About the leaks from the lower manifold gasket (the dealer said it it oil, not coolant, leaks)...Since it is not really wet, the dealer won't work on it...We will have to keep monitoring it.
A comment about the dealer work...We have to bring the van back the second time, for few minor parts weren't put back or fastened. It was a sloppy job from the technician. They also didn't do the alignment after the repairs, the steering wheel was off center, alignment was done after second visit.
This was the second time that we have to take the van back to fix/correct the problems that were introduced from the first visit...We always nervous to have the car in for service and end with new problems when we get it back...And that's what we call quality services???
The funny thing that I noticed is that, now a day, the manufactures and the dealers seem to concern and care more about the high service rating and customer survey, but don't seem to stand by their products and only provide marginal services.
Like many people, we are more worry about our vehicle could have additional 'new' problems after a major repair from the dealer. And that is SAD.
Unless you're going down between changes and its getting all over the underside of the van, I think you're asking too much. The dealer did more than most would do in that instance IMHO.
Have fun and don't worry so much...
DD
When going through the on line catalog need to select heat/ac
If the condensation bothers you, either pressure wash the undercarraige periodically or use an engine degreaser and a spray hose.
Another item I had the dealer check was the temp. gauge. This gauge never goes past the 1/4 mark. I've only had the van for 5 weeks so I don't know what it did when new, but 1/4 bothers me. Dealer said all is well. Gauge reads normal and engine operates at normal temp. I'm thinking either the thermostat opens a little early, or the gauge isn't calibrated correctly. Has anyone else noticed this?
Tom
On my Olds, the engine temp gauge normal is exactly 1/2 way or 12o'clock.
Good idea to ask GM about the intake gasket repair (if that is what wrong on my van). Thanks for sharing that tidbit!
DD
'01 Olds Silo -- a little more than 1/4
My Silo has the trailering package. I still don't understand why the trailering pkg does not include the trailer hitch. Has anyone added this themselves, which hitch did you use, how hard/easy was it to attach and drill holes?
Yes, that's correct. That was a surprise for me - didn't catch it when I was buying the van.
-> "How does this work if you have a booster seat that requires a shoulder/lap belt combo"
Well, that doesn't work... (I have 2000 Venture with 8 seats), but I happened to have a child's seat (for my 11-month old, up to 35 lbs, I think) that works with only lap belt - I lucked out.
Tomek
I just bought a Silho premier with AWD. Didn't really need the AWD but asked myself what is the price of safety for my wife and kids, it kinda looks affordable then. Anyone have anthing to say about it? Looking for poss. but need to know the negs. as well. Any trouble? Any tech service bullitens I should know about? I'm new to the Board and didn't see too much info regarding the AWD.
Thanks in advance.
Why ask about negatives after you bought the van? Enjoy it and quit worrying.
My favorite features are the comfortable dual power seats, the room, the MPG you get (I'm getting 23-24), the trip computer and storage, self leveling suspension, the cruising range (around 500-600 miles per tank) all the features and power gadgets and how easy it is to drive. It would be nice to have more horsepower and torque (I'll always say that) but for the purpose of a van it works great.
There are some things people don't like and you won't have to look too hard to find them. One major gripe I have is that I prefer the seat padding to be stiffer like a Honda or Mercedes, but I could have the seat modified at a shop I guess.
DD
I was offered new ceramic brakes for addl $10, but stuck with the basic replacement.
Just as info
The center is perfectly safe - in fact it's the safest seat in the van considering its distance from the exterior on all sides. I'd highly recommend using LATCH over a seat belt any time, it's a LOT safer IMHO.
-Dan L.
'01 Montana
Also, what is the going rate for an extended warranty on a 02 Venture (2WD)? I was quote $3000 for a GM warranty (7 yr/100K/$0)and $1600 for 'another brand'. I always thought it was recommended to get the warranty w/ the manufacturer. My jaw dropped when I read the $3000 quote! That is triple than other going rates on various makes. Of course, this is probably negotiable, but my gosh! Has anyone had experience w/ this?
From my readings on these forums, the priviate warrentys are hardly a bargin, most require you to pay the bills and then submit them for reimbursement, and in some cases they require you and the dealer to prove things are really broken. Coverage details (type you find out when you got to use the thing) typically folks find are not as good. And you don't know if the company will Enron on you (file bankruptsy) leaving you with a paper you can use to start a fire.
For my mind, $3000 would be better off used to fund my kids college fund. I'd take the bet that this van would not require that much in repairs in 3-5 years. You've done reasearch on which one is the most reliable (GM), why pay honda price gouging for a warrenty you'll probably not use?
