On the newer systems they use a viscous center diffy with a 50/50 torque split that essentially puts power to both driveshafts at the same time. If the front slips more power is sent to the rear and visa versa. In addition you probably have a rear LSD which does the same thing except from left to right in the rear.
On the 4EAT transmissions prior to '96 you had a 90/10 torque split using an electromagnetic clutchpack in the AT. Post '95 it went to a 80/20 split. Now the VTD/VDC 4EAT has a 45/55 torque split and more clutch packs than the older ones.
-mike
So what is the difference in the way the AWD works if you have a manual or automatic transmission. Here is the confusing paragraph from the brochure which makes it look like the 2003 Forester has two types of AWD systems, depending on what transmission type you pick:
"Manual transmission models split engine power 50/50 between front and rear wheels. Models with automatic transmission use Active All-Wheel Drive, an electronically controlled muliplate transfer clutch for maximum traction".
I don't have the LSD since that is only available in the 2.5XS model.
MT System: Viscous Coupled Center diffy, moves power front to rear based on slippage with a 50/50 initial torque split and a 60/40 40/60 range of movement.
AT System: Electronically controlled torque splitting unit 80/20 intial torque split up to 50/50 depending on slippage, weight distribution, etc.
The AT system uses sensors to give input to the transmission which splits the power, based on those inputs it shifts the power around.
Hope this helps.
-mike
I just paid a visit to the owner of the body shop and asked him the question. He said the $500 is a waste of money. The oil treatment is as good and probably better at covering all the protential rusting places. What he told me that is very interesting is that you should never park a car on grass or even bare earth because that holds in dampness and it creeps in under the car. Salt is an enemy he said, but humidity is very bad as well. Park your car on dry pavement or on crushed stone.
-mike
Bob
I prefer the feel of the manual's viscous coupling because it sends more power to the rear axle by default. The Auto's system is more sophisticated but feels more like FWD.
Both are probably more than you'll need.
Saw a post at 12:26 in another topic that you'd bought the Forester. Congrats!
-juice
Funny and true story. My sister had cross-shopped a Forester and a Camry, remember? Well, she bought the Forester. Now it's in to have some accessories installed, and she got a loaner....Camry!
Hilarious. I asked and she said that after driving the Camry around for a 2nd day, she still preferred her Forester. Cool.
For the mechanics in this group, check out the Miata thread for the story on the clutch slave cylinder rebuild on the Miata. Finally got that done, and took some pics that may come in handy later for someone.
-juice
We'll be interested in your comments as to the Forester pans out as a "farm truck."
You might even consider getting the factory/dealer trailer hitch. If you get a light utility trailer, I'm sure you can get a bunch of bales of hay, and not worry about getting that straw all over the interior. Juice has used my 5'x8' utility trailer behind his 5-speed Forester several times to get loads of mulch.
The Forester 5-speed is rated to pull 2400 pounds. If you're just going to use it in the fields for hauling hay, it should be fine. Out on the highway you should have trailer brakes to pull over 1000 pounds, but I would think that the low speeds in the fields wouldn't be a problem. Also, the Hill-Holder clutch should make it less stressfull on the drivetrain when pulling a trailer. I would seriously think about that option.
Bob
http://www.thecarconnection.com/index.asp?article=6111&sid=18- 1&n=157
Bob
I bet this will be even more popular than the hot H2.
Bob
My conern right now is why the dealer hasn't called with a registration number and delivery dates. I hope he doesn't call and say that there are no manual silver 2.5x models left! After being patient for so long, I am now VERY impatient!
The rubber cargo mat is very good to have. You might also get the rear rubber bumper pad. You never know when something might scuff up the bumper, especially considering how you might use the car.
You also have a roof rack that's rated to carry 150 pounds too.
Bob
Your body shop probably uses a high pressure gun to coat the car with oil. You can probably duplicate that either with a low or high pressure applicator. Obviously a HP applicator would be better, but you can probably do as nearly as good a job with a low pressure applicator. What does your body shop charge for an oil application? i believe that you said that it was done annually. Sounds like your talking fairly big $$. Again the way cars are built nowadays I'd question the necessity of even doing that. If you've ever leased a car the dealers don't rust proof them. Their reasoning is that rust won't show up during the life of the lease. There was another famous rust proofing system of about 25-30 years ago (forget name), but they guaranteed their treatment for five years. The catch is that it will almost always take longer than five years for rust to show up. Bottom line is that you don't see the rust buckets on the road that you saw 30-40 years ago, even near the ocean where you're near salt water. Whatever money it costs, I'd keep it in your pocket. The college fund may be going towards the body shop owner's kids instead.
Ed
Bob
Considering how highly-stressed the 2.5l is in the STi (even with the beefed-up internals), it's not too surprising to hear about spark knock. Since the XT's engine isn't being asked to do quite as much, I'd be willing to bet it won't suffer from the same trouble.
I bet it'll sell like crazy. Funny that Isuzu engineered it, if it has a Duramax it might actually be interesting.
I gotta say, a trailer would be really handy on a farm. Any interior will take a beating, let the trailer take the beating instead. Even if it's a cheap $300 4'x8' used one.
-juice
Interesting review on the Touareg. It's got one full-featured AWD system. There's a good write up in over in the VW Vortex forums.
So, is the STi's 300HP rated at 91 octane?
Ken
-mike
Jon: I've heard stories of how a gas truck goes from station to station (different brands) and fills up using the same gasoline. Of course the station may or may not put in their own additives, who knows.
But look in the WSJ and you find that premium wholesales for 3 cents more than regular, yet some stations around here charge 20-25 extra for it. It's robbery.
Then again others charge just 10 cents more. If you have an Entertainment Book, you get 10 cents off per gallon of premium once a month at Crown stations. That's the only time I've gotten it.
We had a 626 and used nothing but premium in it. At about 50k miles, the fuel injection got clogged up and we had to do a throttle body service, the dealer charged a couple hundred bucks, ouch.
The irony is that on my old Escort, I'd use the cheapest stuff I could find, price being the *only* criteria. It went 107k miles without ever needing that service!
Both were Mazda engines, FWIW, and we owned them at the same time.
<here comes Colin to disagree> ;-)
-juice
3 cents is on the low side but of course the wholesale price difference isn't as large as the retail price difference.
-Colin
Bob
Then we got the throttle body cleaned and BAM! it was quick again. We had probably lost 30 horsepower.
Even if it was one bad tank, I'd expect better quality control from higher octane gas. Guess not.
-juice
I've always liked the Patrol. My only problem was it was rather primitive by current standards. The new model, while still a true back-to-basics SUV, appears to have been given some much needed upgrades. It's a shame it's not sold here, especially with the excellent 3.0 I-4 turbo diesel.
Bob
-juice
-Colin
-juice
Bob
Bob
Bob
-juice
monster balance shafts!
-Colin
Ken
but mainly when the idea got off the ground with the 924, they didn't want to use a six cylinder due to tromping on the 911's hallowed ground. the 914-6 raised enough hackles five or so years previous.
-Colin
-mike
-juice
Jon
Bob
