Vibrations due to bad tires
car_hunter
Member Posts: 17
Last few weeks I have been getting some vibration while driving at highway speeds (50mph and above). Showed the car to a local shop and the guy said that the rear tires were in real bad shape. Even though the treads were looking good, he said that the tire surface was uneven & bumpy. Could have been caused from bad struts or a lot of "dirt-road" driving that made the surface wear off unevenly (he said he could feel the bumps with his bare hands). He recommended changing the struts and getting a pair of new tires. I mostly do highway driving to and back from work - not sure what might cause this. (It's a 95 Galant with 75k miles). Any ideas? Thanks.
I've always recommended an alignment once a year - more often if you or another driver in your family likes curbs (no accusations, just an idea). People seem to get really mad when that suggestion is made, saying "I don't hit curbs when I'm parking". Yeah, right. Who hasn't?
the tires to wear,you would experience a very bouncy ride.if you didn't keep up with regular tire rotation (atleast every 7500 miles )the rear tires would develop irregular and choppy wear patterns on them.once this happens it is too late to save them.if the toe was off you would get a feathering wear pattern starting from either edge and gradually diminishing towards the center.
if the bumps are on SIDEWALLS, like giant round or oblong blisters, this is a major safety issue, your casing is delaminating. put the flashers on and creep to the nearest tire store immediately, those suckers are gonna blow out the sidewalls at any moment. that is caused by serious overheat in the sidewalls, aka overload, and bruised belts on terrain can also cause these issues.
not to be confused with the almost-universal sidewall "ridge" where the top belt ends as it wraps alongside the casing. almost every tire now ends up showing this "speed bump" on the sidewall, in a straight line from the center out to the tread. this is excess belt overlap and not a problem.
Also I'll bet a paycheck the shocks and struts are totally blitzed. 75,000 miles? Those things were wasted at 40,000. Lack of maintenance and cheapo tires will cause those problems.
On rereading your post, I would guess that your problem is one of tread wear, and not one of physical damage. I'll bet you have "ruined" your back tires by failing to rotate tires in a timely fashion, and/or your alignment needs adjustment, and/or your struts are allowing "bounce." Fix the suspension, align it, and put on new tires.
Rotating the tires every 5 to 10 k miles is usually enough to prevent it. Tires with "ribs" of tread running around the tire instead of blocks or lugs do not have this problem in most cases.
Harry
On occasion I hear a car going by that is absolutely screaming wow wow wow-some people never ever rotate.
Is there a way to check if the belt separation has started and whether I need to change just one bad tire instead of one bad and three good. It is funny that from the outside the tire and treads look good (the treads stand out and still look good).
Thanks to all of you the key point that I have realized is that I should have rotated tires more frequently. I think I had mine rotated almost 15k miles ago.
My 91 w/80K had the same problem (tires with flat spots). Sounded like a truck. I only had 40K on the 80K tires. My struts were shot and the bad roads led to the tire flatness. I thougt I had a rubbing brake rotor, but it was OK.
A full alignment is part of the strut replacement, and you will have to pay for it ($60 for alignment). You'll have a smooth drive once you replace both. Expect to pay under 1K for the complete job. Tires: $90 pop and struts around $75 each (not including labor). Of course, you can find cheaper priced tires and struts). Don't forget to take advantage of the free tire rotation if you purchase at company X. Make sure it's near a mall so you can shop during the free rotation
Good luck..
Have 48K miles on car, 3rd set of tires, rotated every 5k and tire pressure checked every other week. Every set starts out great, then the ride quality tanks really fast... Michelin, BFG, or yes, even Bridgestone (haven't decided), here I come!
OEM tires are completely different in quality and design, no matter what tire manufacturer you're dealing with. Just like most bid situations, the one with the lowest bid gets the bid - where does that leave quality? (on the shelf)
My original set of 4 are still on my 1996 Chrysler Concorde, and going strong. Just yesterday I was "cruising" homeward at the end of a 300 mile round trip at a brisk pace, uuuuuuh, yeah, the scenery was going by very swiftly... no problems with those tires at all.
My point is, I guess, that not all OEM squatty tires on Chryslers are shoddy. Maybe that 45 profile is a problem? By the way, I am no fan of Goodyear, but I believe in giving credit where it is due.
I remain unhappy about the excessive balancing weights used to put Wranglers on my Ranger, as a free deal for my recalled Firestones. I have not had a problem with those Wranglers, but I am waiting...
Get ready for new rears down the road...
I'm a little nervous about having 2 new tires with 2 older tires...any comments?
Make certain that the wheel/wheels are running true (not bent). Hand spin tires on the truck on a lift rack and look for lumps and bumps on any tire surfaces, and look for tire running true. Does the tread rise and fall as the tire spins? That would mean out of round, very likely. Does the tire circumference move from side to side as the tire spins? Broken cords can do this. Balancing cannot fix these problems, and only new tires can do it (presuming you do not have a bad wheel or more).
By the way, I strongly recommend that you run the prescribed size of tire for this vehicle-- there are reasons for this decision. I learned this the hard way with a 1993 Explorer that I bought new and replaced tires on, due to mileage wearout, two times before selling it.
