Toyota Corolla Accessories and Modifications
                    If anyone hears of a roof rack for a Matrix...let me know about it.  I need to haul my Kayak and 2 mountain bikes as I do now on my Corolla (Thule roof rack which attaches to the rain gutter).
They said that it's just one of their removable std. racks.
Their telephone number is 888-925-0703.
Too bad we can't find one that would compliment the design of the Matrix.
Toyota really dropped the ball here.
The front lower peices which form the complete ground effects package from the XRS would be available as a part # too if you really wanted to mimimic an XRS. As you know these are missing on the XR...you can have a body shop paint them to match and bolt them on. The only difference in exterior view of the XR vs an XRS then would the 16" vs 17" wheels and some of you americans may have ordered those as well...
A rack for me needs to sit forward more on the vehicle than the non-removable rack on the Vibe. The Vibe rack may look good but it is practically useless...sitting at the back of the car like that. I have a 17' sea kayak that is strapped on to the car near the cockpit...if I tried this on the Vibe rack I would have 8 feet of boat out the rear while the front would barely reach the windshield. The removable racks are great because you can centre them properly...the boat is about the same length as the car and it is really nice to have it directly over the car. They are also nice in that you can remove and store them when you are not using them as all racks add noise and wind resistance to a car decreasing fuel mileage.
Can you tell me how the removable rack works.
Is there something that is permanently mounted on the roof that you attach the bars to when you need to set it up, or does the whole thing detach from the roof?
I agree, it's nice not to have the wind noise and drag and also that rack on the Vibe is almost useless.
Are the Matrix's clearcoated ?What size is the block-heater?
you can check Yakima roofracks online.
Also ,have you Matrix drivers noticed when you release your emergency brake the front lights go on ,I think dim and rear lites don't ?
Here are a few answers for you...
Not sure in aftermarket who makes trailer hitches for the Matrix yet...but Toyota make a mini-receiver as a dealer installed option. I think it is 1 1/4" receiver the same as a Rav4. Frame may be similiar to a Corolla but I doubt the rear bumper is even close. Trailer would not be pre-wired but again available as an accessory. There are some really neat do it yourself kits out now that pop into the rear tail light assembly. Matrix's are base coat clear coat paint. Block heater...not sure of the size but should always get the block heater from and installed by the dealer. You don't want a $50 part failing and taking out an engine! Yakima make a rack to fit...Thule does not (YET!)
Daytime running lights by design are designed to shut on and off with the emergency brake. Unless things have changed (My Matrix is still on order) it should work that starting the vehicle with the parking brake on will not enable the daytime running lights. Releasing the brake will enable them.
hope this helps
On our previous 4runner(auto) all lites came on after starting. Now I have 2 turn tail lites on .
I was concerned with the wattage of blockheater,can't hear it ,could here one in the 4runner.Who handles the wiring kit U mentioned ,2 fit toyota's ? I've heard of them 2 but had 2 wire my 4runner myself.the wiring on left side rear looks like it may have a connector. Several hitches fit 2002 corola but matrix is 2003.
I have not yet decided on the tire size for the wheels...I will likely not buy the tires until next winter as I am not taking delivery till June. The trick is to get the combination of 15" wheels and tires which is exactly the same height as the P205/55R16 and alloy combo. I am not exactly sure how to do this math but I had a tire dealer do it for me on another vehicle and the heights were within millimeters. You need to have the heights identical in order to keep the speedo the same...
When I get the right combination, I will post it in this forum...
Can you tell me if the overall height of the P215/50/R17 is the same as the P205/55/R16? I doubt it huh?...the 5% profile difference would not make up extra 1" of height! If that is the case the speedo must be geared differently in your XRS when compared to my XR. hmmm so I will need a slightly smaller winter tire...possibly 185 or 195/65/r15. Do you have rims off a pre-91 Camry on your XRS now? That is excellent...that will be a lot less expensive than new 15" 2002 Corolla rims from Toyota (ouch they will not be $20 each, I can guarantee you that)
For you to go from 15's to 16's (tires), you're best bet is a set of 195/65/r15's. This brings your overall diameter up to 25" from 24.5, which will decrease your speedo about 0.4% (807 revs/mi to 811 revs/mi). These tires can be found pretty cheap too. As far as rims go, you should be able to get away with a multi-purpose set of steel rims (if for winter).
Steel rims are around $45 CND each. I got mine at Palmar (wholesaler in Atlantic Canada). In Halifax, you can get a good deal at Dartmouth Surplus (see Robert).
PS. Buy winter tires now, they are cheaper this time of year.
