. I on the other hand had read the TSB that stated this was normal and left. 3 years later it has the same alternator. I noticed that my 01 Silo does the same dimming as I come to a stop sign or while the vehicle is warming up. Most noticably in the Cierra, when turn signal and headlight are on evrything dims and the signal slows as I come to a stop. Once stopped everything goes up to speed. To sum up this rambling, the TSB states this is not a problem and will not hurt anything based on the fact that my 96 Olds is going strong with 90K and no problems.
    Noticed that as I went over a bump got a new sound which was from inside the cabin. It seemed to coincide with the rear seat movement.
    I removed all the seats (3 middle and 2 rear) and sprayed the floor lugs with silicon spray as well as the seat release fittings themselves. This has cured the problem.
    Our youngest child is 10 years old. All of them have been opening the manual side doors on our 99 Venture. I'm looking at buying a second Venture; several come with the $770 list power door option. Is there any reason at all that this would be useful when all my kids can open the door on their own?
  • centarforcentarfor Member Posts: 22
    I have a 1998 Pontiac Montana and it is already starting to show its age. The Power Steering fluid started leaking a long time ago, the rear wiper/washer doesn't work, and just now the sliding door won't unlock when the other doors are unlocked. I have also had to drill the front light because water was building up inside and burning out the bulb. Is anyone having any of theses problems? If so, what did you do? Thanks.
    Igor Trninic
    The nice thing about the power door is that it's great for those who can't close the door well. Like when Granny goes for a ride. Also it's nice to push the button while running to the van in the rain.
    I had the rear wiper go on my 98 Venture. Got one on line for $150 and my mechanic installed it for $20.
  • mobilmacmobilmac Member Posts: 60
    for my wife, we underestimated its value, i feel it saved us depreciation on our van, usually when the kids or other riders unfamiliar with the amount of force needed to close the slider door, are overzealous and slam it to hard, or not hard enough, our experience has been, repeated times i had get out of my seat and close it again for them. After repeated, unneccessary door closures and repeated yanking on exterior door handles and interior handles, it takes its toll on sliders mechanisms and paint finish around door handle and interior handles. continue in next post.
  • euphorbiaeuphorbia Member Posts: 14
    My 98 Venture has 130,000 miles on it now. It has always had the engine knock and it is now getting a little more noticeable. It hasn't caused any problems and doesn't even use any oil between oil changes (per the book every 7500 miles). I think that this is the best vehicle I have ever owned. At least 40,000 of the miles was pulling a 4,500 pound trailer between Michigan and Florida over the last couple of years. The biggest problems have been water in headlights, power lock switches stopped working (at about 100,000 miles, right power window switch won't close the window. I've also had the hose to the rear window washer shrink and pull off the washer motor. Overall these are not big problems. The drive train on these vans are bulletproof compared to the competition. I had a 98 Windstar and got rid of it at 28,000 miles when the trans started failing. I will buy another GM mini when this one finally quits.
  • tomekktomekk Member Posts: 310
    Did you see any coolant pools under the van? I've noticed my coolant level is below "full when cold" mark, but there are no visible leaks.
    Thanks in advance,
    Tomek
    (2000 Venture, 27K miles)
  • yzfyzf Member Posts: 65
    Anybody have success turning the video/vcp unit in their GM minivan into a TV? I'd like to get some local stations while waiting in the minivan for the wife to finish shopping but can't find a way to hook in a tuner. Anybody got any ideas?
    Thanks in advance.
    what I did to fix:
    Remove the lights by taking off the mounting thumbscrews, remove the bulb and holder together. Examine plastic lens housing. The glue that goes between the front clear part and the reflective part is defective and leaks. You can pry these apart carefully, then scrape the old glue out of the sealing area. I used "goop" to re-glue, but you can also try a polyurathane caulk. While you're at it, clean out the reflector and lens with windex. Let dry, then reassemble.
    Regarding power steering leak, you should be able to see where its leaking. If its the rack, replace it. Hoses are a easy fix if that's the problem and that's cheaper.
    The door lock sounds like you need a new servo.
    None of these is a major problem, the worst might the PS, but that's a must-fix in my books as its a potential safety item as well as a enviromental issue with the fluid leaking on the ground.
    I agree with the other poster, Ford, Honda and Dodge vans have consistant transmission problems. The GM vans are not everything to everyone but you do get 3-4 MPG better than even the Honda.
    Suggest you fix these items so you can start enjoying your ride again w/o reservations.
    DD
  • hawk27hawk27 Member Posts: 5
    We've owned our 2001 Silhouette for more than a year now (15000 miles). We have been very pleased. It is very comfortable, handles very well and has been trouble-free. Most of the miles have been kid-hauling local trips, and this van has performed exceptionally. We tested everything and our decision came down to the GM vans or the Odyssey. I was unimpressed by the acceleration of the Honda, but we liked it overall, and it was wider. However, the price tag was $5,000 more than the Silhouette. My brother-in-law bought the Odyssey at the same time we did, and he likes it. However, it's already been in the shop once for a door problem -- and they have only 10k miles on it.
    Those who have had the dealer fix a manifold gasket problem, what was the solution? Is it the same gasket material as the failed one, a new gasket design, or permatex, or ??? Just curious.
    FYI - We love our 98 van, the transmission is great unlike many vans and the torquey powerplant makes the van pretty zippy. And its very comfortable. I'm happier than I was with a 1/2 ton 4x4 dodge pickup, even with the lesser ego trip.
    ps. suggest we all join the triplets list.
    DD
    I had water build up in my from light, I couldn't find the place where it was leaking so I just drilled two holes in the bottom of the light. Now it is fine.
    I'd be interested in a TV option as well. We did add a DVD which works well though.
    Also, any way to allow the front speakers to play the radio while the movie plays in back??
    DD- have a 98 olds also. 40k on it. have added small amount of coolant but can not find the leak. brought it to the dealer for an inspection and he didn't find any leak either. he did find a power steering fluid leak in the rack [non-permissible content removed]. that will be replaced soon. Talked to a mechanic who said that the Dexicool tends to leak through the gasket more than the regular green antifreeze. On the cars where he replaced gaskets, the manifold was tight, no loose bolts. as far as the lights go, the dealer drilled a hole on the bottom and siliconed the light case
  • autolover3autolover3 Member Posts: 53
    Any news on the AWD Venture? I haven't seen any yet. Are they reliable?