FYI, these are huge profit centers for the dealerships, check the info here on Edmonds, and yes, like everything, the price is definately negotiable and can be added after the purchase from what I understand, and you can even get it mail order from out of state dealer if you find a deal.
DD
Change once a year seems fine. Quite a lot of debris in there from leaves etc.
At 45k miles on it, my biggest beef was how quickly the front pads and rotors wore out. Mostly highway miles, no aggressive braking. That was 2 set of pads/rotors i put on it, not including the orignals.
I did expect to be able to turn the rotors, they were always out of spec for turning,i had to buy new ones each time. So when its time for a brake job, buy the better pads, and replace the rotors
All in all, we really loved that vehicle. This was for fellow triplet owners, our history with
our silhouette. continue next post.
One thing about the front brakes worth noting. The left front inside pad was almost completely gone, but the left side outside pad and both pads on the front right side had plenty of pad left. The wear indicator is located on the outside and had a long way to go before it would start squealing. Don't wait for this indicator to start rubbing to replace the pads or you may be in trouble.
BTW - this is not just a testimant to the Olds Silo. Any minivan with similar LATCH compliant anchors will work well to secure a child seat. The key is to get the right strap (mine's made by Evenflo) and hook it in securely to the child seat. I've used the strap and seat on a rental DC van with similar anchors. Also works well!
Thanks, Harry
Thanks so much for your opinions.
Thanks for the input.
Also, I'm going to try to tap into the wiring harness to get to the rear speaker wires in order to drive a small subwoofer. I'm guessing the wires go through the heater/AC/aircompressor panel in the back, and since there's also a solid power feed for the aux power outlet, it should make wiring it fairly straight forward. Getting the panel off requires star drive to remove the rear seat belt hanger, and some special tool to remove the plastic cover clips w/o damaging them. Anyway, if I get to this and finish it, I'll try to post some pics. Although its not the simplist thing to do...
Host - some items I'd suggest for the to-do list at Edmonds:
* Text searchable BY MESSAGE not just topic
* Easier way to post pictures - the current way seems like too much work
Thanks!!
DD
The message box uses most of the usual html formatting stuff, so the image screen tag is what works. Too expensive to let y'all park pics on a server here and link to them that way - got something else in mind?
Steve
Smart dealer always has them stock. Maybe Chevy should come out with a two pack, then I would always have spare.
My final thought that if I had married someone over 5'6", they wouldn't have had to use it anyway and just grab the rear edge of the door.
Such is life !
#2 Oldsmobile Silhouette
#5 Pontiac Montana
#8 Chevrolet Venture
Steve
The first time to confirm that the transmission fluid leaks due to the seal and the dip stick tube has a small punctured. The seal was replaced but the dip stick tube has to be ordered.
We brought the van back again for the dip stick tube replacement. After I got the van back, to my surprise, the replacement tube doesn't look new (I can see the "water" dirt marks all over the tube).
Also transmission dip stick now has a black plastic ball about .25 inch on top of the full cross line mark on the dip stick. I don't remember the black ball was there before. The fluid seems a bit over filled, about .5 inch above the full mark (no bubbles seen).
I am now not too comfortable with the tube and the dip stick, but at long there is no more leaks I will not want to have my van back to the dealer.
A question, does anyone has a GM's triplets that as a transmission dip stick with a little black ball attached?
Thanks and sorry for the long post.
I replaced the engine air filter today for the second time. Boy is it a pain. I was able to do it without having to take anything loose like the rubber hose coming off it, but it is hard to squeeze the new filter in.
I noticed the outside covering of one of the throttle cables was cracked. There are two cables and it looks like the hood is pushing them down when the hood is closed. It has cracked the outside covering right at the end where is it attached to the black bracket. Seems to work ok for now, but may have the dealer look at it when I take the van in next.
I have a question for the folks that have replaced the ignition coil packs due to corrosion. Was the posts where the spark plugs wire attach rusted? I replaced my spark plug wires a couple months back because two of the posts were rusted and the ends of the plug wires were rusted also. I wonder if the rusted posts were a sign that the coil packs are corroded also? When you first start the van and don't give it gas, the idle speeds up then slows downs, then speeds up, then slows down, etc.
Matt
Thanks for your help.
I would just clean off the corrosion, put on some di-electric grease on all terminals (for preventing future corrosion) and drive it. Although some coils have failed from what you read, they are usually bullet-proof.
DD
