GM's triplets Venture, Silhouette, and Montana
I have a Chevy Venture. So many of the posts in each of the three current discussions apply to all three versions that I've started this unified discussion. Please post any common topics here.
-Dan L.
'01 Montana
'00 BMW 528i
How many Venture,Montana, and Silhouette owners have had the leaky headlights,water in the jack compartment, and engine knock on start up problems?
Steve
Denis
Thank you to those who offered suggestions
Denis
Any ideas? Some sort of quality (or lack of) check?
-Dan L.
'01 Montana
I agree with you, 1/2 way is unacceptable.
-Dan L.
Just wonder if this is a common problem, should I be worry that the leaks will get worst, and have the deal fix it now while it is still under warranty. I would hate to have the dealer try to fix this minor problem, and may introduce a more serious problem.
The car has been very good so far, we got 21 mpg avg since new. Only minor problems were the liftgate water leak, and the passenger side power slide door problem. Both problems seem to be fixed now.
Suggest the the three separate vans be archived and we kick off with this one. Also the Chevy Van Owners is not getting a great following.
Ray T.
FYI - We just got a used '98 Olds Silo GLS EXT in December 2001, and its been wonderful. I have only had a few minor things to fix (normal on a used vehicle)and the van looks, feels and drives like a new one! With the steep depreciation curve (sorry folks, just a fact) these are excellent used values. This thing has very comfortable seats even in the back, every feature you could get at the time, and even in houston traffic we get 23.5 MPG on most tanks, and one tank I got 24.6. Its like a luxury car, a pickup and van all in one.
I do have a few minor issues I need to address, such as a small coolant leak that I think is from the intake manifold gasket - that's one of the few known problems on this motor. Thanks to these boards I know its not just mine.
Anyway, if in the future someone has a question for the service manuals, I forked over the $100+ and bought a set. I also am a weekend mechanic and can help diagnose problems.
S
I don't have GM's info in front of me, but basically new motors like the 3.4 are engineered for gas milage and low friction. Piston skirts have been greatly reduced, piston rings are lighter and there are fewer of them than they used to use. This is part of the cause of the startup noise. Also, GM makes them a bit "loose" so they spin easier and you get better gas milage. This is why some new cars have "acceptable" oil consumption of a quart every 4-5k miles. On the 3.4, you certainly can't argue with the milage of these things. I get 23-24.5 around town/commuting by rolling into the gas instead of stabbing it.
Also, I remember reading on this on a past message on the Montana list that basically a bullitin explains that a supplier got a tolerance slightly off on the fit of the piston, but when the motor heats up and metal expands, it fits just fine. I belive its just a noise issue and not a motor problem. Just think, you could have endless transmission problems or pulling to the right like a lot of Honda Ody owners, this noise is a non-problem in my book.
If someone has the "official" GM line how about posting it?
Hope this helps, DD
I have NEVER had a GM product or any other new engine do this, it is not normal. The only problem is time, how long after the warranty is gone will it last before major failure? No one knows, it's a gamble. I prefer GM to back up their claim in writing if this abnormal condition is normal in their eyes. I spend 30k on a new truck, which I normally keep for 10-12 years, I don't expect to hear lifters or pistons tapping right from the getgo, if you have a 3 year lease I would'nt be so concerned, but to each his own from one backyard mechanic to another.
Ray T.
Truer words never spoken!
Ray T.
The kink is a possibilty as well, but I can't help you much there, except to say that I would first look at the rear door, thats the only area subject to movement.
P.S. This triplet section is great, would be great if there were fewer threads instead of honda oddity this and honda oddity that.
We love the van and its a excellent vehicle. I like the highway gearing the best. The transmission works very well, and the passing gear at highway speeds is almost un-noticable to passengers but moves the van well.
My latest problems are the squealing brakes in the front and disappearing coolant. I will look at those front brakes soon, but all the parts are new, must just need some of that antisqueal TLC. The coolant - I can't see where its going but not in the oil. I'm guessing the intake gasgets are to blame, but letting it get worse for now. Will pressure test it to see if I can find the leak. Maybe try some of that glow in the dark you put in the coolant.
The procedure in the GM service book for replacing the intake manifold gasgets is pretty involved but not rocket science. A lot of stuff has to come off the motor such as the valve covers, alternator, thermostat, throttle body, coil packs, EGR, upper and lower intake manifold, pushrods(!) etc. I'm guessing (book didn't say) that in practice the mechanics take loose the front motor mounts and tip the motor to the front to gain access to the rear.
If I felt better about dealers doing the same quality work I can do, I'd take in into them, but I'm thining of doing it myself all in one day. I have to use my air tools and garage for something to justify it once in a while!
DD
ps. the triplet board is a good idea. Lets keep it up!
DD
I removed all the seats (3 middle and 2 rear) and sprayed the floor lugs with silicon spray as well as the seat release fittings themselves. This has cured the problem.
Igor Trninic
Thanks in advance,
Tomek
(2000 Venture, 27K miles)
Thanks in advance.
Remove the lights by taking off the mounting thumbscrews, remove the bulb and holder together. Examine plastic lens housing. The glue that goes between the front clear part and the reflective part is defective and leaks. You can pry these apart carefully, then scrape the old glue out of the sealing area. I used "goop" to re-glue, but you can also try a polyurathane caulk. While you're at it, clean out the reflector and lens with windex. Let dry, then reassemble.
Regarding power steering leak, you should be able to see where its leaking. If its the rack, replace it. Hoses are a easy fix if that's the problem and that's cheaper.
The door lock sounds like you need a new servo.
None of these is a major problem, the worst might the PS, but that's a must-fix in my books as its a potential safety item as well as a enviromental issue with the fluid leaking on the ground.
I agree with the other poster, Ford, Honda and Dodge vans have consistant transmission problems. The GM vans are not everything to everyone but you do get 3-4 MPG better than even the Honda.
Suggest you fix these items so you can start enjoying your ride again w/o reservations.
DD
FYI - We love our 98 van, the transmission is great unlike many vans and the torquey powerplant makes the van pretty zippy. And its very comfortable. I'm happier than I was with a 1/2 ton 4x4 dodge pickup, even with the lesser ego trip.
ps. suggest we all join the triplets list.
DD
Also, any way to allow the front speakers to play the radio while the movie plays in back??