..deagled..
Wow you know your tire and wheels...yes these are just for the winter so muli-purpose black would be perfect. I was just in Halifax last weeked too but I should be there again soon...thanks again for the info...I will see Robert at Dartmouth Surplus
Are you going to get aftermarket wheels for next winter? Save those nice alloys you have...
I am thinking more like K and N filter, free flowing muffler, performance chip etc.
any ideas?
I have some trouble with my DRL on my XR Matrix:
1. DRL will turn on my low beam at full strength when it is very sunny outside. When it is partly cloudy, then it will turn on everything else (fog lights if you set it to on, and tail lights). Is this what you guys experienced?
2. My headlight switch is practically useless, since almost all the time, all my lights are on (even on a bright day, all the lights will be turned on).
Any comments / help ?
Peter
Sounds like a trip to the dealer is in order, since this is definitely not how they are supposed to work. They should come on at reduced brightness until the sensor on the dash detects low light level. At that point, they should begin coming up to full brightness. However, the taillights should come on only when you turn on the switch.
It wouldn't explain all of the symptoms, but covering the sensor (driver's side top of dash) would cause the lights to be at full brightness all the time.
If so, where would you purchase the molding?
I seem to remember reading somewhere that you go the nav system. Could you tell me if the CD changer in your XRS is a Pioneer and if it can play CD-Rs?
Now a few different sizes have been mentioned, however some are incorrect. Here are sizes which are considered comparable:
17 in 215/50 = 16 in 205/55 = 15 in 205/55 or 195/60. The optimum size for 15 in tires is 205/55 because you're overall circumference will have the smallest differential at this size. However for winter use, I'd recommend 195/60 because of its narrow width. Remember, with a smaller foot print, your tire will cut through the snow better. Hence you'll get better grip. In the summer, the opposite is applies. Get the widest tire you can get! Good luck!
I am a bit lost...you claim "17 in 215/50 = 16 in 205/55 = 15 in 205/55 or 195/60." How could a 205/55x16 and a 205/55x15 be equal in height? There is an inch difference in diameter in the rim.
Also, could you tell me what the 15" eqviualent would be to replace my P205/55r16 factory tires? Deagled and I thought P195/65r15 would be the cats meow...
thanks for your help
XR
You are right when you say you need to maintain an equal circumference, but the sizing you suggest is incorrect. Perhaps you know something I don't (insert joke here). I know from experience that to go from a 17 to a 15 (for winter tires for example) you need to go 205/65 15's. this keeps the diameter at 25.5 inches and the circumference at 80.0 (give or take a mm). This setup would only throw your speedometer off 0.1% (slower).
Please help me understand why/where you got these numbers.
..deagled..
http://www.paspeedo.com/calculator.htm
195-60-15 seems to create less speedometer error.
The tire sizing site's pretty good. Thanks TUP!
Here's how I came up with my tire sizing:
215/50R17 = 323.4 mm Radius
205/55R16 = 315.9 mm Radius
205/55R15 = 303.2 mm Radius
195/60R15 = 307.5 mm Radius
Obviously these figures are all different, however the matrix is set up to run 205/55R16 tires. The 215/50R17's are a size up and the 195/60R15 are a size down. Both deviate less than 9 mm from the 205/55R16. When we look at a tire, 9 mm can easily be eaten by tread wear, inflation pressure and temperature.
I admit, I was smoking some pretty cheap stuff when I typed 20/55R15 (because thats probably pushing the envelope of error). All in all, as long as gauge error is kept below 10%, you'll have whats considered a capable gauge. This is you should always fight your speeding tickets!
Cheers,
..deagled..
do have a solution now, they are just not telling anyone about it.
Thule now make a TP Top Track to fit just about any vehicle including the Matrix. If you go to http:\\www.thule.com now and use their fit
guide you are told there is no roof rack solution for a Matrix, but you do have this option. You need to bolt to the roof so my suggestion would be to have your dealership do it...but for $120 USD you can bolt this setup rail system to your roof and then connect your existing Thule components to it (providing you have the right
connection feet).
The ad also claims it accepts Yakima rail riders as well.
I thought I would share this because I was just about ready to sell my entire Thule Rack system and purchase an entire Yakima system...this rail system is saving me hundreds of dollars...
XRS 6spd...1450km and counting...
This is the link to the site...
I'm thinking going aftermarket would be better, cost-wise, though. . .
Toyota at least put a cushion on the driver door for you left arm!! Does anyone know where I can get a modified hatch so my elbow does not get inflamed? Thanks.
