How to Pick a Pickup
The automatic stinks and I would like to avoid getting another. But I am concerned about the comments about towing limitations on manual transmissions. Since I tend to keep vehicles for extended periods I would like to be able to buy a ski-boat in the 10 years.
It seems to me large trucks on the road are manual shifts whats up with pickup trucks? Is this just a warranty problem for jokers riding the clutch or are the manuals in pickups lower quality than the automatics?
Pretty Full: Even worse
Fifth Wheel: Pathetic
Please reply, or copy yuor reply to my e-mail address since time is short: condit@aol.com.
THANKS!
I would go with the limited slip. I am looking into getting a 99 F150 XLT also. I was told that the limeted slip feature prevent the axle from sliping. It will only improve the control of the vehicle when it encounter slipery driving condition. In other word it should enhence the 4WD. Best of luck.
Regards
Thau
I have ordered it on the '99 Silverado 2WD I'm getting. Handy when pulling a boat out of the water or in the snow, even on a 2WD
price in order to get close to invoice....
Performance is key, however don't necessarily desire to go overboard. Lean toward Ford product as result of others apparent satisfacation plus personal experience with Ford cars.
I just got a '99 F350 CC DRW 4x4 ... one reason I got the DRW was for future trailer towing. While it doesn't add anything to your rated capacities I like the added stability and the protection from tight corner rear-tire blowouts that it adds. You may not be looking for something that big though. Tell us a little more about your situation, and we'll try to help :-)
When you're looking at vehicle weight ratings for towing, the GVWR isn't what you need. GVWR is the max *vehicle* (truck + internal payload) weight.
What you want to compare is the GCWR, or Gross Combined Weight Rating. That's the maximum weight (truck + payload + trailer) that the truck is rated to move.
Also, keep the trailer tongue weight in mind. I'd expect burned axle bearing to be more of a tongue weight problem than a total trailer weight problem...
For a 5th wheel, you can get away with a short bed if you use a ~$2500 extending hitch, otherwise you'll need the long. Are you towing all the time? If so, I'd get the diesel. If not, stick with the V10. Beyond that, just spec it normally and you'll love your purchase :-)
My preference at this point is the Nissan king cab ,Toyota king cab, or the Mazda extended cab.
Thanks for any reply on this subject
donreid@futureone.com
Keep on Truckin
first year with all new stuff, i'm a little leary
buying before the kinks are out. and it seems that
fords are everywhere i look on the road,somebody likes them for a reason.
There is a good reason.....they're a good truck. I've driven one for the past 2 years. The '97 model was the first year for new body style. Mine is an F150 extended cab 4x4. Performed flawlessly for 25,000 miles.
Getting dizzy looking at Frontiers, Tacomas, Rangers, S10s, etc.....
What's the best buy??
But with all the talk about Chev. having problems with customer support I am now considering another ford f-150 but this time the 4x4 w/ off road package. Can anyone compare the Z71 to the "off road" ford? Also any general comments about either truck. Thanks
I agree with sd99. Try to forget brand loyalty and try not to listen to those who are giving advice based on the same.
Go look at each one. Test drive each one. And, as sd99 says, DON'T let the salesperson talk you into something you don't want. You're going to have to live with your new truck for a while. Concentrate on what YOU want and what YOU can afford. Salespeople will always try to convince you otherwise.
All three - Ford, Dodge, Chevy - make good trucks. Pick the one that will suit your needs and makes you happy just looking at it.
dunlay.
Mike
lovtlc@gte.net
For Dave40's benefit: Low end torque is what lets you peel out of parking lots, btw.
Geez.
