Question about Alternators
K - here's the deal - I am basically clueless about cars other than that I don't like mine at the moment. I bought a use '96 Grand Am about a year ago - currently it has 120k miles on it...since I bought it I have had lights that like to come on and off (most especially the check oil light and/or a combination of the ETS and check engine light at the same time) but just a few weeks ago my battery light came on and the next day the whole thing went nuts and died on me...it was diagnosed as the alternator and I got it fixed and it runs now - the only thing is my check oil light is coming on and off again...I have talked to a few people I know that know a thing or two about cars and they all told me to get rid of it ASAP because more than likely my alternator will go out again...I'm just looking for some suggestions and other people with experience - thanks!!!
If your alternator was replaced recently and it goes out again, you should work out something with your mechanic, as the part may have been defective, or he missed something the first time around -- maybe a time for a change in mechanics rather than a change in cars?
kirstie_h
Roving Host
Edmunds.com
MODERATOR /ADMINISTRATOR
Review your vehicle
I don't think dumping a car with a flickering oil light is going to be too successful, financially or otherwise, so you'll have to deal with it.
on most cars this $8-14 part can be replaced in a quarter hour or less, so the bill should not be that evil.
if you still have oil pressure light blinks, a mechanical gauge should be hooked up to diagnose any potential oil issues.
Good luck
Hint most foreign car lovers that buy German or Japanese AND properly maintain them keep them more than a few years.
An unmaintained import can show you what repair cost nightmares can be.
Harry
I have a 2000 Protege ES (automatic). I have had the car for almost 2 years now and it has been flawless...nothing but oil changes until now. I took a trip to Nashville, TN (from Raleigh, NC) and on the way back it was raining hard for about 2 hours straight. The rain let up and shortly after I had the cruise control, AC, rear defogger, radio, and headlights on. Occasionally my headlights got brighter for a few seconds and then back to normal. At the same time there was a slight surge (or hesitation?) in engine power. As I was almost back to Raleigh my battery light starting coming on, then going back off (and I felt the hesitation). I noticed this as I exited off of the highway onto the exit ramp. It was 3AM when I got in so I didn't do anything about it at the time. The next day I checked the belts and battery connections and everything looked fine. During the next week I made several short trips (non highway) and the problem did not re-occur.
Since I am moving to Nashville next week I took the car in to get this checked out before I make the 8+ hour drive. When I explained the symptoms over the phone to the service department they suspected the alternator. I brought the car in to the dealership today (wed) and the battery light came on as I was exiting the highway to go to the dealership (again with hesitation). This is the first time I had the car up to highway speed since my trip last week. They checked the car and said the alternator was fine. He also said he didn't have authorization to replace parts unless he could diagnois what the problem was (still under warranty). He said to pick up the car and if it happened again to bring it back in immediately. I told him this was not acceptable since I am moving and making the long drive to TN next week, and I want the problem solved. He agreed to have a mechanic take it on the road tomorrow to try and replicate the problem.
Does anyone have a clue as to what could be causing this? Any help would be greatly appreciated. BTW, the car starts fine, so I don't think the battery is losing its charge (yet).
I posted this at Protege problems forum yesterday. To update, the dealer drove the car for 40+ miles at various speeds (including highway) and they couldn't replicate the problem. They drove with the A/C and other power using accessories on. I HAVE to drive this car 500+ miles to Nashville, TN next week, as I am moving there next week. I feel like I am being set up for disaster.
Thanks for help.
if the regulator is sour, or external and there are intermittents in the wiring to it, you can mess up internal circuitry in either one.
if the battery is a chunk'o'lead and no chemical action, high drain could be killing the diode trio or the brushes.
if you have a 600-watt ham transciever in there and you don't have the power leads well filtered, you could have harmonics running on the DC leads that are finding a resonant circuit in the alternator and blowing it.
lots of places to fail. which ones are going out? if the mechanics aren't telling you that, we can't assist. oh, and there could be a "lifetime limited warranty" on those alternators for the simple reason that they are being rebuilt from bad cores with inadequate or no inspection.
